    I swore I had RTC ntp_sync() working on my Lopy and now I can't get it working at all?
    lopyntp sync rtc
    6 Posts 5 Posters 1.3k Views 5 Watching
      duhmojo
      Hi. I was writing a pair of Lora test apps to NTP sync the clock from one to the other, where ntp_sync() was used to setup the RTC. I swore I had this bit working yesterday and now I can't get anything working over
      from machine import RTC
      from machine import UART
      from network import WLAN
      from network import LoRa
      uart = UART(0, 115200)
      os.dupterm(uart)
      pycom.heartbeat(False)
      wlan = WLAN()
      if machine.reset_cause() != machine.SOFT_RESET:
          wlan.init(mode=WLAN.STA)
          wlan.ifconfig(config=('192.168.2.230', '255.255.255.0', '192.168.2.1', '192.168.2.3'))
      if not wlan.isconnected():
          wlan.connect(ssid='SSID', auth=(WLAN.WPA2, 'password'))
          while not wlan.isconnected():
      print(wlan.ifconfig())
      print("Syncing RTC to NTP...")
      rtc = RTC()
      rtc.ntp_sync("pool.ntp.org", update_period=3600)
      while not rtc.synced():
          pass # save power while waiting
      print(rtc.now())
      Basically the ntp_sync() call and subsequent while loop just sits there while nothing syncs. I'm tempted to try and setup a wireshark sniffer on my router to watch what the Lopy is trying to do over the Wifi network.
      Any ideas? Thanks!
        duhmojo
        Ah... I think my machine.SOFT_RESET might have had something to do with it. When I hit the reset button on the unit it reloaded and reconnected to my wifi correctly I believe, because I started ntp_sync()ing correctly. Thanks.
          protean
          Did you ever solve this? I'm still having this issue, today, on a FiPy.
          T P 2 Replies Last reply Reply Quote 0
            Thosch42 @protean
            @protean
            Have you tried to use a IP adress instead of the URL? Just for testing...
              Paul Thornton @protean
              @protean Can you confirm your on the latest firmware?
                reidfo @Paul Thornton
                @paul-thornton I replied on another thread that I think you responded to that I have this issue with 1.20.0.rc0. I reverted back to my unmodified build of 1.19.0.b4 and the problem disappeared. I found that after machine.reset() the clock still would not sync reliably (or at all) and even sometimes after a hard reset by hitting the reset button.
