    FiPy OTAA join not working
    5 Posts 3 Posters 301 Views 3 Watching
    • F Offline
      ftorres
      I have the following code running on two LoPy boards without any problem
      from network import LoRa
      import ubinascii
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.US915, adr=False, public=True)
      for channel in range(0, 72):
          lora.remove_channel(channel)
      for channel in range(0, 8):
          lora.add_channel(channel, frequency=902300000 + channel*200000, dr_min=0, dr_max=3)
      app_eui = ubinascii.unhexlify('ADA4DAE3AC12676B')
      app_key = ubinascii.unhexlify('11B0282A189B75B0B4D2D8C7FA38548B')
      while not lora.has_joined():
          time.sleep(2.5)
          print('Not yet joined...')
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 2)
      s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, True)
          s.setblocking(True)
          s.setblocking(False)
          time.sleep(10)
      I recently got two FiPy boards but, when I try to run the exact same code, they are unable to join to the network because they get stuck in
          time.sleep(2.5)
      I'm using LoRa Server as network server, so I checked the application logs and the join request messages don't even appear. Does anyone know what could be happening?
      Thanks in advance.
        thinginnovations @ftorres
        Are you within range of a gateway?
        • F Offline
          ftorres @thinginnovations
          @thinginnovations Yes, I am (it is a Multitech Conduit). As I said in the first post, I'm using two LoPy boards with the same code and setup and they are working fine, but when I try it with the FiPy boards I can't make it work, so I'm clueless.
            rskoniec @ftorres
            @ftorres
            • What do you mean by same setup - same f/w, same hardware setup (connected devices)?
            • Do you have something connected to the FiPy (especially to pins P5, P6, P7 - these are used by LoRa/Sigfox radio). Details in FiPy Pinout Diagram
            • F Offline
              ftorres @rskoniec
              @rskoniec
              • By "same setup" I mean same firmware as the LoPy boards (1.18.1.r1), same code running on the boards, same gateway (Multitech Conduit), same network server (LoRa Server) and they are registered to the same application with the same configuration.
              • The FiPy are connected to Expansion Boards 3.0, but they don't have anything connected to its pins.
