Gpy AWS IOT Mqtt
@pranithmichael I had no luck with the Pycom AWS library. I was finally able to get connected to MQTT using simple.py.
The certificates were a little tricky to figure out (i.e. which root CA cert to use). The certificates should be in PEM format (typically extensions of .crt, .key, and .pem are PEM formatted). The root CA certificate I used was RSA 2048 bit Root CA 1.
Here's my connect function. I hope this helps.
from simple import MQTTClient def mqttConnect(): global connection global state global mqtt wdt.feed() log('mqttConnect') while state != config.CONNECTED: try: gc.collect() state = config.CONNECTING log("connecting to mqtt") mqtt = MQTTClient(config.CLIENT_ID, server=config.AWS_HOST, port=config.AWS_PORT, keepalive=600, ssl=True, ssl_params={"certfile": config.AWS_CLIENT_CERT, "keyfile": config.AWS_PRIVATE_KEY, "ca_certs": config.AWS_ROOT_CA}) # if mqtt.connect(600): mqtt.connect() state = config.CONNECTED log('MQTT connection established!') except Exception as e: log(e) log('could not establish MQTT connection') time.sleep(10) continue log('end mqttConnect') -
This post is deleted! -
Thank you for having taken the time to reply @reidfo
I downloaded the Python SDK for Linux and OSx that AWS provides while creating a 'aws thing'. There is a start.sh script file that generates a root CA file. It matches the Root CA 1 certificate that you have pointed to.
I set the following of extensions: .crt for certificate file, .key for the private file and .pem for the RootCA file, but didnt have any luck connecting to AWS.
Global settings for the project on the ATOM IDE allows us to mention the type of files that can be uploaded on to the pycom module.
I tried including 'ca' files in order to upload rootCA.ca file but that didn't seem to work either.Just to be sure. The CLIENT_ID is the AWS thing name, AWS_HOST is my host location at xxsomethingxx.iot.us-east-2.amazonaws.com and AWS_PORT is 8883. right?
All the more confusing to me is the AWS example found in the documentation config.py , where CLIENT_ID and THING_NAME are mentioned as two separate entities.
@pranithmichael Did you try the AWS example from Pycom?
https://docs.pycom.io/tutorials/all/aws
After some guesswork which certificate is what and enabling the certificate upload in pymakr, it worked right away (Wipy). -
@pranithmichael said in Gpy AWS IOT Mqtt:
That is correct.
@martinnn Thank you for your reply.
I did try with the AWS example.
Can you please confirm the extensions of the certificate files that you have used?AWS_ROOT_CA = '/flash/cert/root-ca.pem' AWS_CLIENT_CERT = '/flash/cert/ab4XXXXb22-certificate.pem.crt' AWS_PRIVATE_KEY = '/flash/cert/ab4XXXXb22-private.pem.key'I included different file upload types in the global settings on the IDE, in order to try and execute the code with .ca, .crt extensions for the rootCA file.
The rootca file that I have used is the RSA 2048 file found here
This file also matches the root CA file that AWS IOT python SDK package generates during the creation of a AWS thing.In all cases (different extensions for the rootCA file) I get the following error on the window:
Socket create error: CA file not found Socket send error 128I cross checked on AWS, the AWS thing is linked with its respective policy and certificates and vice versa.
I invoke main_publish directly from boot.py:
from machine import UART import machine import os uart = UART(0, baudrate=115200) os.dupterm(uart) machine.main('main_publish.py')Im not sure whether this is the right thing to do. Must I compulsorily have a main.py and then invoke methods in main_publish.py?
@pranithmichael I am not a certificate guru, there are different certificate formats. I don't think the name or ending matters. Mine looks like this
-----BEGIN CERTIFICATE-----
MIIE0zCCA7ugAwIBAgIQGNrRniZ96LtKIVjNzGs7SjANBgkqhkiG9w0BAQUFADCB
...hnacRHr2lVz2XTIIM6RUthg/aFzyQkqFOFSDX9HoLPKsEdao7WNq
-----END CERTIFICATE-----
For starters, I didn't use a boot.py but renamed the main_publish.py to main.py.Are you sure you set the config.py correctly?
AWS_ROOT_CA = '/flash/cert/aws_root.ca'
AWS_CLIENT_CERT = '/flash/cert/xxx-certificate.pem.crt'
AWS_PRIVATE_KEY = '/flash/cert/xxx-private.pem.key''file not found' pretty much sounds like... the file is not there?
modules:composer.user_said_in, @martinnn, Gpy AWS IOT Mqtt
@PranithMichael Check your Pymakr settings as well. By default it only uploads certain file types to the board.
pymakr.conf
"sync_file_types": "py,txt,log,json,xml,html,js,css,mpy,pem,cet,crt,key", -
@reidfo said in Gpy AWS IOT Mqtt:
pymakr.conf
"sync_file_types": "py,txt,log,json,xml,html,js,css,mpy,pem,cet,crt,key",This would be my guess to. Give this a try. If your still having issues drop a message to support@pycom.io
I'm experiencing the same issues. I've checked using both the AWSIoTMQTTClient and the simple.py on the 1.18.2 firmware. For the simple.py solution I found that it was throwing this error:
Traceback (most recent call last): File "main.py", line 52, in <module> File "main.py", line 32, in run File "/flash/lib/simple.py", line 84, in connect IndexError: bytes index out of rangeIt looks like it's not getting a response from aws in the simple.py and attempting to read nothing on the socket.
resp = self.sock.read(4) assert resp[0] == 0x20 and resp[1] == 0x02I've verified using AWS's python SDK on my computer with the same certificates and mqtt topic. It's working as intended.
@randomrnti Figured out my issue was due to the AWS policy only allowing certain clients for the iot:Connect policy. Changing it to the wildcard * fixed my issue.
Another issue though is I can only get it working for Wifi. The moment I attempt this on NB-IoT I'm getting the following errors:
AWSIoTMQTTClient
Socket create error: [Errno -78] MBEDTLS_ERR_NET_SEND_FAILEDTraceback (most recent call last): File "main.py", line 90, in <module> File "main.py", line 79, in run File "/flash/lib/simple.py", line 56, in connect OSError: [Errno 113] ECONNABORTEDThis again is on the connect action and I've tried with connecting using both the IP Address and it's domain name.
