    Firmware Release v1.20.1
    firmware
    68 Posts 18 Posters 12.2k Views 19 Watching
      serafimsaudade
      I'm getting this error when compiling.
      I clone the repo and try to compile.
        robert-hh @serafimsaudade
        @serafimsaudade IOt may be a problem with the pycom esp-idf.
        in the folder pycom-esp-idf, execute the command:
        git checkout idf_v3.2
        git submodule sync
        git submodule update --init
        Also, in you pycom esp32 source directory, issue the commands:
        git checkout Dev
        git submodule sync
        Then, a
        make BOARD=WIPY clean
        make BOARD=WIPY
          serafimsaudade @robert-hh
          @robert-hh Tks for the tip.
          That was the idf submodules.
          problem solve. :)
            serafimsaudade
            Hi again,
            I'm trying to connect gpy to wireless, but when I do wlan.scan() get this error:
            wlan = WLAN(mode=WLAN.STA_AP,ssid="teste", auth=(WLAN.WPA2, 'pass'))
            nets = wlan.scan()
            OSError: Scan operation Failed!
            This work on others fw version.
            robert-hhR A 2 Replies Last reply Reply Quote 0
              @serafimsaudade The following sequence works for me:
              from network import WLAN
              wlan = WLAN(WLAN.STA_AP)
              wlan.scan()
              S robert-hhR 2 Replies Last reply Reply Quote 0
                @robert-hh but I need to set a custom ssid and password.
                  robert-hh @robert-hh
                  @robert-hh This sequence works too, after setting the password to a length of 8 min.:
                  wlan=WLAN(mode=WLAN.STA_AP, ssid="teste", auth=(WLAN.WPA2, 'passpass'))
                  wlan.scan()
                  Pycom MicroPython 1.20.1.r1 [d4b4717] on 2019-10-09; LoPy4 with ESP32
                  I do not expect that the GPY is different with respect to WiFi.
                    time.sleep(3)
                    wlan.scan()
                    If I put a delay >= 3 seconds, works as espected, strange.
                      crumble
                      Running 1.20.1r1 I am impressed of the boot performance.
                      But in combination with a pytrack there are a lot of i2c errors. I am not amused to figure out new timings which may result in less errors, but will never remove them all.
                      Additionally I run now into i2c that can only be resolved by cutting the power suply. Would be great, if the PIC has a watchpig function. So I can track down with less efford, if this is caused by the LoPy or the Pytrack.
                        andreas @berni
                        Hi there,
                        @berni said in Firmware Release v1.20.1:
                        I have disabled the pybytes in the pybytes_config.json file by adding {"pybytes_autostart": false} and that fixed the issue.
                        We are able to confirm the new firmware obtained from [0] and bundled and flashed to a FiPy device through the process outlined on [1] works flawlessly. Before adding the pybytes_config.json file, we also experienced Guru Meditation errors like outlined above (bad00bad bad00bad bad00bad). We didn't even use LoRa, just WiFi.
                        @crumble said in Firmware Release v1.20.1:
                        We are running the Terkin Datalogger [2] and are also very happy about the performance improvements through the efficiency gains of the new mpy file format shipped with MicroPython 1.11 [3] when loading the py/mpy files into memory. On MicroPython 1.9.4, this took about 30(!) seconds and now we are down to 5 seconds [4].
                        Thanks to all people involved in this release, turtles all the way down to the MicroPython core maintainers - you know who you are!
                        With kind regards,
                        Andreas.
                        [0] https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.1.r1
                        [1] https://forum.pycom.io/topic/4518/firmware-update-elf-vs-tar/13
                        [2] https://github.com/hiveeyes/hiveeyes-micropython-firmware
                        [3] https://github.com/micropython/micropython/releases/tag/v1.11
                        [4] https://community.hiveeyes.org/t/micropython-module-freezing/2445/10
                          t0000899
                          Wlan connection has turned to really unreliable in 1.20 version. In 1.18 connection was instant and never disconnected but in the 1.20 version wlan.connect(...) timeout most of the time and if connection is made it disconnects randomly.
                          If connection get broken wlan.ifconfig() show (0.0.0.0,0.0.0.0,0.0.0.0,0.0.0.0).
                          Pycom MicroPython 1.20.1.r1 [v1.11-3138a13] on 2019-10-08; LoPy4 with ESP32
                          Pybytes Version: 1.1.3
                          Smart config auto-start is disabled.
                          Sometimes during FTP transfer there is an unhandled exception and flash memory is formatted:
                          Memory dump at 0x4020234c: bad00bad bad00bad bad00bad
                          Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.
