    if lte.is attached() makes it think it's not
    if lte.isattachgpy
    1 Posts 1 Posters 397 Views 2 Watching
    • K Offline
      kjm
      I can run this program repeatedly & it works OK
      import time, pycom, machine
      import urequests as requests
      from network import LTE
      lte = LTE()
      pycom.heartbeat(False)
      def getLTE():
        if lte.isconnected(): return lte
        if not lte.isattached():
          print('attaching ', end=''); lte.attach()
          while not lte.isattached(): print('.', end=''); time.sleep(1)
        if not lte.isconnected():
          print('connnecting ', end=''); lte.connect()
          while not lte.isconnected(): print('.', end=''); time.sleep(1)
        return lte
      getLTE()
      r=requests.get('http://micropython.org/ks/test.html'); print(r.text)
      lte.disconnect()
      But if I add one extra line to check the modem is still attached
      lte = LTE(); rtc = RTC()
      def getLTE():
        return lte
      getLTE()
      if lte.isattached(): pycom.rgbled(0x007f00)
      lte.disconnect()
      it won't run a second time. On the second run it behaves like it thinks it's not attached. It looks like asking if it's attached makes it think it's not?!
      attaching Traceback (most recent call last):
        File "<stdin>", line 18, in <module>
        File "<stdin>", line 11, in getLTE
