    nb-iot on t-mobile in NL
    fipynb-iotconnect issuesconnectionconnect
    12 Posts 2 Posters 1.3k Views 2 Watching
      robert-hh @Eric Waai
      @eric-waai Did you update both the sequans firmware and the ESP32 firmware to the most recent version ?
      And also, the first attach may take very long time, like 20 minutes.
      • E Offline
        Eric Waai
        yes modem software is NB1-40343
        esp32 firmware is the last stable release 1.18.1.r7
        for now i waited over 1 hour without attach
          @eric-waai i 1hour is too long.
          what is the result of lte.send_at_command('At+CSQ') while waitung for is_attached()
          • E Offline
            Eric Waai
            AT+CSQ is usually around 23-25,99
            CREG gives (1,0)
            and CEREG also (1,0)
            which would indicate it is somewhat connected
            but CGATT gives 0
              @eric-waai CEREG1,0 means:
              enable network registration unsolicited result code (1) and
              not registered, MT is not currently searching an operator to register to (0)
              You should see something like CEREG 2,0 or CEREG 2,2 while searching.
              AT+CSQ result is good. It means, the device detects a strong signal.
              I'm testing with v1.20.0.rc3
              • E Offline
                Eric Waai
                according http://m2msupport.net/m2msupport/atcreg-network-registration/
                CREG 1,0
                means registered, home network
                on GSM
                i assumed that for CEREG it meant somewhat the same
                will try again tomorrow
                  @eric-waai As far as I understand it, the coding for CREG and CEREG is the same. The 0 means: not registered, not searching.
                  At my set-up, while waiting for attach, the result of AT+CEREG? is 2,2 most of the time and rarely 2,0
                  • E Offline
                    Eric Waai
                    still not getting anywhere
                    this is the result of showpy
                    DL SYNCHRO STATISTICS
                    Synchro state : DRX_SLEEP
                    PPU SIB1 ACQ watchdog : 0
                    Frequency Hypothesis RF (Hz) : 0
                    RSRP (dBm) : -82.24
                    RSRQ (dB) : -12.62
                    Channel estimation state (Cell-spec.) : LOW CINR
                    Channel estimation state (UE-spec.) : LOW CINR
                    Channel estimation state (MBSFN) : LOW CINR
                    Channel estimation CINR : 5.23
                    Channel length : SHORT
                    AGC
                    AGC RX gain (dB) : 42.57
                    RX PSD BO (dBFs) : -18.79
                    RX PSD (dBm) : -83.06
                    Noise level RS (dBm) : -87.31
                    Digital gain (dB) : 3.90
                    CINR RS (dB) : 5.07
                    NARROWBANDS
                    Last DL NB : Central
                    Last UL NB : 0
                    AFC
                    Frequency offset RF (Hz) : -447
                    Frequency offset BB (Hz) : 0
                    PBCH
                    MIB received quantity : 0
                    MIB timeout quantity : 0
                    if i send AT+COPS=1,2,"20416" (tmobile specific)
                    i get
                    +CEREG: 2
                    +CREG: 2
                    OK
                    +CGATT: 0
                    OK
                    +CEREG: 1,2
                    OK
                    +CFUN: 1
                    OK
                    OK
                    OK
                    +CGATT: 0
                    OK
                    +CEREG: 1,2
                    OK
                    +CFUN: 1
                    OK
                    OK
                    as return
                    if i later again send AT+C(E)REG
                    i get +CREG: 1,0
                    lte.isattached() is still false
                    but the statistics change
                    Synchro state : CELL_ACQUIRED
                    RSRP (dBm) : -82.88
                    RSRQ (dB) : -11.70
                    Channel estimation state (Cell-spec.) : HIGH CINR
                    Channel estimation CINR : 6.45
                    AGC
                    AGC RX gain (dB) : 42.49
                    RX PSD BO (dBFs) : -20.98
                    RX PSD (dBm) : -84.72
                    Noise level RS (dBm) : -89.38
                    Digital gain (dB) : 5.66
                    CINR RS (dB) : 6.50
                    NARROWBANDS
                    Last UL NB : 0
                    AFC
                    Frequency offset RF (Hz) : -452
                    PBCH
                      @eric-waai b.t.w.: which apn have you specified?
                      I found a link where some of that is discussed: https://forum.iot.t-mobile.nl/topic/25/nieuwe-settings-voor-nb-iot-hardware-en-api/11
                      • E Offline
                        Eric Waai
                        hmm i can try that settings
                        i used this settings
                        Frequency Range: Guard Band
                        Radio band: band 8, 900 Mhz
                        APN: cdp.iot.t-mobile.nl
                        PLMN ID: 20416
                        NCDP address for Neul Messaging (CoAP): 172.27.131.100 Port 5683
                        CDP address for UDP messaging: 172.27.131.100 Port 15683
                        Hostname for using the API: https://iot.netwerk.t-mobile.nl
                        Supported TLS certifications: TLS v1.1 and TLS v 1.2
                        as described here
                        https://docs.iot.t-mobile.nl/docs/general-settings
                          @eric-waai These settings should be fine then.
