    Pymesh updates
    loraenhancementpymesh
    73 Posts 13 Posters 14.1k Views 18 Watching
      Jordan Reyes @catalin
      @catalin Awesome when do you think stable version to be released?
      • catalinC Offline
        catalin @Jordan Reyes
        Hi @jordan-reyes, announcing a stable release with Pymesh included, it's not a matter of Pymesh being not stable. There are some other features/improvements that need to be tested in whole firmware. Sorry, I don't know more details, probably the bugs/requests were raised on forum :)
        Some new Pymesh features were just released internally (so they will be incorporated in the next RC, probably this Friday) plus some example scripting for Border Router:
        • added socket binding to IP, add listing border_router
        • BUG: src and dest port on BR should he Host Swapped
        • Mesh.rx_cb() added argument, with the callback
        • added Mesh.border_router_del(prefix) method, for erasing Border Router entry
        • added multi-socckets (max 3)
        • added Border Router socket with header IP and port destination
          I did not forgot, we'll open-source some Pygo example scripts, as promised. I need to update/test for the new release.
        Plus, working on some Pymesh Roadmap...
        Catalin,
        • catalinC Offline
          catalin
          Hello everyone,
          In the release 1.20.0.rc8 the Pymesh was updated, please check https://forum.pycom.io/topic/4499/firmware-release-candidate-v1-20-0-rc8
          As usual, let me know what's not clear, the Border Router example a bit too simple.
          Catalin,
          T J 2 Replies Last reply Reply Quote 1
            thinginnovations @catalin
            @catalin ooo, interesting. Thanks for the update.
            Andrew
              @catalin had a lot of issues with 1.20.0.rc7 almost all nodes were corrupted with guru meditation error on lora.mesh. the mesh seemed to be the issue, The error did not seem to be on previous versions, (although it wasn't run very long on previous version prior to update), I am hoping with rc8 this problem is fixed....
              • catalinC Offline
                Hi Jordan,
                Yes, please try the RC8 release, I did not had any issue with RC7, either.
                Now I am running the Pymesh with ~30 micropython scripts (sending data to the Cloud, using Wifi and BLE), also creating Pymesh with 20+ nodes(lopy4 and Fipy), no Error found.
                Catalin,
                  @catalin with both deployed is orignial lopy, not lopy4 would this be any difference with about 12 nodes. it was running for a bit and then would crash, but we weren't getting stable communication either, some were more consistent then others.
                    @catalin deployed rc8 upon boot up nodes hit (outside With Line of sight ) and they are suppose to respond every ten seconds, some responsive more than others but after some time they do not send data anymore. Sometimes it lasts an hour sometimes a day but it is not reliable. What is environment you are running your set upon. We are covering about 2.25-2.5 km.
                    • catalinC Offline
                      @jordan-reyes I did not properly tested Pymesh on Lopy1, mainly because the scripts that I use, occupy lots of RAM.
                      What LoRa params are you using, spreading-factor, bandwidth? I would start tests with fastest datarate (SF7, BW 250). Are you printing the RSSI values, if they are at the border (for that SF, for ex: lower than -115), there could be corrupted packets, that Node could exit/re-enter the Mesh.
                      10 seconds is a small waiting time; Mesh internally sends, every 32 seconds, sends a keepalive between each pair of neighbours (last communication is in the age field from Mesh.neighbors() and Mesh.routers()).
                      Catalin,
                        @catalin SF is 7, Bandwidth is 125. The RssI values were not being printed.
                        • catalinC Offline
                          catalin
                          Hi community 🙌,
                          I've been busy lately making Pymesh application protocol more robust ⚙.
                          I've just released a relatively large 🐘 micropy project using Pymesh: https://github.com/pycom/pycom-libraries/tree/master/lib/pymesh
                          It was tested on a 20+ Mesh network on Lopy4 and Fipy (sorry Lopy1 can't work with these scripts, due to scripts size and RAM requirements).
                          I am really waiting for your comments and PRs, I foresee tons of improvements 🤓.
                          Heads-up, I am working on a visual tool, like a Pymesh viewer to actually click buttons and follow Pymesh evolution. Most probably connecting Pymesh to Pybytes 🌥.
                          Catalin,
                          • catalinC Offline
                            catalin
                            Just a small note, the v1.20.0.rc8 for Fipy and Pybytes scripts doesn't have Mesh class inside LoRa (so no Pymesh feature included).
                            Due to an error, Pymesh was excluded on Lopy4 rc8 builds, too; this is about to be fixed as I speak.
                            Catalin,
                              rfinkers @catalin
                              @catalin said in Pymesh updates:
                              Does it work on the L01? It has the same amount of RAM and flash as the Lopy4.
                              • catalinC Offline
                                catalin @rfinkers
                                @rfinkers yes, it should work fine with L01, due to increased RAM+Flash.
                                Catalin,
                                • catalinC Offline
                                  catalin
                                  Hi community,
                                  I've released a beta version of the Pymesh mobile app:
                                  • iOS(>v12.1, TestFlight app from Apple is required): https://testflight.apple.com/join/PIxwbTKp
                                  • Android(>v4.4): https://github.com/pycom/pymesh_apps/tree/master/mobile_app/android
                                  In this repo there are firmware binaries (but latest development should work too), and micropy scripts (but https://github.com/pycom/pycom-libraries/tree/master/lib/pymesh should be also fine).
                                  Catalin,
                                    ricardolima
                                    Any news about pymesh ? Any example how the border router can connect to the internet and provide it to the rest of the network ?
                                    • catalinC Offline
                                      catalin @ricardolima
                                      Hi @ricardolima,
                                      Here is the example of the Border Router: https://docs.pycom.io/tutorials/lora/pymesh-br/, more precisely at this line rcv_data contains the info to be sent to Internet.
                                      In class WLAN and socket you can see how to send data on Wifi.
                                      Similar examples are on NBIoT/CatM1/BLE/Sigfox/LoRaWAN.
                                      Does this answers your question?
                                      On a side note, I am working on some micropython scripts on which any Pymesh node can connect to Pybytes, if connection is done then they declared itself as Border Router, the other nodes see they have a BR in network (as a new IPv6 appears on them). Probably I'll release these in the next couple of weeks.
                                      Also, a separate Pymesh firmware binary release will be done next week (separate from already existing flavours development/stable/pybytes).
                                      Catalin,
                                        ricardolima @catalin
                                        @catalin Thank you for your quick answer. I will wait a bit to see what that news firmwares brings :D
                                        • catalinC Offline
                                          Small update, the Pymesh iOS app was rebuilt, and it's available again in TestFlight, using the same link: https://testflight.apple.com/join/PIxwbTKp
                                          The Pymesh Android app is in this repo.
                                          Also builds with Pymesh included are here, the binaries include micropython scripts.
                                          Catalin,
                                            robert-hh @catalin
                                            @catalin So I installed these images https://github.com/pycom/pymesh_apps/tree/master/custom_fw_bin on two LoPy4's and a FiPy. They run, see each other, declare themselves as leader, router, and child, and have chats. But what else? Are these sample images good for anything beyond that?
                                            And yes: they all seem to have a fixed location in Eindhoven. Using a pytrack does not change that.
                                            • 1 / 4
