    Float to bytearray conversion for sigfox payload
    sigfoxmicropythontypeerror
    23 Posts 4 Posters 4.1k Views 5 Watching
      tttadam @tttadam
      @tttadam I am not sure if anyone still follows this topic, but this is the current status.
      I think I can't compress the gps coordinates anymore, but there is still space some other telemetry data.
      sfMessage=(str(my_gps.latitude[0]*100000)[1:-2]+str(my_gps.longitude[0]*100000)[1:-2]).encode()
      sf.send(bytes(sfMessage))
        tttadam
        @tttadam Nope, I think there is still place for improving.
        This send the caracters as string not as byte array.
          robert-hh @tttadam
          @tttadam But using a string representation requires always more space. As binary representation, you encode 8 bit per byte, as a (decimal) string, you encode about 3 bit per byte.
          Example: A 32 bit integer (or float) always requires 4 byte space, wheras as string it may take need up to 11 bytes for integers and up to 14 bytes for floats.
          P.S.: I recall that you had problems to decode binary numbers at the receiving side.
            tttadam @robert-hh
            @robert-hh I don't really have a problem with decoding on the receiving side, because there is no receing side. only chack the backend.sigfox with my eyes only. My issue right now that I can't convert this string to bytes. I am not sure what method should I use. Probably something trivial I think.
            This is the useful information:
            lat =47.497132
            lon =19.063296 #(famous ruinpub in Budapest)
            str(lat*100000)[1:-2]+str(lon*100000)[1:-2]
              robert-hh @tttadam
              @tttadam You use struct.pack() to put these two floats into an 8 byte array without converting them to a string. That results in the shortest possible message, not readable for human eyes withou doing an unpack.
              import ustruct
              lat =47.497132
              lon =19.063296
              msg = ustruct.pack("ff", lat, lon)
              # and unpack
              lat, lon = ustruct.unpack("ff", msg)
              T 1 Reply Last reply Reply Quote 2
                tttadam @robert-hh
                @robert-hh said in Float to bytearray conversion for sigfox payload:
                Nice, thank you.
                I think is still posible save some more space if cut the first caracter and the dot. (And then possible to include more information)
                Which I try and fail to doing here. I think the unpacked value is rounded somehow.
                >>> lat
                47.49713
                >>> lon
                19.0633
                >>> msg2 =int((str(lat*100000)[1:-2]+str(lon*100000)[1:-2]))
                >>> msg = ustruct.pack("ff", msg2)
                >>> ret = ustruct.unpack("ff", msg)
                >>> print(ret)
                (7.497139e+11, 0.0)
                  jcaron @tttadam
                  @tttadam What you are doing is covering two floats to strings, concatenating them, converting the total to an int, packing that in as a float, and unpacking.
                  Forget about str. Just use pack directly with the original values: ustruct.pack("ff",lat,lon)
                  Or if you want to avoid sending floats over the air, you may convert them to ints and pack than as such instead.
                    robert-hh @tttadam
                    @tttadam msg2 contains an single int. So you must not use "ff" for pack, since that tells, that two float numbers are supplied. You have to use "i", which will pack (and unpack) it into a 4 byte format.
                    Please have a look at the documentation of struct: https://docs.python.org/3/library/struct.html
                      tttadam @robert-hh
                      I see now. Okay. But I think I am still missing some information. Because I can't get back the same number.
                      >>> lat
                      47.49713
                      >>> lon
                      19.0633
                      >>> msg2 =int(str(lat*100000)[1:-2]+str(lon*100000)[1:-2])
                      >>> msg2
                      749713906330
                      >>> msg = ustruct.pack("i", msg2)
                      >>> msg
                      b'\x9aZn\x8e'
                      >>> ret = ustruct.unpack("i", msg)
                      >>> ret
                      (-1905370470,)
                      robert-hhR J 3 Replies Last reply Reply Quote 0
                        robert-hh @tttadam
                        @tttadam The numer is too long for the i format, then you have to use the "q" format (long long). But that results in 8 bytes, and then you can also directly pack the two floats and have no further need for reformatting or scaling (see my post below).
                        Using the "q" format, you could eventually drop the last three bytes, they are zero, and add them before unpacking. But that does not seem to be worth the effort.
                          robert-hh @tttadam
                          @tttadam Or you could split the number:
                          >>> msg2
                          749713906330
                          >>> msg = ustruct.pack("IB", msg2 // 256, msg2 % 256)
                          >>> msg
                          b'Zn\x8e\xae\x9a'
                          >>> msb,lsb = struct.unpack("IB", msg)
                          >>> ret=msb * 256 + lsb
                          >>> ret
                          749713906330
                          But still that is overkill compared to the float packing, unless you fight for every single byte.
                            tttadam @robert-hh
                            @robert-hh So basicly your implamentation is the best. :)
                            Thank you.
                              jcaron @tttadam
                              @tttadam why do you keep doing the same stuff you have already been told twice is not correct?
                              You have been told twice that the solution is very simply ustruct.pack(“ff”,lat,long). What’s wrong with that? Stop with the str and the concatenation and all that. Just pack the two values, and you’re done.
                                robert-hh @jcaron
                                @jcaron I think that this was @tttadam's conclusion.
