FiPy - getting started
- while disconnected I inserted the SIM card into FiPy, connected USB to my laptop and then registered my SIM card with Hologram.
- I downloaded FW upgrade tool and upgraded FW to 1.20.1.r1
- Then in VSCode I wrote boot.py and main.py - both very simple.
- I reconnect FiPy and it connected to port COM15 that I configured in Global Settings and Project Settings
- When I do Upload, I get:
Not safe booting, disabled in settings
Uploading to /flash...
Reading file status
[1/2] Writing file boot.py (0kb)
Failed to write file, trying again...
timeout
[2/2] Writing file main.py (0kb)
Upload failed.: timeout Please reboot your device manually.Then I tried Filezilla after I ran Advanced IP Scanner and found IP: 192.168.1.133 - it is the only active one whose manufacturer is espressif Inc (meaning ESP32 chip, I think). Connection to its FTP fails:
"Connection attempt failed with "ECONNREFUSED - Connection refused by server".Does anyone knows what's going on? No writing rights on the FiPy?
@securigy Pycom is notoriously slow on responses.
Try to mail to bettina@pycom.io (I hope remember the address right).
@robert-hh So far I am very disappointed with Pycom.io sales - they are simply not responsive. I asked them a question about v1.2 and pointed out that there is no information whatsoever on their web site whether what you buy is v1.2 and that the images show 1.0r
**Got no response...**I have never seen anything like that...
I also got no response to my RMA request for defective FiPy 1.0r from Seeed Studio, despite that I provided all the info requested requested by them. Makes me think that there is no sales department per se.
@securigy The one you purchase at Pycom should be new ones. The pictures on teh web site may be old.
@robert-hh BTW, same question again: where can I buy FiPy 1.2 ?
@securigy OK. So it is the old version. But besides the limits for LTE, it should work normally. So the device may have other defects.
@robert-hh The version says: 1.0r
@securigy You can tell the model you have by looking at the bottom side of it. The top side always shows 1.0.
About the garbage files: If erasing and reloading firmware worked, they should be gone. So I assume that something went wrong.
@robert-hh After using the firmware upgrader/updater tool I disconnect and reconnect power to WiFy simply by unplugging USB cable and plugging it back. After that - you cannot see FiPy as AP - it does not show up in the list of wireless network and there is no FTP access to 192.168.4.1. The upload via COM/UART (in my case COM15) is not working - failing to copy files. The only way I could get something is by executing WLAN commands from command line and assigning a static IP address - in my case 192.168.1.177. After that there is 10% success rate of FTP connection (with 1% success rate of file transfers) and 0.1% success rate of COM/UART file transfers. Those numbers are not exact numbers - my impression only. And as you could see the FPT shows lots of garbage of CDUP directories...
I already contacted Pycom RMA and am waiting for their response. In fact I just wanted to buy another FiPy from another source but everywhere I go (digi-key, mouser, etc.) I see FiPy 1.0. The FiPy 1.2 is nowhere to be found. Even if you follow the link from Pycom.io - I am puzzled...
@securigy You can use esptool.py to erase the flash. That's the simple tool behind the pyupgrader and will really erase everything.
link here: https://github.com/espressif/esptool
But you may also able to install it with pip.
The you can upload the firmware again. I'm still puzzled about the IP address 192.168.1.177. Are you sure that you connect to the right device? A really clean installed new device should create an access point with the address 192.168.4.1. Unless you computer is not configured to that address space 192.168.4.x, you will not be able to detect it.
For the rma, look here: https://forum.pycom.io/topic/3843/important-news-regarding-cat-m1-and-nb-iot-cellular-range
"Pycom has a RMA process for replacing 1.0 devices with 1.2 models."
That's a great news.
I really exhausted all options - tried cmd-line FTP: no luck.
I re-flashed the FiPy - same thing as before. Finally got through with Filezilla only to see that both /flash dir and /flash/dir contain those weird CDUP folders (see below).
...numerous days spend/wasted...
