    Pymesh updates
    loraenhancementpymesh
    73 Posts 13 Posters 12.8k Views 18 Watching
    • catalinC Offline
      catalin
      Hi community,
      I've released a beta version of the Pymesh mobile app:
      • iOS(>v12.1, TestFlight app from Apple is required): https://testflight.apple.com/join/PIxwbTKp
      • Android(>v4.4): https://github.com/pycom/pymesh_apps/tree/master/mobile_app/android
      In this repo there are firmware binaries (but latest development should work too), and micropy scripts (but https://github.com/pycom/pycom-libraries/tree/master/lib/pymesh should be also fine).
      Catalin,
        ricardolima
        Any news about pymesh ? Any example how the border router can connect to the internet and provide it to the rest of the network ?
        • catalinC Offline
          catalin @ricardolima
          Hi @ricardolima,
          Here is the example of the Border Router: https://docs.pycom.io/tutorials/lora/pymesh-br/, more precisely at this line rcv_data contains the info to be sent to Internet.
          In class WLAN and socket you can see how to send data on Wifi.
          Similar examples are on NBIoT/CatM1/BLE/Sigfox/LoRaWAN.
          Does this answers your question?
          On a side note, I am working on some micropython scripts on which any Pymesh node can connect to Pybytes, if connection is done then they declared itself as Border Router, the other nodes see they have a BR in network (as a new IPv6 appears on them). Probably I'll release these in the next couple of weeks.
          Also, a separate Pymesh firmware binary release will be done next week (separate from already existing flavours development/stable/pybytes).
          Catalin,
            ricardolima @catalin
            @catalin Thank you for your quick answer. I will wait a bit to see what that news firmwares brings :D
            • catalinC Offline
              Small update, the Pymesh iOS app was rebuilt, and it's available again in TestFlight, using the same link: https://testflight.apple.com/join/PIxwbTKp
              The Pymesh Android app is in this repo.
              Also builds with Pymesh included are here, the binaries include micropython scripts.
              Catalin,
                robert-hh @catalin
                @catalin So I installed these images https://github.com/pycom/pymesh_apps/tree/master/custom_fw_bin on two LoPy4's and a FiPy. They run, see each other, declare themselves as leader, router, and child, and have chats. But what else? Are these sample images good for anything beyond that?
                And yes: they all seem to have a fixed location in Eindhoven. Using a pytrack does not change that.
                • catalinC Offline
                  catalin @robert-hh
                  hi @robert-hh,
                  I think, there is the flow of sending pictures across Pymesh also implemented; by sending message dog a 12KB picture of a dog is sent.
                  More features are to come:
                  • binary release with Pymesh flavour
                  • having included frozen scripts, so a mesh can be started using 3-4 lines of micropython
                  • any node can be declared as Border Router and it can be connected to Pybytes, or other IoT platform
                  • any node accepts BLE connections, so using Pymesh mobile app, one can see diagnostics info within the Mesh.
                  And, of course, we're waiting for more suggestions on Pymesh wishlist.
                  Catalin,
                    robert-hh @catalin
                    @catalin My question was more, what to do with the actual pymesh firmware images you pubished. They run and connect, but I see no path to use it for other purposes. There is a single > prompt. If I push Ctrl-D at it, I get the message:
                    Unhandled exception in thread started by <bound_method>
                      File "cli.py", line 36, in process
                    EOFError:
                    So there is a function cli.py, which seems to wait for commands. But which one?
