    Float to bytearray conversion for sigfox payload
    sigfoxmicropythontypeerror
    23 Posts 4 Posters 3.9k Views 5 Watching
      tttadam
      I manage to store my data in csv file, and now I want to send it over sigfox.
      for example si7021.readtemp() returs a float: 26.32735
      How can I put this float into the sigfox message, what only accept a bytearray:
      s.send(bytes([1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12]))
        robert-hh @tttadam
        @tttadam There a quite a few options. Just to name two:
        • You can use struct.pack("f", float_number), which gives the shortest representation (4 bytes), or
        • you make a string out of it, with str(float_number).encode(), which returns a readable bytearray of varying length.
        Packing is one aspect, but you have to unpack it too. There was a post a few days ago dealing with that task.
        T 1 Reply Last reply Reply Quote 2
          tttadam @robert-hh
          @robert-hh Thanks for the tip. Both of them worked. The first is when I send it as a string (it's temperature data), the second when I send it as byte. But I am not sure how to decode the second one. If you have some tips, or link to other discussion that would be great.
          2018-11-03 21:42:35 32352e3539383034 ASCII: 25.59804
          2018-11-03 21:37:55 a404d241 ASCII: ...A
          My main goal is that send some cordinates also alongside sensor data, but I got the message size.
          Is there a way to compress my sentence?
          My sentence is like this:([47.45194, 'N'] [19.02091, 'E']);temp;25.68384
            jcaron @tttadam
            @tttadam I strongly recommend you convert the data to some integer representation (e.g. multiplying by 100 and truncating to an integer), depending on expected range and desired accuracy. It will make things much simpler for you, and if you pick the right integer size, will probably save you a few bytes, which for media like LoRa or Sigfox, can be essential.
            T 1 Reply Last reply Reply Quote 3
              tttadam @jcaron
              @jcaron Converting to int saved a few bites for me for sure! Thanks!
              But I am still struggling to push GPS data into 12 bytes
              2018-11-04 06:41:20 32313235 ASCII: 2125
              robert-hhR rcolisteteR 2 Replies Last reply Reply Quote 0
                robert-hh @tttadam
                @tttadam What's the problem. You have 3 numbers for latitude, longitude and temperature. Each of them can be converted to a 4 byte signed int, resulting in 12 bytes. So you have +/- latitude, +/- longitude and +/- temp. If you set latitude and longitude to 1 millionth degree, there is still sufficient resolution in a long int. You do not need to send the ASCII decoration in the message. The receiver can restore that, when unpacking the data.
                What kind of coding is available at the receiver side?
                • rcolisteteR Offline
                  rcolistete
                  The Si7021 humidity/temperature sensor :
                  https://www.silabs.com/products/sensors/humidity/si7006-13-20-21-34
                  https://www.silabs.com/documents/public/data-sheets/Si7021-A20.pdf
                  has 0.3-0.4 C accuracy and repeatability/noise of 0.01-0.08 C. So any reading after centesimals (hundredths) has almost no meaning.
                  Other possibility is the node to make many (10-100) measurements and calculate the mean to have a more stable value, but usually temperature sensor gives a slow changing value.
                  I suggest to use :
                  temp_pack = struct.pack(">h", round(si7021.readtemp()*100))
                  where '>h' is signed int with 2 bytes :
                  https://docs.python.org/3/library/struct.html#format-characters
                  https://docs.micropython.org/en/latest/library/ustruct.html
                  so accepting temperatures between [-327.68, +327.67] C.
                  Depending on the use (IoT Cloud service, etc), the temperature should have up to decimals (like Cayenne), i. e. :
                  temp_pack = struct.pack(">i", round(si7021.readtemp()*10))
                  P.S. : fixed '>i' (4 bytes)' to '>h' (2 bytes).
                    rcolistete @tttadam
                    Like @roberto-th said, which is the code at the receiver side ?
                    One option is to convert the GPS numbers to integer, like Cayenne LPP :
                    https://mydevices.com/cayenne/docs/lora/#lora-cayenne-low-power-payload
                    https://community.mydevices.com/t/cayenne-lpp-2-0/7510
                    for GPS :
                    Latitude : 0.0001 ° Signed MSB
                    Longitude : 0.0001 ° Signed MSB
                    Altitude : 0.01 meter Signed MSB
                      tttadam @rcolistete
                      @rcolistete @rcolistete Regading to the receiver side:
                      There isn't any so far, so it could be anything. :)
                      But I am thinking about google cloud platform (maps api)
                      Thanks for tips, I will try to imlement them, and I will be back with the result.
                        tttadam @tttadam
                        @tttadam I am not sure if anyone still follows this topic, but this is the current status.