Any specific links to their RMA process?BTW, thank you, Robert, I appreciate your patience.
![alt text]( image url)
One more thing that I will try is to re-flash the chip - during one of the successful FTP connects I noticed lots of identical CDUP files that I was not able to delete...
That is indeed strange. A clean Pycom device should only show the default boot.py, main.py and three empty directories cert, lib and sys. And yes, using the pycom updater you have the option to erase the flash.
That's what leads me to conclusion that the chip is defective...I purchased it from Seeed that was the least expensive $39 instead of other names such as Digi-Key and Mouser that offered it for $60-$70. My understanding is that Seeed is a Chinese company and maybe the lower price has its reason.
That is too interesting. I looked at that page, and it shows a version # 1.0r on the back side. That model has a problem, in that is only support a limited number of LTE channels. That cannot be fixed by software. So maybe that is the reason why it is way cheaper than the actual model, which is version 1.2. It works in some regions, and the other components are fine.
Edit: Pycom has a RMA process for replacing 1.0 devices with 1.2 models.
@robert-hh Ampy: I set AMPY_PORT=COM15 as environmental variable for myself as a specific user.
I will try FTP command line per your suggestion - but I don't think it will help... Besides, Filezilla is very reliable FTP tool - I used it for years with 100% success...
At this point I will probably shelve the whole project. I had high hopes for it in LTE-M area but I have to deal with facts, and the facts are that I cannot even start making progress since I have been trying to transfer files to FiPy...
One more thing that I will try is to re-flash the chip - during one of the successful FTP connects I noticed lots of identical CDUP files that I was not able to delete...Will FW update tool re-format the whole chip and re-install the firmware of the same version? (the latest)
@securigy Thank you for the feedback. Th eampy error log shows, that ift could not access the com port, for whatever reason. The command line in the window does not show the COM port for the connection. Did you call it with:
ampy -p COMxx ls
About ftp: My experience with ftp and Pycom boards is very well. I use that all the time, and had never problem with it. The devices connect immediately. There are many aspects to argue about with the pycom firmware, but the ftp server always worked. Using command line ftp, i can see that there is a welcome message:
"220 Micropython FTP Server"
So there may be another problem in your set-up.
On windows the command line ftp is very limited. but at least opening a session works, and it will show you the 220 welcome message.
@robert-hh I tried ampy and after installing and setting it up on Windows 10 following instruction to the latter, I was not able to issue command 'ampy ls'. It
C:\Users\sales>ampy ls Traceback (most recent call last): File "c:\python374\lib\runpy.py", line 193, in _run_module_as_main "__main__", mod_spec) File "c:\python374\lib\runpy.py", line 85, in _run_code exec(code, run_globals) File "C:\Python374\Scripts\ampy.exe\__main__.py", line 9, in <module> File "c:\python374\lib\site-packages\click\core.py", line 764, in __call__ return self.main(*args, **kwargs) File "c:\python374\lib\site-packages\click\core.py", line 717, in main rv = self.invoke(ctx) File "c:\python374\lib\site-packages\click\core.py", line 1134, in invoke Command.invoke(self, ctx) File "c:\python374\lib\site-packages\click\core.py", line 956, in invoke return ctx.invoke(self.callback, **ctx.params) File "c:\python374\lib\site-packages\click\core.py", line 555, in invoke return callback(*args, **kwargs) File "c:\python374\lib\site-packages\ampy\cli.py", line 99, in cli _board = pyboard.Pyboard(port, baudrate=baud, rawdelay=delay) File "c:\python374\lib\site-packages\ampy\pyboard.py", line 147, in __init__ raise PyboardError('failed to access ' + device) ampy.pyboard.PyboardError: failed to access \\.\COM15
So I switched to FTP, and using your script I established finally WiFi connection by setting static IP to FiPy. Thank you for that. I was able to connect and copy files that coded and some pytrack libraries. However, I must notice that FTP implementation of FiPy is very flaky. I implemented a few FTP clients and servers over the years and I know bad implementation when I see one...upon connection FiPy FTP server does not issue a welcome message that FileZilla expects and this breaks the whole thing...but somehow after 20-30 attempts I succeeded to copy all files but one... Not sure if this feedback helps or not but I am just stating what I see... (I am using PASSIVE mode and insecure and plan FTP...)
