    Guru Meditation Error
    58 Posts 7 Posters 2.9k Views 7 Watching
      andreas
      Dear @sita,
      others are observing similar things on the LoPy4, even with the Dragonfly builds [1]. Are there any chances you could share the MicroPython code and respective core dumps you are receiving while running Dragonfly?
      Regarding
      Smart Provisioning started in the background.
      Are you sure you have been running the vanilla Dragonfly build here? It actually looks like a Pybytes variant. Please try again using the vanilla variant.
      Thanks already and with kind regards,
      Andreas.
      [1] https://community.hiveeyes.org/t/core-panics-with-the-dragonfly-build-on-the-lopy4/2878
        sita @andreas
        Hello @andreas,
        i have done the procedure according to [1] and vanilla Dragonfly build also done again. Now it is working fine, data also receiving now. :):)
        Thank you once again for the immediate responses.
          andreas
          @sita said in Guru Meditation Error:
          Thanks for letting me know. Please tell me if things are still stable after longer runtimes.
            sita @andreas
            Hello @andreas,
            I got an issue again with this Guru meditation error. While sending the data suddenly this error is coming, if i switch off and on the battery data is transferring normally. Because of this discontinuity i am not able to calculate the packet loss. Is there any solution for this ?
              andreas @sita
              Dear @sita,
              @andreas said in Guru Meditation Error:
              If core panics are still happening, I will be happy to receive respective core dumps from it. If you could share the MicroPython code it would even be better in order to reproduce the problem.
              With kind regards,
              Andreas.
                sita @andreas
                @andreas
                Below is the coredump that i got in my Atom IDE for the guru meditation error.
                rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff8020,len:8
                load:0x3fff8028,len:2136
                load:0x4009fa00,len:19860
                entry 0x400a05d0
                Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                Core 1 register dump:
                PC      : 0x400933c3  PS      : 0x00060033  A0      : 0x80092079  A1      : 0x3ffbf060
                A2      : 0x3ffbb8d8  A3      : 0x00060023  A4      : 0x3ffc44a4  A5      : 0x00000001
                A6      : 0x000000fe  A7      : 0x00000000  A8      : 0x00000000  A9      : 0x3ffbb8d8
                A10     : 0x3ffbb8d8  A11     : 0x00000000  A12     : 0x800fd97c  A13     : 0x3ffd79a0
                A14     : 0x3f403ce4  A15     : 0x00000002  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                EXCVADDR: 0x00000004  LBEG    : 0x400ecf08  LEND    : 0x400ecf4b  LCOUNT  : 0x00000000
                Core 1 was running in ISR context:
                EPC1    : 0x400933c3  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x40087b2e
                Backtrace: 0x400933c3:0x3ffbf060 0x40092076:0x3ffbf080 0x40090a0d:0x3ffbf0a0 0x40089529:0x3ffbf0c0 0x40083be9:0x3ffbf100 0x400ff4ac:0x3ffd7930 0x400e6a17:0x3ffd7950 0x401014de:0x3ffd7980 0x400fd90d:0x3ffd79a0 0x400fd979:0x3ffd79c0 0x4010991b:0x3ffd79e0 0x401015d4:0x3ffd7a80 0x400fd90d:0x3ffd7ab0 0x400fd93a:0x3ffd7ad0 0x400e1aa5:0x3ffd7af0 0x400e1d35:0x3ffd7b90 0x400e0799:0x3ffd7bb0
