    Firmware Release v1.20.1
    firmware
    68 Posts 18 Posters 11.3k Views 19 Watching
      serafimsaudade @robert-hh
      from network import WLAN
      wlan=WLAN(mode=WLAN.STA_AP, ssid="teste", auth=(WLAN.WPA2, 'passpass'))
      time.sleep(3)
      wlan.scan()
      If I put a delay >= 3 seconds, works as espected, strange.
        crumble
        Running 1.20.1r1 I am impressed of the boot performance.
        But in combination with a pytrack there are a lot of i2c errors. I am not amused to figure out new timings which may result in less errors, but will never remove them all.
        Additionally I run now into i2c that can only be resolved by cutting the power suply. Would be great, if the PIC has a watchpig function. So I can track down with less efford, if this is caused by the LoPy or the Pytrack.
          andreas @berni
          Hi there,
          @berni said in Firmware Release v1.20.1:
          I have disabled the pybytes in the pybytes_config.json file by adding {"pybytes_autostart": false} and that fixed the issue.
          We are able to confirm the new firmware obtained from [0] and bundled and flashed to a FiPy device through the process outlined on [1] works flawlessly. Before adding the pybytes_config.json file, we also experienced Guru Meditation errors like outlined above (bad00bad bad00bad bad00bad). We didn't even use LoRa, just WiFi.
          @crumble said in Firmware Release v1.20.1:
          We are running the Terkin Datalogger [2] and are also very happy about the performance improvements through the efficiency gains of the new mpy file format shipped with MicroPython 1.11 [3] when loading the py/mpy files into memory. On MicroPython 1.9.4, this took about 30(!) seconds and now we are down to 5 seconds [4].
          Thanks to all people involved in this release, turtles all the way down to the MicroPython core maintainers - you know who you are!
          With kind regards,
          Andreas.
          [0] https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.1.r1
          [1] https://forum.pycom.io/topic/4518/firmware-update-elf-vs-tar/13
          [2] https://github.com/hiveeyes/hiveeyes-micropython-firmware
          [3] https://github.com/micropython/micropython/releases/tag/v1.11
          [4] https://community.hiveeyes.org/t/micropython-module-freezing/2445/10
            t0000899
            Wlan connection has turned to really unreliable in 1.20 version. In 1.18 connection was instant and never disconnected but in the 1.20 version wlan.connect(...) timeout most of the time and if connection is made it disconnects randomly.
            If connection get broken wlan.ifconfig() show (0.0.0.0,0.0.0.0,0.0.0.0,0.0.0.0).
            Pycom MicroPython 1.20.1.r1 [v1.11-3138a13] on 2019-10-08; LoPy4 with ESP32
            Pybytes Version: 1.1.3
            Smart config auto-start is disabled.
            Sometimes during FTP transfer there is an unhandled exception and flash memory is formatted:
            Memory dump at 0x4020234c: bad00bad bad00bad bad00bad
            Guru Meditation Error: Core  0 panic'ed (IllegalInstruction). Exception was unhandled.
            From my boot.py file:
            if useWlan == True:
            	print('Configure WLAN')
            	wlan = WLAN(mode=WLAN.STA, power_save=True)
            	wlan.ifconfig(config='dhcp')
            	wlan.connect(AP_name, auth=(WLAN.WPA2, AP_password), timeout=30000)
            	del AP_name
            	del AP_password
            A 2 Replies Last reply Reply Quote 2
            • rcolisteteR Offline
              rcolistete @rcolistete
              @rcolistete said in Firmware Release v1.20.1:
              Please update the links for all Pycom devices in :
              https://docs.pycom.io/advance/downgrade/
              to include the version 1.20.1 for manual firmware download.
              Repeating my request.
                benc
                Hi, the release notes mention that uasyncio is included in this release, but I can't find it when I run help('modules').
