    Guru Meditation Error
    58 Posts 7 Posters 2.9k Views 7 Watching
      sita @robert-hh
      Thanks for response but i am not fully aware of pybytes_config.json. I just placed a file on the device and in that file i have kept { "pybytes_autostart": false }.
      I got response like this(shown in the below image). I am not sure whether it is right or wrong!!!
      Could i get any document or web link related to this issue so that i will do accordingly.
      Thanks in advance
        robert-hh @sita
        @sita That's fine now. Pybytes does not start, and the AP should be enabled. If you use Pybytes, then you might set that to true again. I have not documentation about the mechanism. I had to reverse-engineer that method of disabling. Pycom also did not say or write anything about it. It seems very unfriendly to push it's customers into a non-working configuration.
          sita @robert-hh
          @robert-hh Thanks for the information. After adding that pybytes_config.json file also i am not received data,only getting this message(shown in the below fig). My project is mainly focusing on the received data and i have to analyze it. so could you please help me with this problem.
          Thanks in advance
            robert-hh @sita
            @sita Please check, that:
            a) you have set both device to the same communication parameters, like frequency, spreading factor, bandwidth
            b) that you use the right antenna connector
            c) that you start both device with power-up or hard reset.
              sita @robert-hh
              @robert-hh Thanks for the immediate response.
              I have checked all the parameters and they are same for both the devices. And i have connected antennas also right way,still i am not reeving any data and getting same problem again (Guru Meditation Error: Core 0 panic'ed) :(
              one more problem is the below one is not working for factory reset.
              os.mkfs('/flash')
              one question is , if i downgrade the firmware is there any use ?? if so which version is preferable ?
                robert-hh @sita
                @sita The best method for a factory reset is performing a full flash erase using esptool.py.
                Using a previous firmware release will get you away from the pybytes stuff. Since the flash use between v1.20.x and the previous ones has changed, a flash erase is useful anytime you cross that version border.
                  andreas
                  Dear @sita,
                  others are observing similar things on the LoPy4, even with the Dragonfly builds [1]. Are there any chances you could share the MicroPython code and respective core dumps you are receiving while running Dragonfly?
                  Regarding
                  Smart Provisioning started in the background.
                  Are you sure you have been running the vanilla Dragonfly build here? It actually looks like a Pybytes variant. Please try again using the vanilla variant.
                  Thanks already and with kind regards,
                  Andreas.
                  [1] https://community.hiveeyes.org/t/core-panics-with-the-dragonfly-build-on-the-lopy4/2878
                    sita @andreas
                    Hello @andreas,
                    i have done the procedure according to [1] and vanilla Dragonfly build also done again. Now it is working fine, data also receiving now. :):)
                    Thank you once again for the immediate responses.
                      andreas
                      @sita said in Guru Meditation Error:
                      Thanks for letting me know. Please tell me if things are still stable after longer runtimes.
                        sita @andreas
                        Hello @andreas,
                        I got an issue again with this Guru meditation error. While sending the data suddenly this error is coming, if i switch off and on the battery data is transferring normally. Because of this discontinuity i am not able to calculate the packet loss. Is there any solution for this ?
                          andreas @sita
                          Dear @sita,
                          @andreas said in Guru Meditation Error:
                          If core panics are still happening, I will be happy to receive respective core dumps from it. If you could share the MicroPython code it would even be better in order to reproduce the problem.
                          With kind regards,
                          Andreas.
                            sita @andreas
                            @andreas
                            Below is the coredump that i got in my Atom IDE for the guru meditation error.