                7DIAABAAAABsAQAA
                /B39PwAc/T/0Hf0/
                ABz9P5Ad/T9KhAAAaEH8P2hB/D/8Hf0/YEH8PxMAAABmozd+Dukx8vwd/T8AAAAA
                BgAAAPgN/T9Mb1JhAK29WrtYZS52oIoAAQAAAPQd/T8AAAAAIQAGAAYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                n5JAPwAAAACokQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJbrrw==
                hDkIQC4ZCUAwDQYA8CQRgMAc/T9KhAAAaPX7P9gX/j8AAAAAAAAAAAAAAAAuGQmA
                oBz9PwEAAABKhAAA/B39PwEAAAD+AAAAEAAAAA4AAACLVgiAgBz9PwKKCUANiglA
                AAAAAIQ7CEABAAAABC0JQFgu+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAEBA/D8BAAAA/gAAAAEAAAAAAAAA4Bz9P3iY/D8Mmfw/
                2Bf+PwAAAAAAAAAAAAAAAAAAAACQHf0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAACEOwhAAAAAAAQtCUBYLvo/AAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAGNM5gEAAAAAAAAAAAAAAABQQEE//BL8PwyZ/D+h////
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnB39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                8Kn9P4Co/T/oqf0/
                gKj9P4Cp/T9KhAAAVEH8P1RB/D/wqf0/TEH8PxQAAADMMf4/zDH+P/Cp/T8AAAAA
                BQAAAOyZ/T9TZXJ2ZXJzAHLAyj+H2LwAAQAAAOip/T8AAAAAIQAGAAUAAAAAAAAA
                vH/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALrJPQ==
                hDkIQC4ZCUAwDQYA4AgOgECp/T9KhAAAaPX7PwIAAAAA/wAAAAD/AAAAAP8uGQmA
                IKn9PwEAAABKhAAA8Kn9PwEAAAD+AAAAIwAGAAAAAACfCA6AMKn9P2iICUCEiAlA
                /////4Q7CEABAAAABC0JQEi6+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAABgqf0/TPf7PwAAAAAAAAAAYKn9PwAAAAABAAAA
                OG5APwD/AAAAAP8AAAAA/wAAAACAqf0/AAAAAAAAAAAAAAAAAQAAAB5J/D8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjKn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                vLj7P5C2+z+0uPs/
                kLb7P1C4+z+7TnWgOL77P/BA/D+8uPs/6ED8PxkAAADYuPs/2Lj7P7y4+z8AAAAA
                AAAAALi0+z9JRExFMACSxHiuLBjBQ1kAAAAAALS4+z8AAAAAIAcGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzi2A==
                hDkIQFALCUAwDwYA1HcWgFC3+z+02vs/AAAAAADb+z8AAAAAtNr7PwEAAABQCwmA
                MLf7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAAAoAAACEOQhAtGUgQAjPDkBLzw5A
                AAAAAIQ7CEDcQvw/BC0JQBjJ+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAOC3+z8AAAAAAAAAAAAAAABdzw6AkLf7PwEAAABAAAAA
                AAAAAIOEAAAAAAAAAAAAAP////8AgAAA//8AgAoAAADgt/s/AAAAAAjPDkBLzw5A
                KDsPgMC3+z8AAAAAAQAAAAAAAAAoYPU/yJD8PwAAAAAYAAAAAAAAALzj/T8BAAAA
                TMUWgOC3+z+wkPw/AQAAAAAAAAAJAAAAAIAAAP//AIAMGwmAALj7PwAAAAABAAAA
                AAAAAKCu+z8g9fs/IAgGAAAAAAAguPs/AAAAAHhA/D8AAAAASNv8P9xC/D8AAAAA
                AAAAAFC4+z8AAAAAAAAAAGj1+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXLj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                ML77P5C8+z8ovvs/
                kLz7P8C9+z8tlv+U8ED8P8S4+z8wvvs/6ED8PxkAAAA2AEMQSyhLiTC++z8AAAAA
                AAAAACy6+z9JRExFMQDeKCrXPFVSqsEAAQAAACi++z8AAAAAIwAGAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACiJA==
                hDkIQLJtIEAwCwYAXsUWgFC9+z8AAAAA8ED8PzMCCYCAvPs/AwAAACMABgAjAAYA
                kPD7PyAAAAAgAAAA//8/s6urAAADAAAAIwAGAAAAAACQvfs/AAAAAAAAAAAAAAAA
                AAAAAIQ7CECrqwAABC0JQIjO+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAACEOwhASNv8PwQtCUAMGwmAcL37PyAAAAABAAAA
