    New Firmware Release Candidate v1.20.0
    firmware
    81 Posts 17 Posters 23.4k Views 18 Watching
      serafimsaudade @iwahdan
      @iwahdan
      But when I try format to littleFS. It don't work.
      P X 2 Replies Last reply Reply Quote 0
        Paul Thornton @serafimsaudade
        @serafimsaudade HI. Can you give us any more details on the issue your having. do you get any error messages?
        • X Offline
          Xykon administrators @serafimsaudade
          @serafimsaudade said in New Firmware Release Candidate v1.20.0.rc0:
          Please try the following:
          pycom.bootmgr(fs_type=pycom.LittleFS, reset=True)
          This will update the configuration to use LittleFS instead of FatFS. The board will reset automatically.
          Similarly you can switch back to FatFS:
          pycom.bootmgr(fs_type=pycom.FAT, reset=True)
          Note: When switching between LittleFS and FatFS, the flash file system will be re-formatted thus erasing all content.
          Christian Ehlers
            serafimsaudade @Paul Thornton
            @paul-thornton
            When using the Pycom Upgrade software for linux. When I chose LittleFS, the pycom finish the upgrade and start with FatFs
              serafimsaudade @Xykon
              @xykon
              Tks, that works :)
                serafimsaudade
                Now I'm having another problem :/.
                When I call rtc.ntp_sync(pool.ntp.org) func the rtc get the correct time and date but the rtc.synced() never return True.
                Using the 1.19.0.b5 fw this problem disappear.
                  robert-hh @iwahdan
                  @iwahdan The Exposed Keyboard Interrupts Control to Micropython does not work. Reason:
                  The API changes the persistent flags, but the code in machuart.c and telnet.c looks at the non-persistent flags. IMHO, these non-persistent flags are not required, because it is a user script which modifies the flags and can set it back. At the REPL loop in pyexec.c, these flags are anyhow reset to the default state, once REPL gets control again. So better use the mechanism of the initial PR.
                  • I Offline
                    iwahdan @robert-hh
                    Hello @robert-hh, sorry I misunderstood your initial PR, somehow I thought there was a need to control keyboard interrupts in normal REPL, which why I had to do these modifications for it to work.
                    I agree with you, your PR is then sufficient and no further modifications needed, will correct this shortly
                    Wahdan
                    • E Offline
                      EinarJ @iwahdan
                      @iwahdan Why is PSM and eDRX not used when running deinit(dettach=False)?
                        danielm @EinarJ
                        @einarj
                        I did not perform any tests with those features yet but I think you must set requested mode and related timers by AT commands, e.g.:
                        Power Saving Mode Setting:
                        +CPSMS=[<mode>[,<Requested_Periodic-RAU>[,<Requested_GPRSREADYtimer>[,<Requested_PeriodicTAU>[,<Requested_Active-Time>]]]]]
                        • E Offline
                          EinarJ @danielm
                          @danielm I've tried, but it doesn't seem to have any effect. I can see it's being disabled by default in the LTE init, so I've set the command manually after that. The PSM should,in theory, cause the LTE modem go into PSM mode right after the data is sent, but that doesn't seem to happen. Maybe it's becsuse the the flag for going into PSM is not being passes to the modem. But, PSM is useless if you don't cannot setup eDRX. The modem gives me an error if I try the setting specified in the AT-command specs. Do you know if the vendor has implemented these features into the FW?
                            danielm @EinarJ
                            @einarj
                            There are some eDRX-related commands as well:
                            • eDRX Read Dynamic Parameters: +CEDRXRDP
                            • eDRX Setting: +CEDRXS
                            • Specific eDRX Settings: +SQNEDRX
                            I have no idea if PSM/eDRX commands are implemented and working as expected because I did not test them yet.
                            @iwahdan @Paul-Thornton
                            In my opinion Pycom should provide statement regarding readiness of PSM/eDRX features implemented in the modem's firmware because without these features it is not possible to develop battery-powered solutions with reasonable long battery life-time which is the main purpose of NB-IoT.
                            There should also be tutorial available in the documentation because of importance of these features.
                            X 1 Reply Last reply Reply Quote 2
                            • X Offline
                              Xykon administrators @danielm
                              @danielm said in New Firmware Release Candidate v1.20.0.rc0:
                              I will try to post more details about PSM/eDRX as soon as possible. Generally the standard 3GPP AT commands should be used using lte.send_at_command(). However in order to tell the modem to go into PSM/eDRX mode, lte.deinit(dettach=False) should be called. The wrong spelling of dettach aside, the modem checks the state of the flow control pins to see if it is OK to go into low power mode. The deinit command releases the flow control pins thus allowing the modem to go into the configured sleep mode.
                              In regards to the release candidate, after uploading v1.20.0.rc2 earlier today, which includes the latest Sequans firmware updater and Pybytes scripts, I have realised an error was made in pycom_config.h that causes the fs_type flag to be stored at an incorrect position. This is also the reason why the setting from the firmware updater is ignored. I have already uploaded a correction to the release-candidate branch as I had issues updating the perviously used v1.20.0.rc0 branch. I will upload a new version shortly but wanted to give people a heads-up to check the file system type in the firmware updater when updating. This should only affect people who used the commands I posted above to manually switch the fs_type with the pycom_bootmgr command.
