Json fipy afer urequest
I wish you to enjoy the Christmas holiday.I'm coming to you because I can't get them back to you because I wish I could. I do a get on api that returns a JSON object with objects inside. I would like to retrieve the data and store it but the conversion doesn't work. Do you have an idea?
Thanks ! :)
r does nor contain valid JSON,
The valid part is surrounded by ?()
If you cannot fix the web service, you have to remove the invalid part before using it as a parameter
Thank you for your help and Happy New Year.
It's all code this time and well formatted.from network import LTE from machine import Timer import time import sys import machine from machine import Pin import usocket import urequest from network import Bluetooth from network import LTE import ubinascii import time import sys import machine from machine import Pin import usocket import urequest from network import Bluetooth from machine import SPI, Pin from ssd1306 import SSD1306_SPI as ssd import utime import pycom import json import ujson pycom.heartbeat(False) lte = LTE() lte.init() rtc= machine.RTC() def connect_to_LTE(): lte.send_at_cmd('AT+CMEE=2') lte.send_at_cmd('AT+CREG?') lte.attach(band=8,apn="iot.1nce.net") lte.send_at_cmd('AT+COPS=1,2,"26201",9') lte.send_at_cmd('AT+CEREG=2') #lte.send_at_cmd('AT+CGDCONT=0') i=0 while not lte.isattached(): time.sleep(0.5) print(".", end="") i=i+1 if i%3 == 0: print(lte.send_at_cmd('AT+COPS=1,2,"26201",9')) print(lte.send_at_cmd('AT+CSQ')) print("\nAttached!") print(lte.send_at_cmd("AT+CSQ")) lte.connect() # start a data session and obtain an IP address while not lte.isconnected(): time.sleep(0.5) print("-", end="") print("Connected!") pycom.rgbled(0xd5362a) # red def request(): print("DSN :") print(usocket.dnsserver()) usocket.dnsserver(0, '8.8.8.8') usocket.dnsserver(1, '10.0.0.1') print(usocket.dnsserver()) flag=False while(flag==False): try : print("Using library urequest...") r= urequest.get("http://api.open-notify.org/iss-now.json?callback=?") print("Return:", r.text) #r.content flag=True pycom.rgbled(0x7ed446) # green return r except OSError as err: print("OUPS ! OS Error {0}".format(err)) def deconnect_to_LTE(): try : pycom.rgbled(0xd5362a) # red lte.disconnect() print("Disconnected!") lte.detach() print("Dettached!") lte.deinit() except OSError as err: print('Oups..') def timestamp(): print(rtc.ntp_sync("0.pool.ntp.org") ) # printing None timestamp = utime.localtime(utime.time()) #printing (2000, 1, 1, 0, 20, 16, 5, 1) but i would like to have (2019, 12, 24, 12, 36, xx, xx, xx) print(timestamp) return timestamp def is_known(): flag=-1 for i in range(0, device_found): check=ubinascii.hexlify(adv.mac) if (check == list_device[i][1]): flag = i return flag def is_flower_care(): name=bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) if(name == 'Flower care'): print(name) return True else: return False check_time = 60 #second list_device = [] device_found = 0 spi = SPI(0, SPI.MASTER, baudrate=100000, polarity=0, phase=0) disp = ssd(128,64,spi,Pin('P9'),Pin('P8'),Pin('P22')) disp.text('I\'m ready',0,0) disp.show() connect_to_LTE() r=request() deconnect_to_LTE() print(json.loads(r.text)) #line 134
Dear @Tgasser,
the code you are showing should grok with the
NameError: name 'json' isn't defined
error again.You have to look at the library I've linked to and here's my full code if it helps.
I don't see that error coming from the
urequests
module. At least, you didn't show any Python traceback indicating so.AttributeError: 'str' object has no attribute 'json'
is even more strange to me.
Are you sure you are running only this code on the device?
With kind regards,
Andreas.
@Tgasser please give matching source and errors/logs, and correctly format source code by putting ``` alone one a line before and after your code.
As it stands, line numbering of the errors and your code don’t quite seem to match.
@andreas You have to look at the library I've linked to and here's my full code if it helps. Thanks :)
lte = LTE() lte.init() rtc= machine.RTC() def connect_to_LTE(): lte.send_at_cmd('AT+CMEE=2') lte.send_at_cmd('AT+CREG?') lte.attach(band=8,apn="iot.1nce.net") lte.send_at_cmd('AT+COPS=1,2,"26201",9') lte.send_at_cmd('AT+CEREG=2') #lte.send_at_cmd('AT+CGDCONT=0') i=0 while not lte.isattached(): time.sleep(0.5) print(".", end="") i=i+1 if i%3 == 0: print(lte.send_at_cmd('AT+COPS=1,2,"26201",9')) print(lte.send_at_cmd('AT+CSQ')) print("\nAttached!") print(lte.send_at_cmd("AT+CSQ")) lte.connect() # start a data session and obtain an IP address while not lte.isconnected(): time.sleep(0.5) print("-", end="") print("Connected!") pycom.rgbled(0xd5362a) # red def request(): print("DSN :") print(usocket.dnsserver()) usocket.dnsserver(0, '8.8.8.8') usocket.dnsserver(1, '10.0.0.1') print(usocket.dnsserver()) flag=False while(flag==False): try : print("Using library urequest...") r= urequest.get("http://api.open-notify.org/iss-now.json?callback=?") print("Return:", r.text) #r.content flag=True pycom.rgbled(0x7ed446) # green return r except OSError as err: print("OUPS ! OS Error {0}".format(err)) def deconnect_to_LTE(): try : pycom.rgbled(0xd5362a) # red lte.disconnect() print("Disconnected!") lte.detach() print("Dettached!") lte.deinit() except OSError as err: print('Oups..') connect_to_LTE() r=request() deconnect_to_LTE() print(json.loads(r))
This looks like a programming error on line 77 within your
main.py
. Without seeing the code, there's no way to reason about the error.
@andreas Sorry, I made a mistake with the picture, this is the correct screenshot :
the lib use is https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
Thank you for your help.
Dear @Tgasser,
line 133 obviously needs an
import json
statement in order to be able to invoke theloads
function on the module level.With kind regards,
Andreas.