                //8/swAAAAAAAAAAAAAAAAAAAACQvfs/AAAAAHhA/D8gAAAASNv8P+BC/D8AAAAA
                AAAAAMC9+z8AAAAAAAAAAGj1+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzL37PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                bNX7P0Cq+z88rPs/
                QKr7P9Cr+z/IhAAA3ED8P+w6/T9s1fs/1ED8PwcAAADA1Ps/wNT7P2zV+z+41Ps/
                EgAAAECe+z90aVQAEgAAAAAAAAAAAAAAAAAAADys+z8AAAAAIQAGABIAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                hDkIQFALCUAwDwYAeYgYgACr+z+U1Ps/oKv7P+DU+z8AAAAA6NT7PwAAAABQCwmA
                4Kr7PwAAAABkAAAAaPX7P9xC/D/+AAAAAAAAABAAAAABAAAA/gAAAM19GEDWfRhA
                AAAAAIQ7CEDcQvw/BC0JQJi8+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAALwIGIAQq/s/HOtBPwAAAAB7ChiAQKv7P/////+gq/s/
                AAAAAGSEAABkAAAAzAkYQGQAAAAAq/s//gAAAAAAAADEChiAUKv7PxAAQj9sYfs/
                Y5QXgHCr+z/A3vw/oKv7P2OUF4Bwq/s/wN78P6Cr+z9kAAAA/////2SEAAAAAAAA
                AAAAAKCr+z9EqRdAAAAAAMwJGEAQAEI/RKkXQAAAAABY5fw/WOX8P1Tl/D9U5fw/
                AAAAANCr+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Kv7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                5Dr9P9A4/T/cOv0/
                0Dj9P3A6/T+EhAAAdNX7P9xA/D/kOv0/1ED8PxMAAACMQ/ta1QwgEuQ6/T8AAAAA
                BgAAAOAs/T9TaWdmb3gAJvt6AwCUiIMAAAAAANw6/T8AAAAAIQAGAAYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANKNuw==
                hDkIQC4ZCUAwAQYAmtMegJA5/T+EhAAAaPX7P9Am/j8AAAAAAAAAAAAAAAAuGQmA
                cDn9PwAAAACEhAAA5Dr9PwEAAAD+AAAAIwAGABEAAAA4S/o/AAAAAAAAAAAAAAAA
                AAAAAIQ7CEABAAAABC0JQDhL+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAsDn9P4Do/D986Pw/
                0Cb+PwAAAAAAAAAAAAAAAAAAAABwOv0/AAAAAAAAAACEOQhAgNMeQDAABQAAAAAA
                cDr9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                OEv6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHw6/T8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                nMr7P0DJ+z+Uyvs/
                QMn7PzDK+z8AAAAAyED8P8hA/D+cyvs/wED8Pw8AAADMv/s/zL/7P5zK+z/Ev/s/
                CgAAAJjA+z9UbXIgU3ZjAPqsJsW66/YAAAAAAJTK+z8AAAAAIQAGAAoAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACQ6JA==
                hDkIQFUrCUAwAAYAAAAAAADK+z8AAAAAAAAAAAAAAADsQvw/5EL8PwoAAABVKwmA
                4Mn7PwAAAABo9fs/QED8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAIQ7CEAAAAAABC0JQPja+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAPja+D8AAAAAAAAAAAAAAAAAAAAAMMr7PwAAAAAAAAAA
                AAAAAAAAAAA8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAA==
                vLz9PyC7/T+0vP0/
                ILv9P1C8/T8AAAAAUML9P2zY+z+8vP0/ZED8PxQAAADUvP0/AAAAALy8/T8AAAAA
                BQAAALis/T9Tb2NrZXQgT3BlcmF0aW8AAQAAALS8/T8AAAAAIQAGAAUAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAJrz0g==
                hDkIQPC/AEAwAAYAOhQJgOC7/T8AAAAAIwAGACAABgAwe/0/VQAAAFCZ/T///z+z
                q6sAACD1+z8jAAYAvLz9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAIQ7CEABAAAABC0JQBjN+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmA8Lv9P2j1+z8GAAAA
                5mQOgBC8/T8BAAAA4EL8P7y8/T8BAAAA/gAAALCd+z8AAAAAMLz9PwAAAAAAAAAA
                3EL8P2j1+z9QQPw/VEH8PwAAAABQvP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXLz9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                SML9P6Dh/T+04/0/