                            rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
                            configsip: 0, SPIWP:0xee
                            mode:DIO, clock div:1
                            load:0x3fff8020,len:8
                            load:0x3fff8028,len:2136
                            load:0x4009fa00,len:19860
                            entry 0x400a05d0
                            Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                            Core 1 register dump:
                            PC      : 0x400933c3  PS      : 0x00060033  A0      : 0x80092079  A1      : 0x3ffbf060
                            A2      : 0x3ffbb8d8  A3      : 0x00060023  A4      : 0x3ffc44a4  A5      : 0x00000001
                            A6      : 0x000000fe  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x3ffbb8d8
                            A10     : 0x3ffbb8d8  A11     : 0x00000000  A12     : 0x800fd97c  A13     : 0x3ffd79a0
                            A14     : 0x3f403ce4  A15     : 0x00000002  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                            EXCVADDR: 0x00000004  LBEG    : 0x400ecf08  LEND    : 0x400ecf4b  LCOUNT  : 0x00000000
                            Core 1 was running in ISR context:
                            EPC1    : 0x400933c3  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x40087b2e
                            Backtrace: 0x400933c3:0x3ffbf060 0x40092076:0x3ffbf080 0x40090a0d:0x3ffbf0a0 0x40089529:0x3ffbf0c0 0x40083be9:0x3ffbf100 0x400ff4ac:0x3ffd7930 0x400e6a17:0x3ffd7950 0x401014de:0x3ffd7980 0x400fd90d:0x3ffd79a0 0x400fd979:0x3ffd79c0 0x4010991b:0x3ffd79e0 0x401015d4:0x3ffd7a80 0x400fd90d:0x3ffd7ab0 0x400fd93a:0x3ffd7ad0 0x400e1aa5:0x3ffd7af0 0x400e1d35:0x3ffd7b90 0x400e0799:0x3ffd7bb0
                            7DIAABAAAABsAQAA
                            /B39PwAc/T/0Hf0/
                            ABz9P5Ad/T9KhAAAaEH8P2hB/D/8Hf0/YEH8PxMAAABmozd+Dukx8vwd/T8AAAAA
                            BgAAAPgN/T9Mb1JhAK29WrtYZS52oIoAAQAAAPQd/T8AAAAAIQAGAAYAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                            n5JAPwAAAACokQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJbrrw==
                            hDkIQC4ZCUAwDQYA8CQRgMAc/T9KhAAAaPX7P9gX/j8AAAAAAAAAAAAAAAAuGQmA
                            oBz9PwEAAABKhAAA/B39PwEAAAD+AAAAEAAAAA4AAACLVgiAgBz9PwKKCUANiglA
                            AAAAAIQ7CEABAAAABC0JQFgu+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAEBA/D8BAAAA/gAAAAEAAAAAAAAA4Bz9P3iY/D8Mmfw/
                            2Bf+PwAAAAAAAAAAAAAAAAAAAACQHf0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                            AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAACEOwhAAAAAAAQtCUBYLvo/AAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAGNM5gEAAAAAAAAAAAAAAABQQEE//BL8PwyZ/D+h////
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnB39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                            8Kn9P4Co/T/oqf0/
                            gKj9P4Cp/T9KhAAAVEH8P1RB/D/wqf0/TEH8PxQAAADMMf4/zDH+P/Cp/T8AAAAA
                            BQAAAOyZ/T9TZXJ2ZXJzAHLAyj+H2LwAAQAAAOip/T8AAAAAIQAGAAUAAAAAAAAA
                            vH/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALrJPQ==
                            hDkIQC4ZCUAwDQYA4AgOgECp/T9KhAAAaPX7PwIAAAAA/wAAAAD/AAAAAP8uGQmA
