    Firmware release 1.0.1.b1
    28 Posts 9 Posters 8.7k Views 9 Watching
      TravisT @sakis
      @sakis
      Thank you sir!
        livius
        @daniel
        can you add to updater tool option to use files from dir not from internet?
        e.g.
        1. i can transfer all files to pendrive and go to computer without internet connection and update my board
        2. i can change something in source code and do custom make
          and need to flash it to the board
          previously i do this simple by replace files in "updater" folder and run updater tool
          DongYin
          @daniel
          I set my Lopy to WLAN.STA mode and connect it with the router, then i ping it's IP address on my computer successfully.
          But if there is a way i can ping the IP address of my computer on the Lopy.
          If and how i can save any data to the flash?
            livius @DongYin
            @DongYin said in Firmware release 1.0.1.b1:
            you can write files to the `\flash' folder without any problem
              Ralph
              @livius, before Daniel replies, let me add that (if you didn't know this already,) you can still update your board manually by placing the bin file in the /sys directory on the board itself using FTP, then rebooting the board. Your idea of making it an option in the updater would probably be better, but until that happens, you can do it this way.
              Edit: This works even nicer:
              make BOARD=LOPY ESPPORT=/dev/ttyUSB0 flash
                livius @Ralph
                @Ralph said in Firmware release 1.0.1.b1:
                what this command flash do?
                write e.g. appimg.bin or also partition.bin, bootloader.bin some other things like erase mem...
                EDIT
                this does not work for me - but i tested this tommorow only once at night
                then maybe i do something wrong
                when i do this and restart the board it do not run
                i then reflash it with the updater tool once again
                and flash board with command line to put my custom source code make
                updater.py -f ......
                but i must change script of updater.py and remove erase_sytem_mem steap
                from some reason this steap time out
                a little hint here 'erase_sytem_mem' have one letter typing error should be 'erase_system_mem' ;-)
                  Ralph
                  @livius it writes all three .bin files, but it doesn't erase anything else on the file system.
                    livius @Ralph
                    @Ralph
                    thank you for the explanation
                    one question here - why then updater tool do erase mem?
                    EDIT:
                    and for windows it is like this?
                    make BOARD=WIPY ESPPORT=COM6 flash
                      Ralph
                      @livius As I understand from my colleagues, the updater tool does the same as the flash command does: it only erases what it needs to, to write the firmware, partition and bootloader.
                      And yes that looks about right to me for windows. ESPPORT just needs to be the full comport.
                        livius @Ralph
                        @Ralph
                        ok - maybe this steap is unnesceserry at all it is used only if args.tar = None
                        in update.py is
                            def erase_sytem_mem(self):
                                # Erase first 3.5Mb (this way fs and MAC address will be untouched)
                                self.erase(0, 0x3100000)
                        i will use flash switch from make
                        thank you again
                          DongYin @livius
                          @livius said in Firmware release 1.0.1.b1:
                          Thank you! i used uos.mkdir("setting.ini") to write a file to '\flash', then how to write&read it by programs?
                            livius @DongYin
                            @DongYin
                            look at:
                            https://docs.python.org/3/tutorial/inputoutput.html
                            there are paragraphs about files
                            also look here
                            https://docs.pycom.io/pycom_esp32/library/uos.html
                            os.mkdir create directory
                            • 2 / 2