                oOH9P1Dj/T8AAAAAKHz7P8S8/T9Iwv0/ZED8Pw4AAACMq/0/jKv9P0jC/T+Eq/0/
                CwAAALjD/T9JUlFzAAAAAAAAAAAAAAAAAQAAALTj/T8AAAAAIQAGAAsAAAAAAAAA
                AAAAAOzi/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ==
                hDkIQFALCUAwBQYAGD4PgGDi/T9gq/0/AOP9P6yr/T8AAAAAtKv9PwAAAABQCwmA
                QOL9PwEAAAD/////aPX7P9xC/D/+AAAAAAAAAAAAAAAY9Po/AAAAAAAAAAAAAAAA
                AAAAAIQ7CEDcQvw/BC0JQBj0+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAABCAAAApaWlpaWlpaWUDg6AoOL9PziR/D8A4/0/
                AAAAAGEAAAClpaWlpaWlpf////+g4v0/ZJT8PwDj/T8AAAAAAQAAACyR/D9EEfw/
                AAAAADDj/T8skfw/AAAAAFDj/T8AAAAAAAAAAAAAAAAAAAAALJH8PwAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4/0/
                ABwAAAST/D8Ek/w/AAAAABj0+j8AAAAAAAAAAAAAAAAEk/w/CgAAAFBA/D/MQfw/
                AAAAAFDj/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAABc4/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAA==
                IHz7P7Cc+z84nvs/
                sJz7P9Cd+z+DtIl4pLL7P1DC/T8gfPs/ZED8PwEAAAD0e/s/9Hv7PyB8+z/se/s/
                GAAAADya+z9pcGMxAJ0FQOZBwVEXuaIAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAyuRg==
                hDkIQFALCUAwBQYAECAIgHCd+z/Ie/s/AAAAABR8+z8AAAAAyHv7PwAAAABQCwmA
                UJ37PwEAAAD/////aPX7P9xC/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAIQ7CEDcQvw/BC0JQJiu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAACB8+z8BAAAA/gAAACMABgAAAAAAsJ37P7w//D8AAAAA
                AAAAANQEAAD+AAAAIAMGAP////8AAAAAvD/8P6g//D/wdfs/AAAAAAEAAAAAAAAA
                AAAAANCd+z8AAAAAAAAAAPB6CEABAAAAAAAAAAAAAAC9FAiAgH3+PwABAADoDQBA
                AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAA=
                nLL7PzCI/T/gif0/
                MIj9P4CJ/T8BAAAAeCv9Pyh8+z+csvs/ZED8PwUAAABwrPs/cKz7P5yy+z9orPs/
                FAAAAOR9/T9ldmVudFRhc2sAAAAAAAAAAAAAAOCJ/T8AAAAAIQAGABQAAAAAAAAA
                KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                hDkIQFALCUAwAgYAPMQWgPCI/T9ErPs/MIn9P5Cs+z8AAAAAmKz7PwAAAABQCwmA
                0Ij9PwAAAAD/////aPX7P9xC/D/+AAAAIAAGAAAAAADQiP0/3Ij9P2iICUCEiAlA
                /////4Q7CEDcQvw/BC0JQEia+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAAMIn9PwDb/D8AAAAA
                AAAAAAwFAAD+AAAAIAAGAP////8wif0/ANv8PwAAAACQrPs/AAAAAGiy+z8BAAAA
                AAAAAICJ/T8AAAAAAAAAAA4AAADAQfs/AQEAANT1/D8GAAAAzgi8P///AAA0BgAA
                vH5BPzwAAAACAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAACMif0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                cCv9P8Ap/T9oK/0/
                wCn9PwAr/T+8srNtYHr7P6Sy+z9wK/0/ZED8PxEAAABccboJBQl95HAr/T8AAAAA
                CAAAAGwf/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAGgr/T8AAAAAIQAGAAgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAHBlyA==
                hDkIQPC/AEAwAAYAOhQJgIAq/T8AAAAAIwAGACAABgAgcP0/AwAAACMLBgD//z+z
                q6sAACD1+z8jAAYAcCv9PwEAAAD+AAAAAQAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAIQ7CEABAAAABC0JQMg7+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmAkCr9P2j1+z8HAAAA
                3Q8RgLAq/T8BAAAA4EL8P3Ar/T8BAAAA/gAAACALBgAAAAAA0Cr9PwAAAAAAAAAA
                3EL8P2j1+z9QQPw/kEH8PwAAAAAAK/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwr/T8AAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                WHr7P9B4+z9Qevs/
