    Using PyCom boards with Arduino IDE
    arduinofipy
    19 Posts 11 Posters 6.6k Views 15 Watching
    • VolodymyrV Offline
      Volodymyr @jmarcelino
      @jmarcelino Thx. Updated my post to reflect this.
        Lonefish
        I'm not sure if topicstarter is still on Pycom, but I can't seem to get this to work. The first example doesn't build because of the FastLED library, but I can make it a hello world that just prints over serial.
        So the arduino part works. I do have a problem communicating with the LTE modem tho, as in, it doesn't reply at all. Did something change in firmware on the fipy/modem/...?
          gouach
          thanks @Volodymyr for you post, i'm trying to see if i can use lopy4 with the arduino ide (or platformio) and i wonder where to find the doc or the code to run sigfox functions in cpp. Can you give me a hint ?
            mattt
            Has anyone had success with this? When running the above code, I get an "OK" in response to "AT" but every other code that I've tried results in an "ERROR" response from the modem.
              Lonefish @mattt
              @mattt I never even had an OK back. Did you use the exact same code?
              M 2 Replies Last reply Reply Quote 0
                mattt @Lonefish
                @Lonefish I tried using that code and the code in this pull request against the TinyGSM library, same result. Almost like the modem is locked until it receives a certain command.
                  mattt @Lonefish
                  I did have to add #define SerialAT Serial2
                  @Lonefish said in Using PyCom boards with Arduino IDE:
                    BorbonJuggler
                    Have anyone managed to do it with a Gpy ?, I have been trying without success
                    I am defining the UART pins as :
                    #define LTE_TX    23
                    #define LTE_RTS   18
                    #define LTE_RX    5
                    #define LTE_CTS   19
                      Lonefish @mattt
                      @mattt said in Using PyCom boards with Arduino IDE:
                      That seemed to work indeed! Sending AT+CSQ replied with 99,99 which is no connection. Haven't tried it any further, but it's more than I had a few months ago ;) Thanks!
                      EDIT : There was no antenna connected nor was there a SIM inserted, so the 99,99 is logical.
                      VolodymyrV 1 Reply Last reply Reply Quote 0
                        Volodymyr @Lonefish
                        @Lonefish I'm wondering if you got this working ;)
                        I have updated the OP use the Serial2.
                          Lonefish @Volodymyr
                          @Volodymyr I'm restarting my efforts to get this working again. Have been jumping from POC to POC. But we're switching to esp-idf instead of Arduino. Although, once it's working in esp-idf, it'd be an easy port to arduino back probably.
                          ATM I'm still at the "having communication" part, no actual internet connection yet, but just started working on it again.
                            Lonefish
                            I'm using this library at the moment, I can attach and connect to the network, but my efforts fail when I want to do some actual calls to servers. I don't seem to have http-traffic:
                            https://github.com/vshymanskyy/TinyGSM
                            J K 2 Replies Last reply Reply Quote 0
                              JFarque @Lonefish
                              @Lonefish Ever get TinyGSM working? I need to sent CoAP UDP messages with it. I've used TinyGSM with other Arduino computers on standard ublox cell modules but new to narrow band.
                              • K Offline
                                Kinnay21 @Lonefish
                                @Lonefish
                                Hello, did you finally able to use TinyGSM with FiPy or GPy in order to call servers?
                                  Clemens
                                  Would be also interested to use FiPy or GPy with TinyGSM for Arduino
                                    pottendo pottendo @Clemens
                                    @Clemens said in Using PyCom boards with Arduino IDE:
                                    hi, you may look here: https://github.com/vshymanskyy/TinyGSM/issues/579
                                    bye, pottendo
                                      Jeroen Jager
                                      I'm getting this error whenever I try to compile anything for the GPy:
                                      [15975] Error loading Python lib '/var/folders/57/hyd6ntr1233_x_brscxdp8480000gn/T/_MEI7xbrkg/libpython3.8.dylib': dlopen: dlopen(/var/folders/57/hyd6ntr1233_x_brscxdp8480000gn/T/_MEI7xbrkg/libpython3.8.dylib, 10): Symbol not found: ____chkstk_darwin
                                        Referenced from: /var/folders/57/hyd6ntr1233_x_brscxdp8480000gn/T/_MEI7xbrkg/libintl.8.dylib
                                        Expected in: /usr/lib/libSystem.B.dylib
                                       in /var/folders/57/hyd6ntr1233_x_brscxdp8480000gn/T/_MEI7xbrkg/libintl.8.dylib
                                      I have just re-installed Python 3.9.
                                      Anyone know how to fix this?