@securigy I have FiPy and LoPy4 devices. They do not get hot. If you supply them though a Pytrack board and USB, there is nothing that should damage them supply wise. The consume less than 1W power, so that should not get to any excess temperatures. If you have the chance to measure the current they consume, you should do that. There are low cost USB adapters who do that.
Generally the xxPy devices are of good manufacturing quality. They are built as intended, even if the intention is sometimes wrong. You should however upload the recent firmware.
Pymakr in my view is a source of trouble. You get problems with any change of VSC or Atom. Better use simple tools. For the REPL console, use a terminal emulator like Putty (do nto forget to set flow control to None). For file upload, you can use adafruit-ampy or rshell as basic tools, and go for FTP or FileZilla as soon a the WiFi is set up.
P.S.: Do not call both the constructor wlan=WLAN(...) and wlan.init(), because the latter will set what have been initialized in the constructor, maybe to the default.
My WiFi init sequence is:def do_connect(): import network import time from uos import uname wlan = network.WLAN(mode=network.WLAN.STA) # create station interface if not wlan.isconnected(): # check if the station is connected to an AP wlan.ifconfig(config=(WIFI_IP, "255.255.255.0", ROUTER_IP, ROUTER_IP)) wlan.connect(ssid=WIFI_SSID, auth=(network.WLAN.WPA2, WIFI_PASSWD)) for _ in range(100): if wlan.isconnected(): # check if the station is connected to an AP break print('.', end='') time.sleep_ms(200) else: print("Connect attempt timed out\n") return print('\nnetwork config:', wlan.ifconfig()) do_connect()
It sets a fixed IP address in my local network range. IP-Addresses are strings in the form "xx.xx.xx.xx". If oyu omit the ifconfig call, then dhcp is requested. You may also call:
import pycom pycom.wifi_on_boot(True)
I connected FiPy instead of LoPy4 and having the following problems:- Both FiPy and PyTrack get hot, they do not burn the skin but still quite hot...
- FiPy on the boot does not exhibit any SSID
- I have tremendous problems copying files (over the same COM port I used for LoPy4) to FiPy using VSCode/pymakr - the success rate is 1:100, File uploading still works fine for LoPy on the same PyTrack.
So, did I receive defected FiPy? Or those are just "immaturity" problems of this device, and it is simply not ready for prime time? Can I return it to the distributor I bought it from?
@robert-hh When I boot up FiPy and get into REPL on COM15, and then execute from REPL the following commands, I do not get any SSID:
>>>import pycom >>> from network import WLAN >>> wlan=WLAN() >>> wlan.init() >>> wlan.mode() 1 >>> wlan.ssid() >>> wlan.auth() (3, 'www.pycom.io')
Is that normal? I read everywhere that FiPy boots in WLAN.AP mode...
Redundant to say - I do not see any FiPy network in a list of available wireless networks...
Another strange thing: when I scan all IPs with Advanced IP Scanner it shows me the Espressif Inc for address 192.168.1.133 while the name is some kind of 12#@*san.rr.com - the last part is the Internet provider domain...
Anyway, I am at loss - already spent 2 days trying to copy the files to FiPy...
@securigy When trying to use FileZilla, did you connect your PC to the AP, set up by the FiPy?
Adafruit ampy and rshell are python scripts. So they works on windows too. They just require Python to be installed. For ampy, look here on setup notes: https://learn.adafruit.com/micropython-basics-load-files-and-run-code/install-ampy
seems that rshell and adafruit-ampy are linux tools... and I am running Windows 10....
I am just curios why I am getting
When I try to copy with FileZilla... I tried both without credentials and with user=micro and password=python with the same result... using plain FTP (insecure)