                0Hj7P/B5+z9bG56ThHL7P3gr/T9Yevs/ZED8PwEAAAAodvs/KHb7P1h6+z8gdvs/
                GAAAAFR2+z9pcGMwAKcnkoDUgBY5q6QAAAAAAFB6+z8AAAAAIQAGABgAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOCIJQ==
                hDkIQFALCUAwAQYAECAIgJB5+z/8dfs/AAAAAEh2+z8AAAAA/HX7PwAAAABQCwmA
                cHn7PwAAAAD/////aPX7P9xC/D/+AAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAIQ7CEDcQvw/BC0JQLiK+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAGj1+z/cQvw//gAAAAEAAAAAAAAA0Hn7P7g//D8AAAAA
                AAAAAGELAAD+AAAAAQAAAP////8AAAAAuD/8P6g//D9Idvs/AAAAAPx1+z8AAAAA
                AAAAAPB5+z8AAAAAAAAAAPB6CEAAAAAAAAAAAAAAAAAhFAiAMDz+P0xA/D+XdEA/
                AAAAAAAAAAD8efs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                fHL7P/Bw+z90cvs/
                8HD7PxBy+z+3laR7TEP7P2B6+z98cvs/ZED8PwMAAAA4P/w/OD/8P3xy+z8wP/w/
                FgAAAHhm+z9lc3BfdGltZXIA/0uahkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZfvg==
                hDkIQFALCUAwAQYAkCMNgLBx+z8MP/w/AAAAAFg//D8AAAAADD/8PwAAAABQCwmA
                kHH7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAAAAAAAD/////hDsIQGiICUCEiAlA
                /////4Q7CEDcQvw/BC0JQNiC+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAKkYCICwcfs/MPX7PwAAAAAAAAAA8HH7P2Q//D9sP/w/
                AAAAAECEAAD+AAAAAAAAAP/////wcfs//F77P2w//D939AcCOPX7P3f0BwIAAAAA
                AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAYD/8P2w//D8AAAAAAAAAAAAAAAAAAAAA
                AAAAAAAAAAAccvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                AAAAAA==
                REP7P3BB+z88Q/s/
                cEH7P9BC+z+zJhymbED8P4Ry+z9EQ/s/ZED8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                FwAAAEA1+z93aWZpALqbfav+sgPU8R4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                hDkIQFALCUAwDwYAecIWgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAABQCwmA
                EEL7PwAAAAD/////aPX7P9xC/D/+AAAAAAAAABwAAACZ6xOAUEL7P2iICUCEiAlA
                /////4Q7CEDcQvw/BC0JQJhT+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAKviFIBAQvs/AAAAAJCZCEBtxyCAcEL7P1Au+z+gQvs/
                AAAAAEKEAADwIgzAACAMAP////9sE/w/iLT8PwAAAAAAAAAAkEL7P2wT/D94FPw/
                AAAAAJBC+z9sE/w/eBT8P/////8AAAAAxAAAAHgG/D8AAAAA0EL7PwAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAWAP9PxoAAABwE/w/
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                ZNj7P1CY/T/kmf0/
                UJj9P4CZ/T/E2Ps/xLz9P2xA/D9k2Ps/ZED8PxQAAACI2Ps//////2TY+z8AAAAA
                BQAAAOiJ/T9TbWFydENvbmZpZwABAAAAAQAAAOSZ/T8AAAAAIQAGAAUAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                hDkIQPC/AEAwAAYAOhQJgBCZ/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                q6sAACD1+z8jAAYAZNj7PwEAAAD+AAAARAEAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                AAAAAIQ7CEABAAAABC0JQEiq+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCJQmAIJn9P2j1+z8FAAAA
                D3QOgECZ/T8BAAAA4EL8P2TY+z8BAAAA/gAAACADBgAAAAAAYJn9PwAAAAAAAAAA
                3EL8P2j1+z9QQPw/VEH8PwAAAACAmf0/AAAAAAAAAAAATvw/AAAAAAAAAAAAAAAA
                AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjJn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                E (9009) esp_core_dump: Skipped 1 tasks with bad TCB!
