How can I check what filesystem is used on a current pycom board
  • Re: File system problems & solutions
    I have flashed some FiPys with a custom firmware via
    pycom-fwtool-cli.exe --port COM9 flash --tar FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
    pycom-fwtool-cli.exe has afaik no option to set a specific file system (FAT-FS vs. littleFS) So I dont know what the command makes regarding file system.
    In contraast to the command line tool you can set the file system in the GUI-version:
    alt text
    How can I check what file system is use on a current FiPy, a time ago you found this output right after startup:
    load:0x4009fa00,len:19208
    entry 0x400a05f4
    Initializing filesystem as LittleFS!
    Starting boot process...
    but with the latest versions (the above mentioned but also the official 1.20.1.r2) I get only
    ets Jun  8 2016 00:22:57
    rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2136
    load:0x4009fa00,len:19860
    entry 0x400a05d0
    Pycom MicroPython 1.20.1.r1-0.7.0-vanilla-dragonfly-onewire [13d82ea5-dirty] on 2019-11-17; FiPy with ESP32
    or
    load:0x4009fa00,len:19880
    entry 0x400a05d0
    Smart Provisioning started in the background
    See https://docs.pycom.io/smart for details
    Pycom MicroPython 1.20.1.r2 [v1.11-06dfad0] on 2019-11-30; FiPy with ESP32
    Pybytes Version: 1.3.0
    and no debug or startup information about the used file system.
    Is there any command or hack to find out the used file system??
  • @robert-hh In that case "try Roberts discovery arising from his masterful ability to ferret out these pearls from the great pile of info, much of it no longer current."
  • Many thanks @robert-hh! There was no filesystem before! I did
    pycom-fwtool-cli.exe --port COM9 erase_all
    before flashing the firmware. So the only thing / information about the Filesystem should be the preset / default in the firmware. I assume that it is respected while using
    even when there is no information / option in pycom-fwtool-cli.exe to use a specific file system.
    Ok I found in your link https://development.pycom.io/firmwareapi/pycom/pycom/
    Note: When the firmware is built with option FS_USE_LITTLEFS the file system for /flash is forced to be LittleFS.
  • @Clemens If a LittleFS filesystem was on the device before firmware upgrade, it will not be touched. You have to erase the device to get the new selection in place. Or you may manually use
    pycom.bootmgr(fs_type=pycom.LittleFS)
    and then reboot. About pycom.bootmgr(), look here:
  • Many thanks! In fact the command puts out:
    >>> import pycom; pycom.bootmgr()
    ('Factory', 'LittleFS', 'SafeBoot: False', 'Status: Ready')
    I had a discussion with @andreas yesterday about the issue and used the same firmware image with the GUI. In the GUI I have choosen FatFS for testing:
    alt text
    There is a remark "if supported" on the screen but I got this confirmation "File system type set to FatFS" after flashing:
    alt text
    So I assume FatFS was used. But on the REPL you see ...
    Something must be wrong in the end, the output of the GUI "File system type set to FatFS" or the output of pycom.bootmgr(). :-/
    Btw I did not found any information via pycom-fwtool-cli --help but this thread may be interesting: https://forum.pycom.io/topic/5375/using-pycom-fwtool-cli/
  • @kjm No trick, just reading the instructions.
  • Try Roberts trick....
1 out of 7