                            IKn9PwEAAABKhAAA8Kn9PwEAAAD+AAAAIwAGAAAAAACfCA6AMKn9P2iICUCEiAlA
                            /////4Q7CEABAAAABC0JQEi6+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAABgqf0/TPf7PwAAAAAAAAAAYKn9PwAAAAABAAAA
                            OG5APwD/AAAAAP8AAAAA/wAAAACAqf0/AAAAAAAAAAAAAAAAAQAAAB5J/D8AAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjKn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            vLj7P5C2+z+0uPs/
                            kLb7P1C4+z+7TnWgOL77P/BA/D+8uPs/6ED8PxkAAADYuPs/2Lj7P7y4+z8AAAAA
                            AAAAALi0+z9JRExFMACSxHiuLBjBQ1kAAAAAALS4+z8AAAAAIAcGAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzi2A==
                            hDkIQFALCUAwDwYA1HcWgFC3+z+02vs/AAAAAADb+z8AAAAAtNr7PwEAAABQCwmA
                            MLf7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAAAoAAACEOQhAtGUgQAjPDkBLzw5A
                            AAAAAIQ7CEDcQvw/BC0JQBjJ+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAOC3+z8AAAAAAAAAAAAAAABdzw6AkLf7PwEAAABAAAAA
                            AAAAAIOEAAAAAAAAAAAAAP////8AgAAA//8AgAoAAADgt/s/AAAAAAjPDkBLzw5A
                            KDsPgMC3+z8AAAAAAQAAAAAAAAAoYPU/yJD8PwAAAAAYAAAAAAAAALzj/T8BAAAA
                            TMUWgOC3+z+wkPw/AQAAAAAAAAAJAAAAAIAAAP//AIAMGwmAALj7PwAAAAABAAAA
                            AAAAAKCu+z8g9fs/IAgGAAAAAAAguPs/AAAAAHhA/D8AAAAASNv8P9xC/D8AAAAA
                            AAAAAFC4+z8AAAAAAAAAAGj1+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXLj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            ML77P5C8+z8ovvs/
                            kLz7P8C9+z8tlv+U8ED8P8S4+z8wvvs/6ED8PxkAAAA2AEMQSyhLiTC++z8AAAAA
                            AAAAACy6+z9JRExFMQDeKCrXPFVSqsEAAQAAACi++z8AAAAAIwAGAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACiJA==
                            hDkIQLJtIEAwCwYAXsUWgFC9+z8AAAAA8ED8PzMCCYCAvPs/AwAAACMABgAjAAYA
                            kPD7PyAAAAAgAAAA//8/s6urAAADAAAAIwAGAAAAAACQvfs/AAAAAAAAAAAAAAAA
                            AAAAAIQ7CECrqwAABC0JQIjO+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAACEOwhASNv8PwQtCUAMGwmAcL37PyAAAAABAAAA
                            //8/swAAAAAAAAAAAAAAAAAAAACQvfs/AAAAAHhA/D8gAAAASNv8P+BC/D8AAAAA
                            AAAAAMC9+z8AAAAAAAAAAGj1+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzL37PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            bNX7P0Cq+z88rPs/
                            QKr7P9Cr+z/IhAAA3ED8P+w6/T9s1fs/1ED8PwcAAADA1Ps/wNT7P2zV+z+41Ps/
                            EgAAAECe+z90aVQAEgAAAAAAAAAAAAAAAAAAADys+z8AAAAAIQAGABIAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                            hDkIQFALCUAwDwYAeYgYgACr+z+U1Ps/oKv7P+DU+z8AAAAA6NT7PwAAAABQCwmA
                            4Kr7PwAAAABkAAAAaPX7P9xC/D/+AAAAAAAAABAAAAABAAAA/gAAAM19GEDWfRhA
                            AAAAAIQ7CEDcQvw/BC0JQJi8+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAALwIGIAQq/s/HOtBPwAAAAB7ChiAQKv7P/////+gq/s/
                            AAAAAGSEAABkAAAAzAkYQGQAAAAAq/s//gAAAAAAAADEChiAUKv7PxAAQj9sYfs/
                            Y5QXgHCr+z/A3vw/oKv7P2OUF4Bwq/s/wN78P6Cr+z9kAAAA/////2SEAAAAAAAA
                            AAAAAKCr+z9EqRdAAAAAAMwJGEAQAEI/RKkXQAAAAABY5fw/WOX8P1Tl/D9U5fw/
