    Need Help to connect NB-IOT 1nce / Germany
    5 Posts 4 Posters 538 Views 4 Watching
      svonbentzel
      Hello togehther, I need help.
      I have multiple FiPy Boards with and without expansion board try´d.
      I have used two 1nce SIM-Cards. The cards working good. and its a NB-IOT Contract.
      FiPy Rev. 1.2 RMA from Pycom
      Modem Firmware is already updated to DUP NB1-41019
      LTE-Antenna is connected
      SIM-Card is correctly plugged in.
      i have try multiple NB-IOT connection Scripts. no ones run.
      i have running the script multiple hours inside and outside of the House.
      any Ideas and Hints?
      Sysname: FiPy
      Release: 1.18.2.r3
      Version: v1.8.6-849-a1641ca on 2019-02-28
      Machine: FiPy with ESP32
      Query LTE modem imei... 35434**********
      Query SIM iccid... 89882***************
      Sent to modem: 'ATI1', delay 1000 ms
      UE6.0.0.0
      LR6.0.0.0-41019
      OK
      Sent to modem: 'AT!="showver"', delay 1000 ms
      SYSTEM VERSION
        FIRMWARE VERSION
          Bootloader0  : 5.1.1.0 [39529]
          Bootloader1* : 6.0.0.0 [41019]
          Bootloader2  : NA
          NV Info      : 1.1,0,0
          Software     : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15
          UE           : 6.0.0.0
        COMPONENTS
          ZSP0         : 1.0.99-3171
          ZSP1         : 1.0.98-3170
      OK
      Sent to modem: 'AT!="RRC:setDbgPerm full"', delay 1000 ms
      OK
      Sent to modem: 'AT!="RRC:showcaps"', delay 1000 ms
      == CAPS config =============================
        .Lock UE on SRV band    : false
        .MFBI support           : true
        .TM8 TDD support        : false
      == CAPS ====================================
        . access stratum: R13
        . catM          : 1
        . nb-IoT        : 1
      -- EUTRA bands --
        . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
        . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
        . admin         :
        . pending admin :
      -- EUTRA carriers --
        . admin         :
        . pending admin :
      OK```
      • E Offline
        Elizar @svonbentzel
        @svonbentzel Did you setup the AP?
        Something like 'AT+CGDCONT=1,"IP","internet.nbiot.telekom.de"' ?
          svonbentzel @Elizar
          @Elizar Hello, Yes I think ;)
          from network import LTE
          lte = LTE()
          lte.attach(band=8, apn="iot.1nce.net")
          while not lte.isattached():
              time.sleep(0.5)
              print(".", end="")
          print("\nAttached!")
          print(lte.send_at_cmd("AT+CSQ"))
          lte.connect()       # start a data session and obtain an IP address
          while not lte.isconnected():
              time.sleep(0.5)
              print("-", end="")
          print("Connected!")
          Second Script:
          import usocket
          def send_at_cmd_pretty(cmd, delay=1000):
              response = lte.send_at_cmd(cmd, delay=delay).split('\r\n')
              print('Sent to modem: \'{}\', delay {} ms'.format(cmd, delay))
              for line in response:
                  if line.strip() != '':
                      print(line)
          # Print module details
          un = os.uname()
          print('Sysname:', un.sysname)
          print('Release:', un.release)
          print('Version:', un.version)
          print('Machine:', un.machine)
          # Initialize LTE object
          lte = LTE()
          time.sleep(5)
          # Pre attaching debugging
          print('Query LTE modem imei...', lte.imei()[:5] + '*' * 10)
          print('Query SIM iccid...', lte.iccid()[:5] + '*' * 15)
          send_at_cmd_pretty('ATI1')
          send_at_cmd_pretty('AT!="showver"')
          send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
          send_at_cmd_pretty('AT!="RRC:showcaps"')
          time.sleep(5)
          send_at_cmd_pretty('AT+SQNCTM?')
          # Attach LTE
          print('LTE attaching...')
          attempts = 0
              time.sleep(5)
              attempts = attempts + 1
              print('Attaching...', attempts)
              if attempts % 15 == 0:
                  send_at_cmd_pretty('AT+SQNMONI=9')
                  send_at_cmd_pretty('AT+CEREG?')
                  send_at_cmd_pretty('AT+CFUN?')
                  send_at_cmd_pretty('AT+CSQ')
                  send_at_cmd_pretty('AT!="showphy"')
                  send_at_cmd_pretty('AT!="fsm"')
          print('LTE attach succeeded!')
          # Debug attached state
          send_at_cmd_pretty('AT+CGPADDR')
          send_at_cmd_pretty('AT+PING="8.8.8.8"', delay=5000)
          # Connect LTE
          lte.connect()
          attempts = 0
              time.sleep(5)
              print('Connecting...', attempts)
          print('LTE connection succeeded!')
          # Test DNS
          try:
              usocket.dnsserver(0, '8.8.8.8')
              usocket.dnsserver(1, '1.1.1.1')
              usocket.dnsserver()
              print(usocket.getaddrinfo('www.google.com', 80)[0][-1])
          except Exception:
              print('DNS over NB-IoT failed...')
          # Shutdown LTE
          print("Disonnecting LTE ... ")
          lte.disconnect()
          print("Detaching LTE ... ")
          lte.dettach()
          print("Shuttting down LTE...")
          lte.deinit()
          robert-hhR V 2 Replies Last reply Reply Quote 0
            robert-hh @svonbentzel
            @svonbentzel The first script is the one I uss too for testing and it works. Only I have a different firmware version:
            Pycom MicroPython 1.20.0.rc10 [3911a85-dirty] on 2019-04-17; FiPy with ESP32
            Edit: updated to:
            Pycom MicroPython 1.20.0.rc11 [55accd1-dirty] on 2019-05-24; FiPy with ESP32, same good state.
            • V Offline
              v2h @svonbentzel