                Any tips of how to import it?
                  robert-hh @benc
                  @benc You have to go to this lib https://github.com/micropython/micropython-lib and get: uasyncio/uasyncio/init.py and uasyncio.core/uasyncio/core.py. Copy it to the board, best under lib/uasyncio. Then you should have the files:
                  lib/uasyncio/init.py
                  lib/uasyncio/core.py
                  You may also copy the files upip.py and upip_utarfile.py from https://github.com/micropython/micropython/tree/master/tools. If you install these on your board (e.g. to lib), you can use that via REPL to install modules from https://micropython.org/pi or https://pypi.org/pypi with the commands:
                  import upip
                  upip.install("micropython-uasyncio", "lib")
                  The status of micropython-lib is somewhat unclear. Not all modules from that lib work with any micropython board. But it is always a good source of inspiration.
                    crumble @crumble
                    I found a workaround for my actual I2C problem.
                    When I2C Error on init the GPS pop up, this status will stay even on reboot. So intentioned machine.reset(), uploading new python scripts and the watchdog is no solution. So the machine gets into an endless reboot loop until the power supply is cut.
                    The solution is to catch the I2C error and send the pytrack to deepsleep with gps=True. This resets the GPS, so that the ESP can talk again to it.
                    try:
                      self.i2c.writeto(GPS_I2CADDR, self._mtkSentence)
                      utime.sleep_ms(wait_ms)
                    except Exception as e:
                      sys.print_exception(e)
                      print("cut off GPS")
                      utime.sleep_ms(2000)
                      pytrack.setup_sleep(1)
                      pytrack.go_to_sleep(True)
                    So 1.20.1.r1 seems to fix my problems at the moment. Would be nice, if this damn GPS will will be able again to find sattelites and print is able to flush.
                      andreas @t0000899
                      @t0000899 said in Firmware Release v1.20.1:
                      We can confirm this after upgrading to 1.20.1 on FiPy and LoPy4 devices, with or without VARIANT=PYBYTES. We are also spuriously getting these core panics, see also https://community.hiveeyes.org/search?q=bad00bad bad00bad bad00bad.
                      Guru Meditation Error: Core  1 panic'ed (Cache disabled but cached memory region accessed)
                      Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                      Memory dump at 0x4020f958: bad00bad bad00bad bad00bad
                      Memory dump at 0x40200754: bad00bad bad00bad bad00bad
                        dabal221 @serafimsaudade
                        @serafimsaudade How do you solve this "OSError: Scan operation Failed!"?
                          serafimsaudade @dabal221
                          @dabal221
                          I put a time.sleep of 3sec before wlan.scan(). And the error don't happen.
                          # Change the mode to both AP and station so we can connect to the network
                          self.wlan.init(mode=WLAN.STA_AP, ssid=system.uniqueGwId, auth=(WLAN.WPA2, self.system.apKey))
                          # Use internal antena
                          #self.wlan.antenna(WLAN.INT_ANT)
                          # Use External antena
                          self.wlan.antenna(WLAN.EXT_ANT)
                          try:
                              time.sleep(3)
                              self.nets = self.wlan.scan()
                          except Exception as exception:
                              print("error", 'startWLAN scan: {0}'.format(exception))
                            @serafimsaudade Unfortunately, it does not change anything. :(
                              andreas @serafimsaudade
                              @serafimsaudade said in Firmware Release v1.20.1:
                              I'm trying to connect gpy to wireless, but when I do wlan.scan() get this error:
                              wlan = WLAN(mode=WLAN.STA_AP,ssid="teste", auth=(WLAN.WPA2, 'pass'))
                              nets = wlan.scan()
                              This work on others fw version.
                              @dabal221 said in Firmware Release v1.20.1:
                              For us, this flow works
                              import network
                              station = network.WLAN()
                              station.antenna(network.WLAN.EXT_ANT)
                              station.mode(network.WLAN.STA)
                              station.init()
                              then, later, either
                              station.scan()
                              or
                              station.connect(ssid, (auth_mode, password), timeout=int(timeout * 1000))
                                dabal221 @andreas
                                @andreas Where can I find Firmware Release v1.20.1? Because when I update Firmware using Pycom Firmware Update I have got 1.20.0.rc13 not 1.20.1
                                  andreas
                                  Maybe the program will offer the newer releases after upgrading the Pycom Firmware Updater itself.