                            AAAAANCr+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Kv7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            5Dr9P9A4/T/cOv0/
                            0Dj9P3A6/T+EhAAAdNX7P9xA/D/kOv0/1ED8PxMAAACMQ/ta1QwgEuQ6/T8AAAAA
                            BgAAAOAs/T9TaWdmb3gAJvt6AwCUiIMAAAAAANw6/T8AAAAAIQAGAAYAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANKNuw==
                            hDkIQC4ZCUAwAQYAmtMegJA5/T+EhAAAaPX7P9Am/j8AAAAAAAAAAAAAAAAuGQmA
                            cDn9PwAAAACEhAAA5Dr9PwEAAAD+AAAAIwAGABEAAAA4S/o/AAAAAAAAAAAAAAAA
                            AAAAAIQ7CEABAAAABC0JQDhL+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAsDn9P4Do/D986Pw/
                            0Cb+PwAAAAAAAAAAAAAAAAAAAABwOv0/AAAAAAAAAACEOQhAgNMeQDAABQAAAAAA
                            cDr9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            OEv6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHw6/T8AAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                            nMr7P0DJ+z+Uyvs/
                            QMn7PzDK+z8AAAAAyED8P8hA/D+cyvs/wED8Pw8AAADMv/s/zL/7P5zK+z/Ev/s/
                            CgAAAJjA+z9UbXIgU3ZjAPqsJsW66/YAAAAAAJTK+z8AAAAAIQAGAAoAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACQ6JA==
                            hDkIQFUrCUAwAAYAAAAAAADK+z8AAAAAAAAAAAAAAADsQvw/5EL8PwoAAABVKwmA
                            4Mn7PwAAAABo9fs/QED8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAIQ7CEAAAAAABC0JQPja+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAPja+D8AAAAAAAAAAAAAAAAAAAAAMMr7PwAAAAAAAAAA
                            AAAAAAAAAAA8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAA==
                            vLz9PyC7/T+0vP0/
                            ILv9P1C8/T8AAAAAUML9P2zY+z+8vP0/ZED8PxQAAADUvP0/AAAAALy8/T8AAAAA
                            BQAAALis/T9Tb2NrZXQgT3BlcmF0aW8AAQAAALS8/T8AAAAAIQAGAAUAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAJrz0g==
                            hDkIQPC/AEAwAAYAOhQJgOC7/T8AAAAAIwAGACAABgAwe/0/VQAAAFCZ/T///z+z
                            q6sAACD1+z8jAAYAvLz9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                            AAAAAIQ7CEABAAAABC0JQBjN+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmA8Lv9P2j1+z8GAAAA
                            5mQOgBC8/T8BAAAA4EL8P7y8/T8BAAAA/gAAALCd+z8AAAAAMLz9PwAAAAAAAAAA
                            3EL8P2j1+z9QQPw/VEH8PwAAAABQvP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXLz9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            SML9P6Dh/T+04/0/
                            oOH9P1Dj/T8AAAAAKHz7P8S8/T9Iwv0/ZED8Pw4AAACMq/0/jKv9P0jC/T+Eq/0/
                            CwAAALjD/T9JUlFzAAAAAAAAAAAAAAAAAQAAALTj/T8AAAAAIQAGAAsAAAAAAAAA
                            AAAAAOzi/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ==
                            hDkIQFALCUAwBQYAGD4PgGDi/T9gq/0/AOP9P6yr/T8AAAAAtKv9PwAAAABQCwmA
                            QOL9PwEAAAD/////aPX7P9xC/D/+AAAAAAAAAAAAAAAY9Po/AAAAAAAAAAAAAAAA
                            AAAAAIQ7CEDcQvw/BC0JQBj0+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAABCAAAApaWlpaWlpaWUDg6AoOL9PziR/D8A4/0/
                            AAAAAGEAAAClpaWlpaWlpf////+g4v0/ZJT8PwDj/T8AAAAAAQAAACyR/D9EEfw/
                            AAAAADDj/T8skfw/AAAAAFDj/T8AAAAAAAAAAAAAAAAAAAAALJH8PwAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4/0/
