    Firmware release 1.0.1.b1
    28 Posts 9 Posters 8.9k Views 9 Watching
      TravisT @sakis
      @sakis
      Sorry, I was hoping this was a quick link check, not a download and actual test. I appreciate the time.
        sakis
        @TravisT
        No problem. I just tested it and it is the right version:
        (sysname='LoPy', nodename='LoPy', release='1.0.1.b1', version='v1.8.6-264-gadacebe on 2016-12-22', machine='LoPy with ESP32')
          TravisT @sakis
          @sakis
          Thank you sir!
            livius
            @daniel
            can you add to updater tool option to use files from dir not from internet?
            e.g.
            1. i can transfer all files to pendrive and go to computer without internet connection and update my board
            2. i can change something in source code and do custom make
              and need to flash it to the board
              previously i do this simple by replace files in "updater" folder and run updater tool
              DongYin
              @daniel
              I set my Lopy to WLAN.STA mode and connect it with the router, then i ping it's IP address on my computer successfully.
              But if there is a way i can ping the IP address of my computer on the Lopy.
              If and how i can save any data to the flash?
                livius @DongYin
                @DongYin said in Firmware release 1.0.1.b1:
                you can write files to the `\flash' folder without any problem
                  Ralph
                  @livius, before Daniel replies, let me add that (if you didn't know this already,) you can still update your board manually by placing the bin file in the /sys directory on the board itself using FTP, then rebooting the board. Your idea of making it an option in the updater would probably be better, but until that happens, you can do it this way.
                  Edit: This works even nicer:
                  make BOARD=LOPY ESPPORT=/dev/ttyUSB0 flash
                    livius @Ralph
                    @Ralph said in Firmware release 1.0.1.b1:
                    what this command flash do?
                    write e.g. appimg.bin or also partition.bin, bootloader.bin some other things like erase mem...
                    EDIT
                    this does not work for me - but i tested this tommorow only once at night
                    then maybe i do something wrong
                    when i do this and restart the board it do not run
                    i then reflash it with the updater tool once again
                    and flash board with command line to put my custom source code make
                    updater.py -f ......
                    but i must change script of updater.py and remove erase_sytem_mem steap
                    from some reason this steap time out
                    a little hint here 'erase_sytem_mem' have one letter typing error should be 'erase_system_mem' ;-)
                      Ralph
                      @livius it writes all three .bin files, but it doesn't erase anything else on the file system.
                        livius @Ralph
                        @Ralph
                        thank you for the explanation
                        one question here - why then updater tool do erase mem?
                        EDIT:
                        and for windows it is like this?
                        make BOARD=WIPY ESPPORT=COM6 flash
                          Ralph
                          @livius As I understand from my colleagues, the updater tool does the same as the flash command does: it only erases what it needs to, to write the firmware, partition and bootloader.
                          And yes that looks about right to me for windows. ESPPORT just needs to be the full comport.
                            livius @Ralph
                            @Ralph
                            ok - maybe this steap is unnesceserry at all it is used only if args.tar = None
                            in update.py is
                                def erase_sytem_mem(self):
                                    # Erase first 3.5Mb (this way fs and MAC address will be untouched)
                                    self.erase(0, 0x3100000)
                            i will use flash switch from make
                            thank you again
                              DongYin @livius
                              @livius said in Firmware release 1.0.1.b1:
                              Thank you! i used uos.mkdir("setting.ini") to write a file to '\flash', then how to write&read it by programs?
                                livius @DongYin
                                @DongYin
                                look at:
                                https://docs.python.org/3/tutorial/inputoutput.html
                                there are paragraphs about files
                                also look here
                                https://docs.pycom.io/pycom_esp32/library/uos.html
                                os.mkdir create directory
                                • 2 / 2
