    WiPy and DHT22 issue
    dht22wipy3.0
    12 Posts 3 Posters 1.5k Views 3 Watching
      robert-hh @brewnut
      @brewnut Try this code. It works well for me. It should be in micrpython-lib, but I did not find it. Do not ask me why the class is DTH instead of DHT
      from machine import Pin
      class DTHResult:
          'DHT sensor result returned by DHT.read() method'
          ERR_NO_ERROR = 0
          ERR_MISSING_DATA = 1
          ERR_CRC = 2
          error_code = ERR_NO_ERROR
          temperature = -1
          humidity = -1
          def __init__(self, error_code, temperature, humidity):
              self.error_code = error_code
              self.temperature = temperature
              self.humidity = humidity
          def is_valid(self):
              return self.error_code == DTHResult.ERR_NO_ERROR
      class DTH:
          'DHT sensor (dht11, dht21,dht22) reader class for Pycom'
          __dhttype = 0
          def __init__(self, pin, sensor=0):
              self.__pin = Pin(pin, mode=Pin.OPEN_DRAIN)
              self.__dhttype = sensor
              self.__pin(1)
              time.sleep(1.0)
          def read(self):
              # pull down to low
              self.__send_and_sleep(0, 0.019)
              data = pycom.pulses_get(self.__pin,100)
              self.__pin.init(Pin.OPEN_DRAIN)
              self.__pin(1)
              bits = []
              for a,b in data:
                      if a ==1 and 18 <= b <= 28:
                              bits.append(0)
                      if a ==1 and 65 <= b <= 75:
                              bits.append(1)
              if len(bits) != 40:
                  return DTHResult(DTHResult.ERR_MISSING_DATA, 0, 0)
              # we have the bits, calculate bytes
              the_bytes = self.__bits_to_bytes(bits)
              # calculate checksum and check
              checksum = self.__calculate_checksum(the_bytes)
              if the_bytes[4] != checksum:
                  return DTHResult(DTHResult.ERR_CRC, 0, 0)
              # ok, we have valid data, return it
              [int_rh, dec_rh, int_t, dec_t, csum] = the_bytes
              if self.__dhttype==0:           #dht11
                  rh = int_rh                 #dht11 20% ~ 90%
                  t = int_t   #dht11 0..50°C
              else:                   #dht21,dht22
                  rh = ((int_rh * 256) + dec_rh)/10
                  t = (((int_t & 0x7F) * 256) + dec_t)/10
                  if (int_t & 0x80) != 0:
                      t = -t
              return DTHResult(DTHResult.ERR_NO_ERROR, t, rh)
          def __send_and_sleep(self, output, mysleep):
              self.__pin(output)
              time.sleep(mysleep)
          def __bits_to_bytes(self, bits):
              the_bytes = []
              byte = 0
              for i in range(0, len(bits)):
                  byte <<= 1
                  if (bits[i]):
                      byte |= 1
                  if ((i % 8) == 7):
                      the_bytes.append(byte)
                      byte = 0
              return the_bytes
          def __calculate_checksum(self, the_bytes):
              return the_bytes[0] + the_bytes[1] + the_bytes[2] + the_bytes[3] & 255
      th = DTH(Pin('P8', mode=Pin.OPEN_DRAIN),1)
      def run():
          pycom.heartbeat(False)
          pycom.rgbled(0x000008) # blue
          time.sleep(0.5)
          result = th.read()
          if result.is_valid():
              pycom.rgbled(0x001000) # green
              print("Temperature: %.1f C" % result.temperature)
              print("Humidity: %.1f %%" % result.humidity)
      run()
        brewnut @robert-hh
        @robert-hh thanks for this. I have also tried running this code from Jurassic Pork and i get nothing at all when i run it.
        I have changed the pin to G22 so it matches my wiring for both sets of code.
        I will give the code from Daniel a go as well.
        This is the code from Jurassic Pork
        this is the DTH.py file
        from machine import enable_irq, disable_irq,  Pin
        class DTHResult:
            ERR_NO_ERROR = 0
            ERR_CRC = 2
            temperature = -1
            humidity = -1
            def is_valid(self):
        class DTH:
            __pin = Pin(Pin.exp_board.G22, mode=Pin.OPEN_DRAIN)
            print(__pin)
            __dhttype = 1
            def __init__(self, pin, sensor=1):
                self.__pin(1)
                time.sleep(1.0)
            def read(self):
                # pull down to low
                self.__pin(1)
                #print(data)
                bits = []
                for a,b in data:
                		bits.append(0)
                		bits.append(1)
                        #print("longueur bits : %d " % len(bits))
                if len(bits) != 40:
                #print(bits)
                else:			#dht21,dht22
                    if (int_t & 0x80) > 0:
                        t *= -1
                self.__pin(output)
                time.sleep(mysleep)
                the_bytes = []
                byte = 0
                    byte = byte << 1
                    if (bits[i]):
                        byte = byte | 1
                        byte = byte | 0
                    if ((i + 1) % 8 == 0):
                        byte = 0
                #print(the_bytes)
                return the_bytes
        this is the DHT22_example.py code
        from dth import DTH
        th = DTH(Pin.exp_board.G22,1)
        print(th)
        time.sleep(2)
        result = th.read()
        print(result)
            print('Temperature: {:3.2f}'.format(result.temperature/1.0))
            print('Humidity: {:3.2f}'.format(result.humidity/1.0))
        Running the DHT22_example code seems to stall somewhere after the LED changes to blue as it does not change to green. I presume this is because the result is not valid.
          brewnut
          Ok I have since added a one wire temp sensor to the board and got that working so have now come back to the dht22.
          I am still getting the zero pulses received error so will look to see how I go debugging. Any tips would be appreciated.
            robert-hh @brewnut
            @brewnut When you take the voltage at the data pin, it should be about 3.3V. Do you have to visualize the data signal, like with a logic analyzer or Oscilloscope?
              brewnut @robert-hh
              @robert-hh no sorry I don’t have an Oscilloscope. Anything else I can do with the code to troubleshoot eg print out results at certain steps to see where it is failing?
                robert-hh @brewnut
                  robert-hh @brewnut
                  @brewnut did you try to take my code example below and replace 'P8' by 'P12', which is your wiring?
                    brewnut @robert-hh
                    @robert-hh Hi Robert i have just tried your code replacing 'P8' with 'P11' (thats actually what the yellow jumper wire is plugged into).
                    Noting happens when running this.
                    I also tried replacing the __dhttype = 0 with = 1 as reading over the DTH code notes it mentions the DHT 11 sensor is type 0 and DHT 22 sensor is type 1.
                    Changing these settings also results in noting happening when running.
                    • FridaF Offline
                      Frida
                      If you want to use 'P11' (G22), try removing the 'RTS' jumper as it is connected to 'program port'.
                      See: https://docs.pycom.io/.gitbook/assets/wipy3-pinout.png
                        brewnut @Frida
                        @frida thanks for this suggestion, I will give a go and report back. Any particular reason the RTS jumper is linked to P11. Should I try a different pin instead and leave the RTS jumper in place?
                          robert-hh @brewnut
                          @brewnut The RTS pin is not used by the firmware, but driven by the UAB/UART bridge. But you can also use another pin, like P6.