                            ABwAAAST/D8Ek/w/AAAAABj0+j8AAAAAAAAAAAAAAAAEk/w/CgAAAFBA/D/MQfw/
                            AAAAAFDj/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAABc4/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAA==
                            IHz7P7Cc+z84nvs/
                            sJz7P9Cd+z+DtIl4pLL7P1DC/T8gfPs/ZED8PwEAAAD0e/s/9Hv7PyB8+z/se/s/
                            GAAAADya+z9pcGMxAJ0FQOZBwVEXuaIAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAyuRg==
                            hDkIQFALCUAwBQYAECAIgHCd+z/Ie/s/AAAAABR8+z8AAAAAyHv7PwAAAABQCwmA
                            UJ37PwEAAAD/////aPX7P9xC/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAIQ7CEDcQvw/BC0JQJiu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAACB8+z8BAAAA/gAAACMABgAAAAAAsJ37P7w//D8AAAAA
                            AAAAANQEAAD+AAAAIAMGAP////8AAAAAvD/8P6g//D/wdfs/AAAAAAEAAAAAAAAA
                            AAAAANCd+z8AAAAAAAAAAPB6CEABAAAAAAAAAAAAAAC9FAiAgH3+PwABAADoDQBA
                            AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAA=
                            nLL7PzCI/T/gif0/
                            MIj9P4CJ/T8BAAAAeCv9Pyh8+z+csvs/ZED8PwUAAABwrPs/cKz7P5yy+z9orPs/
                            FAAAAOR9/T9ldmVudFRhc2sAAAAAAAAAAAAAAOCJ/T8AAAAAIQAGABQAAAAAAAAA
                            KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                            hDkIQFALCUAwAgYAPMQWgPCI/T9ErPs/MIn9P5Cs+z8AAAAAmKz7PwAAAABQCwmA
                            0Ij9PwAAAAD/////aPX7P9xC/D/+AAAAIAAGAAAAAADQiP0/3Ij9P2iICUCEiAlA
                            /////4Q7CEDcQvw/BC0JQEia+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAAMIn9PwDb/D8AAAAA
                            AAAAAAwFAAD+AAAAIAAGAP////8wif0/ANv8PwAAAACQrPs/AAAAAGiy+z8BAAAA
                            AAAAAICJ/T8AAAAAAAAAAA4AAADAQfs/AQEAANT1/D8GAAAAzgi8P///AAA0BgAA
                            vH5BPzwAAAACAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAACMif0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            cCv9P8Ap/T9oK/0/
                            wCn9PwAr/T+8srNtYHr7P6Sy+z9wK/0/ZED8PxEAAABccboJBQl95HAr/T8AAAAA
                            CAAAAGwf/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAGgr/T8AAAAAIQAGAAgAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAHBlyA==
                            hDkIQPC/AEAwAAYAOhQJgIAq/T8AAAAAIwAGACAABgAgcP0/AwAAACMLBgD//z+z
                            q6sAACD1+z8jAAYAcCv9PwEAAAD+AAAAAQAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                            AAAAAIQ7CEABAAAABC0JQMg7+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmAkCr9P2j1+z8HAAAA
                            3Q8RgLAq/T8BAAAA4EL8P3Ar/T8BAAAA/gAAACALBgAAAAAA0Cr9PwAAAAAAAAAA
                            3EL8P2j1+z9QQPw/kEH8PwAAAAAAK/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwr/T8AAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                            WHr7P9B4+z9Qevs/
                            0Hj7P/B5+z9bG56ThHL7P3gr/T9Yevs/ZED8PwEAAAAodvs/KHb7P1h6+z8gdvs/
                            GAAAAFR2+z9pcGMwAKcnkoDUgBY5q6QAAAAAAFB6+z8AAAAAIQAGABgAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOCIJQ==
                            hDkIQFALCUAwAQYAECAIgJB5+z/8dfs/AAAAAEh2+z8AAAAA/HX7PwAAAABQCwmA
