    Has anyone successfully used lora.nvram_save() and restore?
    lopyloranvram
    17 Posts 7 Posters 5.1k Views 9 Watching
      jalperin @jmarcelino
      @jmarcelino
      Restoring the channel configuration did the trick. Setblocking(True) was not needed here.
      An anomaly that I have seen before showed up. The packets sent after nvram_restore all arrived with "payload not provided". But, if I first send a packet with a payload of a single character, it and all subsequent packets arrive successfully.
      May I suggest that the documentation be amended to detail what is and is not saved by lora.nvram_save().
      Thank you very much for your help.
        johncaipa @jalperin
        @jalperin @jmarcelino works but the counter is restarted on each send, this value is not stored?
        • bmarkusB Offline
          bmarkus @johncaipa
          @johncaipa said in Has anyone successfully used lora.nvram_save() and restore?:
          Unfortunately it is not possible to get or set your own FCnt value, otherwise it would be possible to handle in your code. Just one of the several missing LoRa/LoRaWAN functions.
            johncaipa @bmarkus
            @bmarkus in the documentation says that this value is saved, then I do not know what would be the problem, because in each sending after waking up the packet counters is always in 1 on TTN.
            "lora.nvram_save()
            Save the LoRaWAN state (joined status, network keys, packet counters, etc) in non-volatile memory in order to be able to restore the state when coming out of deepsleep or a power cycle."
            • bmarkusB Offline
              bmarkus @johncaipa
              "lora.nvram_save()
              Do you create a new instance when coming out? It resets the counter.
                johncaipa @bmarkus
                @bmarkus this is the example code I'm testing, based on which share @jalperin, I'm missing something?
                from network import LoRa
                import struct
                import binascii
                import math
                from pysense import Pysense
                py = Pysense()
                loraSaved = pycom.nvs_get('loraSaved')
                print(loraSaved)
                if not loraSaved:
                freq = 902300000
                for channel in range(0, 72):
                lora.remove_channel(channel)
                for chan in range(0, 8):
                lora.add_channel(chan, frequency=freq, dr_min=0, dr_max=3)
                dev_addr = struct.unpack(">l", binascii.unhexlify('************'.replace(' ','')))[0]
                nwk_swkey = binascii.unhexlify('************ 89 F1 74 79 40'.replace(' ',''))
                app_swkey = binascii.unhexlify('************ 3A AA BD E8 A9'.replace(' ',''))
                lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey))
                while not lora.has_joined():
                    machine.idle()
                s.bind(3) #select the port number
                s.setblocking(False)
                s.send('LoRa Up')
                time.sleep(2)
                lora.nvram_save()
                pycom.nvs_set('loraSaved', 1)
                py.setup_sleep(60)
                py.go_to_sleep()
                lora.nvram_restore()
                freq = 902300000
                s.send('LoRa Restored')
                time.sleep(2)
                lora.nvram_save()
                #pycom.nvs_set('loraSaved', 0) # reset for next test
                py.setup_sleep(60)
                py.go_to_sleep()
                  rloro338
                  I am trying to use lora.nvram_save() and lora.nvram_restore() and not works. I set all parameters (LoRaWAN, adr = True, app_eui, app_key and channel configuration) the first time that I boot the device and send a message Loriot server receive it. Then device go to deepsleep for 5 seconds and restore the join state. If I look the state with lora.has_joined() return True value, but when I trying to send the message it isn't received by the gateway.
                  It is curious because when I use the node directly with a command line in Putty the restore and save comands works fine.
                  What I am doing wrong??
                    johncaipa @rloro338
                    @rloro338 I made the following changes to my code and now it works correctly:
                    • list item make sure the socket is blocking ( s.setblocking(True) )
                    • list item add a time.sleep(2) after sending, before saving and going to deep sleep.
                      Bismarck501 @jmarcelino
                      @jmarcelino Hello, I have read your suggestion carefully and tried in my project. But there was some issues about this solution.