                          From my boot.py file:
                          if useWlan == True:
                          	print('Configure WLAN')
                          	wlan = WLAN(mode=WLAN.STA, power_save=True)
                          	wlan.ifconfig(config='dhcp')
                          	wlan.connect(AP_name, auth=(WLAN.WPA2, AP_password), timeout=30000)
                          	del AP_name
                          	del AP_password
                          A 2 Replies Last reply Reply Quote 2
                          • rcolisteteR Offline
                            rcolistete @rcolistete
                            @rcolistete said in Firmware Release v1.20.1:
                            Please update the links for all Pycom devices in :
                            https://docs.pycom.io/advance/downgrade/
                            to include the version 1.20.1 for manual firmware download.
                            Repeating my request.
                              benc
                              Hi, the release notes mention that uasyncio is included in this release, but I can't find it when I run help('modules').
                              Any tips of how to import it?
                                robert-hh @benc
                                @benc You have to go to this lib https://github.com/micropython/micropython-lib and get: uasyncio/uasyncio/init.py and uasyncio.core/uasyncio/core.py. Copy it to the board, best under lib/uasyncio. Then you should have the files:
                                lib/uasyncio/init.py
                                lib/uasyncio/core.py
                                You may also copy the files upip.py and upip_utarfile.py from https://github.com/micropython/micropython/tree/master/tools. If you install these on your board (e.g. to lib), you can use that via REPL to install modules from https://micropython.org/pi or https://pypi.org/pypi with the commands:
                                import upip
                                upip.install("micropython-uasyncio", "lib")
                                The status of micropython-lib is somewhat unclear. Not all modules from that lib work with any micropython board. But it is always a good source of inspiration.
                                  crumble @crumble
                                  I found a workaround for my actual I2C problem.
                                  When I2C Error on init the GPS pop up, this status will stay even on reboot. So intentioned machine.reset(), uploading new python scripts and the watchdog is no solution. So the machine gets into an endless reboot loop until the power supply is cut.
                                  The solution is to catch the I2C error and send the pytrack to deepsleep with gps=True. This resets the GPS, so that the ESP can talk again to it.
                                  try:
                                    self.i2c.writeto(GPS_I2CADDR, self._mtkSentence)
                                    utime.sleep_ms(wait_ms)
                                  except Exception as e:
                                    sys.print_exception(e)
                                    print("cut off GPS")
                                    utime.sleep_ms(2000)
                                    pytrack.setup_sleep(1)
                                    pytrack.go_to_sleep(True)
                                  So 1.20.1.r1 seems to fix my problems at the moment. Would be nice, if this damn GPS will will be able again to find sattelites and print is able to flush.
                                    andreas @t0000899
                                    @t0000899 said in Firmware Release v1.20.1:
                                    We can confirm this after upgrading to 1.20.1 on FiPy and LoPy4 devices, with or without VARIANT=PYBYTES. We are also spuriously getting these core panics, see also https://community.hiveeyes.org/search?q=bad00bad bad00bad bad00bad.
                                    Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
                                    Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                                    Memory dump at 0x4020f958: bad00bad bad00bad bad00bad
                                    Memory dump at 0x40200754: bad00bad bad00bad bad00bad
                                      dabal221 @serafimsaudade
                                      @serafimsaudade How do you solve this "OSError: Scan operation Failed!"?
                                        serafimsaudade @dabal221
                                        @dabal221
                                        I put a time.sleep of 3sec before wlan.scan(). And the error don't happen.
                                        # Change the mode to both AP and station so we can connect to the network
                                        self.wlan.init(mode=WLAN.STA_AP, ssid=system.uniqueGwId, auth=(WLAN.WPA2, self.system.apKey))
                                        # Use internal antena
                                        #self.wlan.antenna(WLAN.INT_ANT)
                                        # Use External antena
                                        self.wlan.antenna(WLAN.EXT_ANT)
                                        try:
                                            time.sleep(3)
                                            self.nets = self.wlan.scan()
                                        except Exception as exception:
                                            print("error", 'startWLAN scan: {0}'.format(exception))
                                          @serafimsaudade Unfortunately, it does not change anything. :(
                                            andreas @serafimsaudade
                                            @serafimsaudade said in Firmware Release v1.20.1:
                                            nets = wlan.scan()
                                            @dabal221 said in Firmware Release v1.20.1:
                                            For us, this flow works
                                            import network
                                            station = network.WLAN()
                                            station.antenna(network.WLAN.EXT_ANT)
                                            station.mode(network.WLAN.STA)
                                            station.init()
                                            then, later, either
                                            station.scan()
                                            or
                                            station.connect(ssid, (auth_mode, password), timeout=int(timeout * 1000))
                                            • 3 / 4