                            cHn7PwAAAAD/////aPX7P9xC/D/+AAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAIQ7CEDcQvw/BC0JQLiK+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAGj1+z/cQvw//gAAAAEAAAAAAAAA0Hn7P7g//D8AAAAA
                            AAAAAGELAAD+AAAAAQAAAP////8AAAAAuD/8P6g//D9Idvs/AAAAAPx1+z8AAAAA
                            AAAAAPB5+z8AAAAAAAAAAPB6CEAAAAAAAAAAAAAAAAAhFAiAMDz+P0xA/D+XdEA/
                            AAAAAAAAAAD8efs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            fHL7P/Bw+z90cvs/
                            8HD7PxBy+z+3laR7TEP7P2B6+z98cvs/ZED8PwMAAAA4P/w/OD/8P3xy+z8wP/w/
                            FgAAAHhm+z9lc3BfdGltZXIA/0uahkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZfvg==
                            hDkIQFALCUAwAQYAkCMNgLBx+z8MP/w/AAAAAFg//D8AAAAADD/8PwAAAABQCwmA
                            kHH7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAAAAAAAD/////hDsIQGiICUCEiAlA
                            /////4Q7CEDcQvw/BC0JQNiC+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAKkYCICwcfs/MPX7PwAAAAAAAAAA8HH7P2Q//D9sP/w/
                            AAAAAECEAAD+AAAAAAAAAP/////wcfs//F77P2w//D939AcCOPX7P3f0BwIAAAAA
                            AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAYD/8P2w//D8AAAAAAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAccvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                            AAAAAA==
                            REP7P3BB+z88Q/s/
                            cEH7P9BC+z+zJhymbED8P4Ry+z9EQ/s/ZED8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                            FwAAAEA1+z93aWZpALqbfav+sgPU8R4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                            hDkIQFALCUAwDwYAecIWgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAABQCwmA
                            EEL7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAABwAAACZ6xOAUEL7P2iICUCEiAlA
                            /////4Q7CEDcQvw/BC0JQJhT+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAKviFIBAQvs/AAAAAJCZCEBtxyCAcEL7P1Au+z+gQvs/
                            AAAAAEKEAADwIgzAACAMAP////9sE/w/iLT8PwAAAAAAAAAAkEL7P2wT/D94FPw/
                            AAAAAJBC+z9sE/w/eBT8P/////8AAAAAxAAAAHgG/D8AAAAA0EL7PwAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAWAP9PxoAAABwE/w/
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            ZNj7P1CY/T/kmf0/
                            UJj9P4CZ/T/E2Ps/xLz9P2xA/D9k2Ps/ZED8PxQAAACI2Ps//////2TY+z8AAAAA
                            BQAAAOiJ/T9TbWFydENvbmZpZwABAAAAAQAAAOSZ/T8AAAAAIQAGAAUAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                            hDkIQPC/AEAwAAYAOhQJgBCZ/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                            q6sAACD1+z8jAAYAZNj7PwEAAAD+AAAARAEAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                            AAAAAIQ7CEABAAAABC0JQEiq+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmAIJn9P2j1+z8FAAAA
                            D3QOgECZ/T8BAAAA4EL8P2TY+z8BAAAA/gAAACADBgAAAAAAYJn9PwAAAAAAAAAA
                            3EL8P2j1+z9QQPw/VEH8PwAAAACAmf0/AAAAAAAAAAAATvw/AAAAAAAAAAAAAAAA
                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjJn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                            E (9009) esp_core_dump: Skipped 1 tasks with bad TCB!
                            E (9014) esp_core_dump: Crashed task has been skipped!
                            Rebooting...