                        I think I can't compress the gps coordinates anymore, but there is still space some other telemetry data.
                        sfMessage=(str(my_gps.latitude[0]*100000)[1:-2]+str(my_gps.longitude[0]*100000)[1:-2]).encode()
                        sf.send(bytes(sfMessage))
                          tttadam
                          @tttadam Nope, I think there is still place for improving.
                          This send the caracters as string not as byte array.
                            robert-hh @tttadam
                            @tttadam But using a string representation requires always more space. As binary representation, you encode 8 bit per byte, as a (decimal) string, you encode about 3 bit per byte.
                            Example: A 32 bit integer (or float) always requires 4 byte space, wheras as string it may take need up to 11 bytes for integers and up to 14 bytes for floats.
                            P.S.: I recall that you had problems to decode binary numbers at the receiving side.
                              tttadam @robert-hh
                              @robert-hh I don't really have a problem with decoding on the receiving side, because there is no receing side. only chack the backend.sigfox with my eyes only. My issue right now that I can't convert this string to bytes. I am not sure what method should I use. Probably something trivial I think.
                              This is the useful information:
                              lat =47.497132
                              lon =19.063296 #(famous ruinpub in Budapest)
                              str(lat*100000)[1:-2]+str(lon*100000)[1:-2]
                                robert-hh @tttadam
                                @tttadam You use struct.pack() to put these two floats into an 8 byte array without converting them to a string. That results in the shortest possible message, not readable for human eyes withou doing an unpack.
                                import ustruct
                                lat =47.497132
                                lon =19.063296
                                msg = ustruct.pack("ff", lat, lon)
                                # and unpack
                                lat, lon = ustruct.unpack("ff", msg)
                                  tttadam @robert-hh
                                  @robert-hh said in Float to bytearray conversion for sigfox payload:
                                  Nice, thank you.
                                  I think is still posible save some more space if cut the first caracter and the dot. (And then possible to include more information)
                                  Which I try and fail to doing here. I think the unpacked value is rounded somehow.
                                  >>> lat
                                  47.49713
                                  >>> lon
                                  19.0633
                                  >>> msg2 =int((str(lat*100000)[1:-2]+str(lon*100000)[1:-2]))
                                  >>> msg = ustruct.pack("ff", msg2)
                                  >>> ret = ustruct.unpack("ff", msg)
                                  >>> print(ret)
                                  (7.497139e+11, 0.0)
                                    jcaron @tttadam
                                    @tttadam What you are doing is covering two floats to strings, concatenating them, converting the total to an int, packing that in as a float, and unpacking.
                                    Forget about str. Just use pack directly with the original values: ustruct.pack("ff",lat,lon)
                                    Or if you want to avoid sending floats over the air, you may convert them to ints and pack than as such instead.
                                      robert-hh @tttadam
                                      @tttadam msg2 contains an single int. So you must not use "ff" for pack, since that tells, that two float numbers are supplied. You have to use "i", which will pack (and unpack) it into a 4 byte format.
                                      Please have a look at the documentation of struct: https://docs.python.org/3/library/struct.html
                                        tttadam @robert-hh
                                        I see now. Okay. But I think I am still missing some information. Because I can't get back the same number.
                                        >>> lat
                                        47.49713
                                        >>> lon
                                        19.0633
                                        >>> msg2 =int(str(lat*100000)[1:-2]+str(lon*100000)[1:-2])
                                        >>> msg2
                                        749713906330
                                        >>> msg = ustruct.pack("i", msg2)
                                        >>> msg
                                        b'\x9aZn\x8e'
                                        >>> ret = ustruct.unpack("i", msg)
                                        >>> ret
                                        (-1905370470,)
                                        robert-hhR J 3 Replies Last reply Reply Quote 0
                                          robert-hh @tttadam
                                          @tttadam The numer is too long for the i format, then you have to use the "q" format (long long). But that results in 8 bytes, and then you can also directly pack the two floats and have no further need for reformatting or scaling (see my post below).
                                          Using the "q" format, you could eventually drop the last three bytes, they are zero, and add them before unpacking. But that does not seem to be worth the effort.
                                            robert-hh @tttadam
                                            @tttadam Or you could split the number:
                                            >>> msg2
                                            749713906330
                                            >>> msg = ustruct.pack("IB", msg2 // 256, msg2 % 256)
                                            >>> msg
                                            b'Zn\x8e\xae\x9a'
                                            >>> msb,lsb = struct.unpack("IB", msg)
                                            >>> ret=msb * 256 + lsb
                                            >>> ret
                                            749713906330
                                            But still that is overkill compared to the float packing, unless you fight for every single byte.