                                    dabal221 @andreas
                                    @andreas said in Firmware Release v1.20.1:
                                    @andreas I have got 1.16.1, it is said that it is the latest stable version.
                                      crumble @dabal221
                                      @dabal221
                                      The new firmware is only visible, if you select pybytes, If yiou are asked about your bybytes ID, you can simply skip the question.
                                        dabal221 @crumble
                                        @dabal221
                                        What is the between pybytes and pybytes/legacy?
                                          andreas @t0000899
                                          Dear @t0000899 and all others here,
                                          Sometimes during FTP transfer there is an unhandled exception and flash memory is formatted.
                                          We have been working on mitigating these issues, so if you feel lucky, you might want to try one of our custom builds published to [1]. More background about this is available through [2].
                                          If we are lucky together, this will improve the stability significantly. If you will be still receiving the core dumps, I will be happy if you would share its content with us. Please just don't paste it into the comment itself but put it into a file which you will be able to upload by dragging it into the text area.
                                          Please be aware that when upgrading from a lower firmware version to the current 1.20.1.r1 development release these builds are based upon, you will have to erase your device completely before flashing in order to keep things straight as outlined within this topic already. Hint: Use a command like pycom-fwtool-cli --port /dev/ttyUSB0 erase_all, see also [3].
                                          Please also be aware that this procedure will also erase the LoRa MAC stored on the device. @robert-hh thankfully outlined the procedure to restore it appropriately:
                                          • If you still know the value the LoraMac had before, then you can follow the procedure explained at https://forum.pycom.io/topic/1272/lora-mac-ffffffffffffffff/21.
                                          • If you do not know it, you will have to use the Pycom updater to restore it:
                                            • First, use the Pycom updater (GUI version) to install a recent image (like pybytes 1.20.1) from the Internet. You do not have to use it, the installation process itself already restores both the LoRa MAC and the Sigfox ID.
                                            • Then, use the Pycom updater to flash the custom image. Do not erase the flash in between.
                                          As it turned out to gain more robustness for others already [4,5], we will be happy to learn if this happens to you as well.
                                          Have fun!
                                          With kind regards,
                                          Andreas.
                                          P.S.: For all people who want to go with Pybytes, we just published builds using VARIANT=PYBYTES at [6]. When going that way, you should probably save the pybytes_config.json before invoking the erase_all procedure and restore it to the device afterwards.
                                          P.P.S.: All these builds use the LittleFS filesystem to prevent filesystem corruption which works for us very well.
                                          [1a] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/LoPy4-1.20.1.r1-0.6.0-vanilla-dragonfly.tar.gz
                                          [1b] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/FiPy-1.20.1.r1-0.6.0-vanilla-dragonfly.tar.gz
                                          [2] https://community.hiveeyes.org/t/investigating-random-core-panics-on-pycom-esp32-devices/2480
                                          [3] https://community.hiveeyes.org/t/installing-the-recent-pycom-firmware-1-20-1-r1-requires-erasing-the-flash-memory-completely/2688
                                          [4] https://community.hiveeyes.org/t/testing-the-custom-dragonfly-builds-on-pycom-devices/2746
                                          [5] https://github.com/pycom/pycom-micropython-sigfox/issues/361#issuecomment-553399627
                                          [6] https://packages.hiveeyes.org/hiveeyes/foss/pycom/pybytes/
                                            bilou7 @iwahdan
                                            @iwahdan
                                            I am using Fipy and Lopy4 device which are getting data from a Ruuvitag by BLE connection. Since I have updated the firmware 1.20.1, pycom devices doesn't get any value from the ruuvi. Do you know if there is an issue with BLE connection with the new firmware ?
                                            • 3 / 4