                            ets Jun  8 2016 00:22:57
                            I'm trying to send loraraw data packets with GPS, timestamp along with a integer( to calculate the packet loss) in them. Once the data is sent, the same will also be stored in the SD card. After no fixed amount of time, the sender module crashes with guru meditation error, but will restart itself to send the data packets. So i'm seeing a break in the integer number, which will restart from 0 after this error. The sender module code that I wrote is as follows:
                            import math
                            import network
                            import utime
                            import gc
                            import ustruct
                            #from machine import RTC
                            from machine import SD
                            from L76GNSS import L76GNSS
                            from pytrack import Pytrack
                            from network import LoRa
                            from math import ceil
                            sd = SD()
                            os.mount(sd, '/sd')
                            os.listdir('/sd')
                            #time.sleep(2)
                            gc.enable()
                            py = Pytrack()
                            l76 = L76GNSS(py)
                            lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, frequency=433000000, power_mode=LoRa.ALWAYS_ON, tx_power=10, bandwidth=LoRa.BW_125KHZ, sf=8, preamble=8, coding_rate=LoRa.CODING_4_8)
                            # create a raw LoRa socket
                            i = 0
                                coord = l76.coordinates()
                                gps_datetime = l76.get_datetime()
                                lat,lon = coord
                                timestamp =('20' + gps_datetime[4][4] + gps_datetime[4][5]+gps_datetime[4][2] + gps_datetime[4][3]+gps_datetime[4][0] + gps_datetime[4][1]+gps_datetime[2][0] + gps_datetime[2][1]+gps_datetime[2][2] + gps_datetime[2][3]+gps_datetime[2][4] + gps_datetime[2][5] )
                                #s.setblocking(True)
                                value = i
                                message = ''+str(lat)+','+str(lon)+','+str(timestamp)+','+str(value)
                                pycom.heartbeat(True)
                                s.send(message)
                                i = i+ 1
                                print(message)
                                pycom.heartbeat(False)
                                pycom.rgbled(0xff00)
                                f = open('/sd/A_3001SF8.txt', 'a+')
                                f.write(message)
                                f.write(' ')
                                f.write('\n')
                                f.close()
                            Kindly please have a look into this issue and guide me so i can continue my work to calculate the packet loss etc., Thanks a lot in advance and have a nice day.
                            Best Regards,
                            Sita
                              pigamonte
                              I am also seeing Guru Meditation Errors with latest firmware v1.20.1.r2 and vanilla releases.
                              Here's just a few:
                              Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception)
                              Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
                              The code makes heavy use of the UARTs and runs flawlessly on desktop.
                                andreas
                                Dear @sita,
                                decoding the core dump shows (without guarantee):
                                ==================== CURRENT THREAD STACK =====================
                                #0  0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                                #1  0x401124f0 in lora_join (n_args=1073518712, pos_args=0x3ffc990c <lora_partial_rx_packet+12>, kw_args=0x401124f0 <lora_join+16>) at mods/modlora.c:1843
                                ======================== THREADS INFO =========================
                                  Id   Target Id         Frame
                                  16   process 15        0x4000bff0 in ?? ()
                                  15   process 14        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073426000, uxInitialCount=1073431200, pxStaticQueue=0x3ffb2e9c) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  14   process 13        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073495820, uxInitialCount=0, pxStaticQueue=0x3ffc3f58 <vflash_mem+1900>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  13   process 12        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073444348, uxInitialCount=0, pxStaticQueue=0x3ffb7648) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  12   process 11        0x4000bff0 in ?? ()
                                  11   process 10        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073458244, uxInitialCount=1073580336, pxStaticQueue=0x3ffbac90) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  10   process 9         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073445832, uxInitialCount=0, pxStaticQueue=0x3ffb7c14) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  9    process 8         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073589088, uxInitialCount=1073603328, pxStaticQueue=0x3ffdabac) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  8    process 7         0x4000bff0 in ?? ()
                                  7    process 6         0x40092b55 in xTaskNotify (xTaskToNotify=0x0, ulValue=<optimized out>, eAction=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4872
                                  6    process 5         0x4009192e in vTaskExitCritical (mux=0x8484) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                                  5    process 4         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073468564, uxInitialCount=1073458080, pxStaticQueue=0x3ffbd4e0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  4    process 3         0x40206db2 in API_vhci_host_check_send_available ()
                                  3    process 2         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073470132, uxInitialCount=0, pxStaticQueue=0x3ffbdb00) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                                  2    process 1         0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                                * 1    <main task>       0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                                So, it seems to happen while performing lora_join within mods/modlora.c.
                                // check for the correct lora radio mode
                                if (lora_obj.stack_mode != E_LORA_STACK_MODE_LORAWAN) {
                                    nlr_raise(mp_obj_new_exception_msg(&mp_type_OSError, mpexception_os_request_not_possible));
                                I assume this is some synchronization issue wrt. the code is already doing other things.