                      robert-hh @catalin
                      @catalin Onother issue:
                      I had one LoPy4 with your pymesh image running over night. This morning it was in a reboot loop with messages like these:
                      Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
                      Core 0 register dump:
                      PC      : 0x400966f0  PS      : 0x00060033  A0      : 0x80094c5a  A1      : 0x3ffc09c0
                      A2      : 0x3ffc1910  A3      : 0x00000000  A4      : 0x3ffc56f4  A5      : 0x000005ab
                      A6      : 0x3ffc5914  A7      : 0x00000000  A8      : 0x3ffe3964  A9      : 0x3ffc0990
                      A10     : 0x00000001  A11     : 0x00060021  A12     : 0x3ffdc468  A13     : 0x00000001
                      A14     : 0x000000fe  A15     : 0x00060023  SAR     : 0x0000001f  EXCCAUSE: 0x0000001c
                      EXCVADDR: 0x00000008  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
                      Core 0 was running in ISR context:
                      EPC1    : 0x400966f0  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x4008b8b4
                      Backtrace: 0x400966f0:0x3ffc09c0 0x40094c57:0x3ffc09e0 0x40097675:0x3ffc0a00 0x40083b16:0x3ffc0a10 0x40201af3:0x3ffdc3b0 0x400965b5:0x3ffdc3d0
                      No clue what happened. Re-flashing it brought it back to normal operation. This is new, because normally these devices are very reliable.
                      • catalinC Offline
                        catalin @robert-hh
                        @robert-hh, the micropython scripts which are frozen in those binaries is in the same repo: https://github.com/pycom/pymesh_apps/tree/master/pymesh_micropy_scripts
                        The cli commands can be seen in the code, sorry for not having then documented:
                        https://github.com/pycom/pymesh_apps/blob/0063271c910c78d0d4832286494eb49f96242eca/pymesh_micropy_scripts/lib/cli.py#L43
                        Nicer is to install the Android or iOS mobile app(link opened by TestFlight mobile app).
                        Regarding the crush, I've pushed the memory heap usage to the max in those binaries, this is solved by the newest IDF_v3.2 from development.
                        Catalin,
                          robert-hh @catalin
                          @catalin OK. Thanks. It looks like the LoPy4 devices crash all the time. The FiPy seems stable.
                            robert-hh @catalin
                            @catalin Two things about the crashes: as long as I have at least two devices in the local mesh, it seems stable. Having just one device running causes a crash each time after a few minutes. Normally, the device just reboots and it will start over. Nor perfect, but acceptable. But after a few hours it will end up with a corrupted flash firmware, causing core dumps like the one below. At that point I have to re-flash the firmware. The file system is not affected.
                            ets Jun  8 2016 00:22:57
                            configsip: 0, SPIWP:0xee
                            mode:DIO, clock div:1
                            load:0x3fff8028,len:8
                            load:0x3fff8030,len:2156
                            ho 0 tail 12 room 4
                            load:0x4009fa00,len:19208
                            entry 0x400a05f4
                            Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited). Exception was unhandled.
                            Core 1 register dump:
                            PC      : 0x00000000  PS      : 0x00060031  A0      : 0x40083b04  A1      : 0x3ffc13f0
                            A2      : 0x3ffc5c6c  A3      : 0x00800000  A4      : 0x00000000  A5      : 0x00000000
                            A6      : 0x3ffdd308  A7      : 0x000006f4  A8      : 0x8008456a  A9      : 0x0000018c
                            A10     : 0x3ffda984  A11     : 0x3ffdda09  A12     : 0x80098d18  A13     : 0x3ffe32b0
                            A14     : 0x3ffda974  A15     : 0x3ffdd304  SAR     : 0x00000013  EXCCAUSE: 0x00000014
                            EXCVADDR: 0x00000000  LBEG    : 0x4009dc28  LEND    : 0x4009dc33  LCOUNT  : 0xffffffff
                            Core 1 was running in ISR context:
                            EPC1    : 0x00000000  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x4008b78e
                            Backtrace: 0x00000000:0x3ffc13f0 0x40083b01:0x3ffc1410 0x4000bfed:0x3ffe3320 0x40095da3:0x3ffe3330 0x400d2f7b:0x3ffe3350 0x400d2fc1:0x3ffe33b0 0x4015edfd:0x3ffe33e0 0x400e2af1:0x3ffe3400 0x400ddd48:0x3ffe3420
                            oB0AAAoAAABsAQAA
                            KND9P/Be/j8cYP4/
                            8F7+P7Bf/j+lpaWl9Fr8P5xX/D8o0P0/lFf8PxQAAAClpaWlpaWlpSjQ/T8AAAAA
                            BQAAACBQ/j9TZXJ2ZXJzAKWlpaWlpaUAAQAAABxg/j8AAAAApaWlpQUAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAABA6v0/qOr9PxDr/T8AAAAAAAAAAAEAAAAAAAAA
                            W0VBPwAAAAC84glAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
                            nDgIQKjhDUAwAAUAAAAAALBf/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAANCT+j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAC8X/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAA
                            • catalinC Offline
                              catalin @robert-hh
                              @robert-hh Thanks a lot, Robert, for highlighting this malfunction.