                E (9014) esp_core_dump: Crashed task has been skipped!
                Rebooting...
                ets Jun  8 2016 00:22:57
                I'm trying to send loraraw data packets with GPS, timestamp along with a integer( to calculate the packet loss) in them. Once the data is sent, the same will also be stored in the SD card. After no fixed amount of time, the sender module crashes with guru meditation error, but will restart itself to send the data packets. So i'm seeing a break in the integer number, which will restart from 0 after this error. The sender module code that I wrote is as follows:
                import math
                import network
                import utime
                import gc
                import ustruct
                #from machine import RTC
                from machine import SD
                from L76GNSS import L76GNSS
                from pytrack import Pytrack
                from network import LoRa
                from math import ceil
                sd = SD()
                os.mount(sd, '/sd')
                os.listdir('/sd')
                #time.sleep(2)
                gc.enable()
                py = Pytrack()
                l76 = L76GNSS(py)
                lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, frequency=433000000, power_mode=LoRa.ALWAYS_ON, tx_power=10, bandwidth=LoRa.BW_125KHZ, sf=8, preamble=8, coding_rate=LoRa.CODING_4_8)
                # create a raw LoRa socket
                i = 0
                    coord = l76.coordinates()
                    gps_datetime = l76.get_datetime()
                    lat,lon = coord
                    timestamp =('20' + gps_datetime[4][4] + gps_datetime[4][5]+gps_datetime[4][2] + gps_datetime[4][3]+gps_datetime[4][0] + gps_datetime[4][1]+gps_datetime[2][0] + gps_datetime[2][1]+gps_datetime[2][2] + gps_datetime[2][3]+gps_datetime[2][4] + gps_datetime[2][5] )
                    #s.setblocking(True)
                    value = i
                    message = ''+str(lat)+','+str(lon)+','+str(timestamp)+','+str(value)
                    pycom.heartbeat(True)
                    s.send(message)
                    i = i+ 1
                    print(message)
                    pycom.heartbeat(False)
                    pycom.rgbled(0xff00)
                    f = open('/sd/A_3001SF8.txt', 'a+')
                    f.write(message)
                    f.write(' ')
                    f.write('\n')
                    f.close()
                Kindly please have a look into this issue and guide me so i can continue my work to calculate the packet loss etc., Thanks a lot in advance and have a nice day.
                Best Regards,
                Sita
                  pigamonte
                  I am also seeing Guru Meditation Errors with latest firmware v1.20.1.r2 and vanilla releases.
                  Here's just a few:
                  Guru Meditation Error: Core 1 panic'ed (Unhandled debug exception)
                  Guru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
                  The code makes heavy use of the UARTs and runs flawlessly on desktop.