                      My device consists of FiPy+pysense, and I connected to TTN via OTAA. My code with lora,nvram_save() and restore() is:
                      # pysense sensor part
                      from LTR329ALS01 import LTR329ALS01
                      from LIS2HH12 import LIS2HH12
                      # FiPy part
                      import ubinascii
                      # pysense machine part
                      from machine import RTC
                      from machine import SD
                      from network import WLAN, Bluetooth,LTE
                      # set parameters for sensor function
                      py = Pysense()
                      lt = LTR329ALS01(py)  # only use light sensor
                      loraSaved = pycom.nvs_get('loraSaved')  # if join already, it is int 3; or it will be None
                      #-------------------------------- if already join -------------------------------------#
                      if (loraSaved == 11):
                          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
                          #--------- Remove default channels ----------#
                          for index in range(0, 15):
                              lora.remove_channel(index)
                          lora.add_channel(3, frequency=867100000, dr_min=0, dr_max=5)
                          lora.add_channel(4, frequency=867300000, dr_min=0, dr_max=5)
                          lora.add_channel(5, frequency=867500000, dr_min=0, dr_max=5)
                          lora.add_channel(6, frequency=867700000, dr_min=0, dr_max=5)
                          lora.add_channel(7, frequency=867900000, dr_min=0, dr_max=5)
                          lora.add_channel(8, frequency=868100000, dr_min=0, dr_max=5)
                          lora.add_channel(9, frequency=868300000, dr_min=0, dr_max=5)
                          lora.add_channel(10, frequency=868500000, dr_min=0, dr_max=5)
                          lora.add_channel(11, frequency=868700000, dr_min=0, dr_max=5)
                          lora.add_channel(12, frequency=868900000, dr_min=0, dr_max=5)
                          lora.add_channel(13, frequency=869100000, dr_min=0, dr_max=5)
                          lora.add_channel(14, frequency=869300000, dr_min=0, dr_max=5)
                          lora.add_channel(15, frequency=869500000, dr_min=0, dr_max=5)
                          print("Join already")
                          #						Set LoRa parameters
                          # create a LoRa socket
                          # set the LoRaWAN data rate
                          #---------- Send uplink & Stroe uplink data ----------------#
                          uplink_payload = ("Light: " + str(lt.light()))
                          s.setblocking(True)
                          s.send(uplink_payload)
                          lora.nvram_save()
                          print("send finish")
                          #--------- Receive downlink & Stroe downlink data ----------#
                          downlink_message = s.recv(64) # bytes form     and     n is typically < 64 bytes
                          time.sleep(1)
                          print(downlink_message)
                          print(type(downlink_message))
                          print("Receive finish")
                          #----------- Jugde whether there is a downlink -------------#
                          if downlink_message == b'':
                              print("There is no downlink")
                              downlink_payload = downlink_message.decode('ascii') # string form
                              print("Downlink message: " + downlink_payload)
                              #-------- Judge downlink message & operate -------------#
                              if downlink_message == b'2': # if ==2, it will light green for 5 seconds
                                  print("Hi, Green!")
                                  time.sleep(3)
                              if downlink_message == b'4': # if ==4, it will light yellow for 5 seconds
                                  print("Hi, Yellow!")
                                  pycom.rgbled(0x7f7f00) # yellow
                                  time.sleep(3)
                          print("####################################")
                          print("\n")
                      #-------------------------------- if never join before -------------------------------------#
                          print("Firstly join")
                          # 					Initialise LoRa in LORAWAN mode.
                          #				Set OTAA mode and connect with the gateway
                          # create an OTAA authentication parameters
                          app_eui = ubinascii.unhexlify('70B3D57ED0013E78')
                          app_key = ubinascii.unhexlify('5D87FAB0BC66A45FB0DA07453ED2BC2B')
                          # join a network using OTAA (Over the Air Activation)
                              time.sleep(2.5)
                              print('Not yet joined...')
                          # join in
                          print('Successfully join in!')
                          s.setblocking(True)
                          lora.nvram_save()
                          #time.sleep(1)
                                  print("Hi, Green!")
                                  time.sleep(3)
                                  time.sleep(3)
                          print("\n")
                          #---------- store in flush to judge next time ----------------#
                          pycom.nvs_set('loraSaved', 11)
                      # time sleep
                      py.setup_sleep(9)   # setup a 9 seconds sleep time
                      py.go_to_sleep()
                      And it can work well. However, after one day, when I tried again, there would be an issue when running code at line 65:
                      Where I was wrong? Thanks for giving me some advice!
                        jcaron @Bismarck501
                        @Bismarck501 You should factorise your code a lot, it would make things a lot easier to maintain.
                        You shouldn't rely on an additional NVRAM variable to determine your LoRaWAN state.
                        Instead, just call nvram_restore, then has_joined. If not true, you need to join. Otherwise, you can go ahead and send/receive.
                        Also, I would call nvram_save after any interaction with the LoRaWAN stack is finished including the recv part. Not sure it currently causes any issues, but it's better to be consistent.
                        B 2 Replies Last reply Reply Quote 0
                          Bismarck501 @jcaron
                          @jcaron Thanks for responsing so quick! I have tried your suggestion and it works now. And I will experiment further to eusure the stability. Now the code is:
                          # FiPy part
                          import ubinascii
                          py = Pysense()
                          lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)   # itialise LoRa in LORAWAN mode.
                          if not lora.has_joined():
                              #-------------------- use OTAA to connect with TTN ------------------------------#
                              lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) # join a network using OTAA (Over the Air Activation)
                              while not lora.has_joined():    # wait until the module has joined the network
                                  time.sleep(2.5)
                              # join in
                              #---------- Set LoRa parameters ----------------#
                              s.setblocking(True)
                              #time.sleep(1)
                              lora.nvram_save()   # store in flush to judge next time
                                      print("Hi, Green!")
                                      pycom.heartbeat(False)
                                      time.sleep(3)
                                      pycom.heartbeat(True)
                                      time.sleep(3)
                              print("\n")
                              #---------------------------Set LoRa parameters-------------------------------------#
                              s.setblocking(True)
                              time.sleep(1)
                              lora.nvram_save()
                                      print("Hi, Green!")
                                      time.sleep(3)
                                      time.sleep(3)
                              print("\n")
                          print("Deep sleep begin!")
                          # time sleep
                          py.setup_sleep(9)   # setup a 10 seconds sleep time
                          py.go_to_sleep()
                          #machine.deepsleep(9000)  # machine.deepsleep([milli_sec])
                          Thanks a lot!
                            Bismarck501 @jcaron
                            @jcaron The issue has been worked out and it works quite well now! Thanks a lot!