                              I will test this scenario on the latest firmware.
                              Catalin,
                                robert-hh @catalin
                                @catalin Two question:
                                1. I tried the Pymesh Android app, but it does not get any connections. Where and how does it search for a connection.
                                2. With these standard binary images, how can I change the WiFi settings, e.g. into STA mode and DHCP? The code seems to be executed from _boot.py. If I interrupt is, the normal boot process continues. Funny enough, some of the pymesh stuff continues to run.
                                • catalinC Offline
                                  catalin @robert-hh
                                  1. The Pymesh mobile app searches BLE Servers with name "PyGo*". I suppose pressing Restart scan button doesn't solve situation. Try to use another mobile app, like BLE Scanner(or nRF Connect) to check if the Lopy is discovered (it should have 2 services advertised). Sometimes Android+iOS have some caching of BLE connections.
                                  2. Basically, you can't have your own main, as several threads are in the frozen scripts, hence the zombie threads.
                                  Now I am working a frozen Pymesh scripts(as library) which can be used with a user main.py+ config file, hope to be done to be included in next Pymesh firmware release.
                                  Catalin,
                                    robert-hh @catalin
                                    @catalin BLE Scanner finds both devices active at the moment, but the pymesh app does not connect.
                                    • catalinC Offline
                                      catalin @robert-hh
                                      @robert-hh, I'm not sure how it works in Android, rights for using Bluetooth and localisation should be given to the Pymesh app (iOS asks when app is first time started).
                                      Localisation right is required as GPS coords are sent to the node when BLE connection is established; and somehow BLE usage is linked to localisation services, too; honestly I did not investigated this.
                                      Catalin,
                                        robert-hh @catalin
                                        @catalin Thank. That was the trick.
                                        • E Offline
                                          eranroll
                                          @catalin Hi,
                                          I have being experiencing the same crashes as @robert-hh when using LoRa MESH with FiPy-1.20.0.rc8, and I know that LoRa MESH has been removed from new development builds such as FiPy-1.20.0.rc13.
                                          I would like to know if a stable LoRa MESH version is planned anytime soon, or perhaps even a more stable development version?
                                          • DanneD Offline
                                            Danne
                                            First of all, let me thank you for this excellent project!
                                            Pymesh paves way for many very interesting projects!
                                            I have started on a project using a pymesh network, it's a simple network with LoPy4 nodes and WiFi access points with web-servers allowing people to find each other and then send encrypted messages over the Loramesh. I want to add batteries and solar-cells to the mesh nodes to make this project completely off-grid.
                                            Cellphone  <- HTTP over WiFi -> LoPy4 <-> LoRa Mesh
                                            Questions for @catalin:
                                            • Which firmware would you recommend for the early development of products using mesh? Should I wait for the upcoming release?
                                            • I would like a version of the firmware with source-code to be able to debug things like "InstrFetchProhibited". The latest version of the Firmware (https://github.com/pycom/pycom-micropython-sigfox) does not include the OpenThread in pycom-esp-idf https://github.com/pycom/pycom-esp-idf . Is there a developer branch that I can get access to, if so which? I don't mind it being under development or if it crashes as long as I can build it and investigate further :)
                                            Sincerely,
                                            • 2 / 4