                                Maybe waiting for successfully joining the LoRaWAN network helps like outlined within [1] before doing other operations.
                                Forget about my last words. I believe this is wrong as I've probably used the wrong application.elf file for decoding the core dump -- see next post(s).
                                I just recognized you are using pure LoRa instead of LoRaWAN....
                                ... so who should be actually invoking lora_join anyway ;].
                                With kind regards,
                                Andreas.
                                P.S.: To be safe that the core dump decoding gives us the correct results: Are you using lopy4-vanilla-dragonfly-onewire or lopy4-vanilla-dragonfly-onewire-i2s?
                                  andreas @sita
                                  What baffles me is that [1] shows:
                                  Drawing a conclusion from that, might it be that lora_join is not advisable when doing raw LoRa as outlined within your code
                                  But who is actually invoking lora_join anyway?
                                  With kind regards,
                                  Andreas.
                                  [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L1841-L1844
                                    andreas @andreas
                                    I have to admit I didn't keep track of the application.elf files coming out of my builds which are required to properly decode the core dumps. May I humbly ask you to try again using LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz?
                                      andreas
                                      I've tried to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly-modonewire-i2s firmware which shows the core dump is happening here:
                                      #1  0x401124f0 in lora_bandwidth (n_args=<optimized out>, args=0x3ffc990c <lora_partial_rx_packet+12>) at mods/modlora.c:2117
                                      See also [1]. I believe this is also due to a erroneous core dump decoding, so nevermind.
                                      I have now kept the application.elf file for the new build LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. If you are able to catch another core dump when running this firmware, we would probably get correct results. Sorry for the extra mile.
                                      [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L2116-L2118
                                      S 3 Replies Last reply Reply Quote 0
                                        andreas
                                        Another attempt by trying to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly firmware without support for 1-Wire and I2S.
                                        #0  0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                                        #1  0x401124f0 in ?? ()
                                        Backtrace stopped: previous frame identical to this frame (corrupt stack?)
                                          Id   Target Id         Frame
                                          15   process 14        xQueueGenericSend (xQueue=0x3ffb2e50, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          14   process 13        xQueueGenericSend (xQueue=0x3ffc3f0c <vflash_mem+1840>, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          13   process 12        xQueueGenericSend (xQueue=0x3ffb75fc, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          11   process 10        xQueueGenericSend (xQueue=0x3ffbac44, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          10   process 9         xQueueGenericSend (xQueue=0x3ffb7bc8, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          9    process 8         xQueueGenericSend (xQueue=0x3ffdab60, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          7    process 6         0x40092b55 in vTaskNotifyGiveFromISR (xTaskToNotify=0x0, pxHigherPriorityTaskWoken=0x0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:5044
                                          6    process 5         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x8484, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                                          5    process 4         xQueueGenericSend (xQueue=0x3ffbd494, pvItemToQueue=<optimized out>, xTicksToWait=100, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          4    process 3         0x40206db2 in littleFsErrorToErrno (littleFsError=393251) at littlefs/vfs_littlefs.c:175
                                          3    process 2         xQueueGenericSend (xQueue=0x3ffbdab4, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                                          2    process 1         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                                        * 1    <main task>       0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                                        Looking at
                                        here.
                                          andreas @sita
                                            f.write(message)
                                            f.write(' ')
                                            f.write('\n')
                                            f.close()
                                          Could you stop opening and closing the file within such a tight loop? You might want to time.sleep_ms() for at least some milliseconds between iterations. To be safe, try to use longer intervals first and get shorter if things might become more stable.
                                          When being at it, you might also want to think about optimizing things using a single write call like f.write(message + ' \n').
                                            sita @andreas
                                            Hello @andreas,
                                            Thanks for the information. I kept time.sleep_ms(10) in the loop and will change f.write as you said.I will do the the experiment again and let you know if i got same again.
                                            Thanks once again.
                                            Have a nice day
                                            • 1 / 3
