    Float to bytearray conversion for sigfox payload
    sigfoxmicropythontypeerror
    23 Posts 4 Posters 4.1k Views 5 Watching
      robert-hh @tttadam
      @tttadam You use struct.pack() to put these two floats into an 8 byte array without converting them to a string. That results in the shortest possible message, not readable for human eyes withou doing an unpack.
      import ustruct
      lat =47.497132
      lon =19.063296
      msg = ustruct.pack("ff", lat, lon)
      # and unpack
      lat, lon = ustruct.unpack("ff", msg)
      T 1 Reply Last reply Reply Quote 2
        tttadam @robert-hh
        @robert-hh said in Float to bytearray conversion for sigfox payload:
        Nice, thank you.
        I think is still posible save some more space if cut the first caracter and the dot. (And then possible to include more information)
        Which I try and fail to doing here. I think the unpacked value is rounded somehow.
        >>> lat
        47.49713
        >>> lon
        19.0633
        >>> msg2 =int((str(lat*100000)[1:-2]+str(lon*100000)[1:-2]))
        >>> msg = ustruct.pack("ff", msg2)
        >>> ret = ustruct.unpack("ff", msg)
        >>> print(ret)
        (7.497139e+11, 0.0)
          jcaron @tttadam
          @tttadam What you are doing is covering two floats to strings, concatenating them, converting the total to an int, packing that in as a float, and unpacking.
          Forget about str. Just use pack directly with the original values: ustruct.pack("ff",lat,lon)
          Or if you want to avoid sending floats over the air, you may convert them to ints and pack than as such instead.
            robert-hh @tttadam
            @tttadam msg2 contains an single int. So you must not use "ff" for pack, since that tells, that two float numbers are supplied. You have to use "i", which will pack (and unpack) it into a 4 byte format.
            Please have a look at the documentation of struct: https://docs.python.org/3/library/struct.html
              tttadam @robert-hh
              I see now. Okay. But I think I am still missing some information. Because I can't get back the same number.
              >>> lat
              47.49713
              >>> lon
              19.0633
              >>> msg2 =int(str(lat*100000)[1:-2]+str(lon*100000)[1:-2])
              >>> msg2
              749713906330
              >>> msg = ustruct.pack("i", msg2)
              >>> msg
              b'\x9aZn\x8e'
              >>> ret = ustruct.unpack("i", msg)
              >>> ret
              (-1905370470,)
              robert-hhR J 3 Replies Last reply Reply Quote 0
                robert-hh @tttadam
                @tttadam The numer is too long for the i format, then you have to use the "q" format (long long). But that results in 8 bytes, and then you can also directly pack the two floats and have no further need for reformatting or scaling (see my post below).
                Using the "q" format, you could eventually drop the last three bytes, they are zero, and add them before unpacking. But that does not seem to be worth the effort.
                  robert-hh @tttadam
                  @tttadam Or you could split the number:
                  >>> msg2
                  749713906330
                  >>> msg = ustruct.pack("IB", msg2 // 256, msg2 % 256)
                  >>> msg
                  b'Zn\x8e\xae\x9a'
                  >>> msb,lsb = struct.unpack("IB", msg)
                  >>> ret=msb * 256 + lsb
                  >>> ret
                  749713906330
                  But still that is overkill compared to the float packing, unless you fight for every single byte.
                    tttadam @robert-hh
                    @robert-hh So basicly your implamentation is the best. :)
                    Thank you.
                      jcaron @tttadam
                      @tttadam why do you keep doing the same stuff you have already been told twice is not correct?
                      You have been told twice that the solution is very simply ustruct.pack(“ff”,lat,long). What’s wrong with that? Stop with the str and the concatenation and all that. Just pack the two values, and you’re done.
                        robert-hh @jcaron
                        @jcaron I think that this was @tttadam's conclusion.
                        • 2 / 2