                              Christian Ehlers
                              D S 4 Replies Last reply Reply Quote 1
                                danielm @Xykon
                                @xykon
                                Yesterday I did some tests with PSM-related AT commands.
                                Is seems that following commands should sent before attaching (after first boot). Of course timer values of '+CPSMS' may be adapted.
                                self.lte.send_at_cmd('AT+CPSMS=1,,,"01000001","00000001"')
                                self.lte.send_at_cmd('AT+CEREG=4')
                                After successful attach '+CEREG?' returns Active time and Periodic TAU values allocated by the network which may be identical to requested values (this is the case in NB-IoT network of Slovak Telekom) but in other networks they may be limited by the network.
                                It seems that '+CPSMS' command has to be called after consequent boots from deep-sleep (with LTE already attached) as well.
                                E 1 Reply Last reply Reply Quote 2
                                  danielm @Xykon
                                  @xykon
                                  Two comments:
                                  1. please rename branch "release-candiate" -> "release-candidate"
                                  2. I had to install pyserial package manually, before I was getting this error:
                                  # make BOARD=GPY TARGET=boot
                                  Use make SECURE=on [optionally SECURE_KEY ?= secure_boot_signing_key.pem] to enable Secure Boot and Flash Encryption mechanisms.
                                  Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
                                  BASE Variant
                                  mkdir -p build/GPY/release/bootloader/
                                  CC bootloader/bootloader.c
                                  CC bootloader/bootmgr.c
                                  CC bootloader/mperror.c
                                  CC bootloader/gpio.c
                                  CC bootloader/flash_qio_mode.c
                                  AR build/GPY/release/bootloader/bootloader.a
                                  LINK xtensa-esp32-elf-gcc *** -nostdlib -Wl,-Map=build/GPY/release/bootloader/bootloader.map -Wl,--no-check-sections -u call_user_start_cpu0 -Wl,-static -Wl,--undefined=uxTopUsedPriority -Wl,--gc-sections -T esp32.bootloader.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.bootloader.rom.ld -T esp32.rom.spiram_incompatible_fns.ld *** -Wl,--start-group -Lbootloader/lib -Lbootloader -Lbuild/GPY/release/bootloader -L/root/micropython_esp32/pycom-esp-idf/components/esp32/ld -L/root/micropython_esp32/pycom-esp-idf/components/esp32/lib -llog -lcore -lbootloader_support -lspi_flash -lsoc -lmicro-ecc -lgcc -lstdc++ -lgcov build/GPY/release/bootloader/bootloader.a -Wl,--end-group -Wl,-EL -o build/GPY/release/bootloader/bootloader.elf
                                     text    data     bss     dec     hex filename
                                    19086    1992      40   21118    527e build/GPY/release/bootloader/bootloader.elf
                                  IMAGE build/GPY/release/bootloader/bootloader.bin
                                    File ".../micropython_esp32/pycom-esp-idf/components/esptool_py/esptool/esptool.py", line 35, in <module>
                                      import serial.tools.list_ports as list_ports
                                  ImportError: No module named tools.list_ports
                                  application.mk:552: recipe for target 'build/GPY/release/bootloader/bootloader.bin' failed
                                  make: *** [build/GPY/release/bootloader/bootloader.bin] Error 1
                                  Environment: Ubuntu 16.04.3 LTS 64-bit
                                    danielm @Xykon
                                    @xykon
                                    Deep-sleep current on G01 with v1.20.0.rc3 built today from source:
                                    machine.deepsleep()
                                    Result: 7uA OK
                                    import network
                                    lte=network.LTE()
                                    lte.deinit()
                                    machine.deepsleep()
                                    Result: 29mA Not OK!
                                    Both tests are included in this graph:
                                    Edit: Tested with FiPy on custom board (no FTDI or other peripherals) powered with 3.75V from Otii Arc.
                                    Results are almost the same as for G01!
                                    • 22uA for the first test code (includes quiescent current of voltage regulator)
                                    • 27mA for the second test code.
                                    Same results if LTE is attached between init and deinit.
                                    The modem starts attach after first lte.isattached() is called!
                                    It can be clearly verified when monitoring consumption with Otii Arc or similar tool.
                                      @xykon
                                      rtc.synced() continue to return false when rtc.ntp_sync("pool.ntp.org") sync the date&time. I'm using v1.20.0.rc3 built today from source:
                                      P 1 Reply Last reply Reply Quote -1
                                      • E Offline
                                        EinarJ @danielm
                                        Tried again with AT+CPSMS, but it seems to give me an error with the 1.20.0.rc2. On the first run, it works fine, but after waking up from a deep sleep it gives me an exception when calling the deinit() method:
                                        File "main.py", line 90, in <module>
                                        Pycom MicroPython 1.20.0.rc2 [v1.9.4-ecfa670] on 2018-12-17; GPy with ESP32
                                          danielm @EinarJ
                                          @einarj
                                          Which module are you using for testing? Can you successfully achieve desired deep-sleep current levels?
                                          E 2 Replies Last reply Reply Quote 0
                                          • E Offline
                                            EinarJ @danielm
                                            @danielm I'm using the GPy. The only way of achieving desired deep-sleep current levels is when i do a "lte.deinit(dettach=True)" and have the GPy alone without any expansion board or PySense/PyTrack
                                            • 5
                                            • 2 / 5
