Pymesh wishlist
Hello community 🙌,
We would like to collect here the wishes for the Pymesh - LoRa based Mesh networking.
Last releasev1.20.1.r2
(3rd Nov 2019).Features:
Using latest pycom updater (1.16.1) and I cant seem to select tar.gz files from the file list when using the Flash from local file option. All the files are greyed out and unselectable.
If you still have this problem, it can be easily sorted by renaming firmware package
.tar
, instead oftar.gz
. We're looking into it.
Finally got around to reflashing the firmware on a few LoPy4 devices. Seems 1 repeatedly guru mediates. I used a windows laptop to reflash, gave up on the Mac.
Next question for @catalin , when will the L01 firmware be available or can the Lopy4 firmware be used on the L01 ?
thanks
Andrew
@thinginnovations said in Pymesh wishlist:
Using latest pycom updater I can't seem to select
.tar.gz
files from the file list when using the Flash from local file option. All the files are greyed out and unselectable.I believe someone from our community also reported this recently. I couldn't believe it.
@catalin said in Pymesh wishlist:
This is due to newest application rights in macOS Catalina.
Thanks for letting us know about this detail, @catalin! Bummer.
@thinginnovations: Maybe invoking the programm from the command line still works for you like
Prepare
alias pycom-fwtool-cli='/Applications/Pycom\ Firmware\ Update.app/Contents/Resources/pycom-fwtool-cli' export MCU_PORT=/dev/cu.usbmodemPye090a1
Invoke
pycom-fwtool-cli --verbose --port $MCU_PORT flash --tar FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
@thinginnovations This is due to newest application rights, in Catalina. (Try System Preferences/Security&Privacy/Full Disk access).
Could you make a new topic in https://forum.pycom.io/category/17/software-tools and maybe the community has the solutions.
This is on Mac OS Catalina.
Any ideas?
The file received did not contain the L01 firmwar images, only for FPy and Lopy4.
Andrew
Got it all now, thanks @catalin
no reply yet.
@thinginnovations hi Andrew,
I'm not sure what you mean. After signing the licence, you'll receive the firmware binary (for Lopy4 and Fipy) immediately.
On the long run, more features and bugfixes will be added to the Pymesh release, probably you'll receive updates automatically (the process is under implementation now).
At some point, Pymesh firmware flashing (and licence signing) will be done within the Firmware Update Tool.
@catalin Thanks, I'll give it a try.
What is the timescale for getting the updated firmware after jumping through the licensing hoops?
Andrew
@thinginnovations fyi, as explained here the sleepy end devices was implemented using a simple
pymesh.end_device(True)
For the ref, this is inv1.20.1.r2
@catalin This is my understanding, the edge nodes don't route traffic, they are like the leaves on a tree - at the very edge.
I was originally looking at the definitions at https://openthread.io/guides/thread-primer/node-roles-and-types
Cheers
Andrew
@thinginnovations Thanks Andrew, for suggestion.
Could you be a bit more exact of what do you expect?
I am thinking, that a certain node (connected within a Pymesh network), can be forced to a
Child
role, so it can go to (deep)sleep as much as it wants. When it wakes up, he will take its old role back (look for the same parent, if not found connect asChild
to a differentParent
), important thing is that he won't affect the Pymesh. Being aChild
he won't relay/route packages.Then probably for some nodes, an opposite feature (always
Router
role) needs to be created, right? So these nodes, would always (most of the time) be active, and they will be designatedLeader
/Router
role with a higher priority.Let me know what you think!
Sleepy edge nodes.
Andrew