                    andreas
                    Dear @sita,
                    decoding the core dump shows (without guarantee):
                    ==================== CURRENT THREAD STACK =====================
                    #0  0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                    #1  0x401124f0 in lora_join (n_args=1073518712, pos_args=0x3ffc990c <lora_partial_rx_packet+12>, kw_args=0x401124f0 <lora_join+16>) at mods/modlora.c:1843
                    ======================== THREADS INFO =========================
                      Id   Target Id         Frame
                      16   process 15        0x4000bff0 in ?? ()
                      15   process 14        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073426000, uxInitialCount=1073431200, pxStaticQueue=0x3ffb2e9c) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      14   process 13        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073495820, uxInitialCount=0, pxStaticQueue=0x3ffc3f58 <vflash_mem+1900>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      13   process 12        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073444348, uxInitialCount=0, pxStaticQueue=0x3ffb7648) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      12   process 11        0x4000bff0 in ?? ()
                      11   process 10        xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073458244, uxInitialCount=1073580336, pxStaticQueue=0x3ffbac90) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      10   process 9         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073445832, uxInitialCount=0, pxStaticQueue=0x3ffb7c14) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      9    process 8         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073589088, uxInitialCount=1073603328, pxStaticQueue=0x3ffdabac) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      8    process 7         0x4000bff0 in ?? ()
                      7    process 6         0x40092b55 in xTaskNotify (xTaskToNotify=0x0, ulValue=<optimized out>, eAction=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4872
                      6    process 5         0x4009192e in vTaskExitCritical (mux=0x8484) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                      5    process 4         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073468564, uxInitialCount=1073458080, pxStaticQueue=0x3ffbd4e0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      4    process 3         0x40206db2 in API_vhci_host_check_send_available ()
                      3    process 2         xQueueCreateCountingSemaphoreStatic (uxMaxCount=1073470132, uxInitialCount=0, pxStaticQueue=0x3ffbdb00) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:659
                      2    process 1         0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                    * 1    <main task>       0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
                    So, it seems to happen while performing lora_join within mods/modlora.c.
                    // check for the correct lora radio mode
                    if (lora_obj.stack_mode != E_LORA_STACK_MODE_LORAWAN) {
                        nlr_raise(mp_obj_new_exception_msg(&mp_type_OSError, mpexception_os_request_not_possible));
                    I assume this is some synchronization issue wrt. the code is already doing other things.
                    Maybe waiting for successfully joining the LoRaWAN network helps like outlined within [1] before doing other operations.
                    Forget about my last words. I believe this is wrong as I've probably used the wrong application.elf file for decoding the core dump -- see next post(s).
                    I just recognized you are using pure LoRa instead of LoRaWAN....
                    ... so who should be actually invoking lora_join anyway ;].
                    With kind regards,
                    Andreas.
                    P.S.: To be safe that the core dump decoding gives us the correct results: Are you using lopy4-vanilla-dragonfly-onewire or lopy4-vanilla-dragonfly-onewire-i2s?
                      andreas @sita
                      What baffles me is that [1] shows:
                      Drawing a conclusion from that, might it be that lora_join is not advisable when doing raw LoRa as outlined within your code
                      But who is actually invoking lora_join anyway?
                      With kind regards,
                      Andreas.
                      [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L1841-L1844
                        andreas @andreas
                        I have to admit I didn't keep track of the application.elf files coming out of my builds which are required to properly decode the core dumps. May I humbly ask you to try again using LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz?
                          andreas
                          I've tried to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly-modonewire-i2s firmware which shows the core dump is happening here:
                          #1  0x401124f0 in lora_bandwidth (n_args=<optimized out>, args=0x3ffc990c <lora_partial_rx_packet+12>) at mods/modlora.c:2117
                          See also [1]. I believe this is also due to a erroneous core dump decoding, so nevermind.
                          I have now kept the application.elf file for the new build LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. If you are able to catch another core dump when running this firmware, we would probably get correct results. Sorry for the extra mile.
                          [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L2116-L2118
                          S 3 Replies Last reply Reply Quote 0
                            andreas
                            Another attempt by trying to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly firmware without support for 1-Wire and I2S.
                            #0  0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                            #1  0x401124f0 in ?? ()
                            Backtrace stopped: previous frame identical to this frame (corrupt stack?)
                              Id   Target Id         Frame
                              15   process 14        xQueueGenericSend (xQueue=0x3ffb2e50, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              14   process 13        xQueueGenericSend (xQueue=0x3ffc3f0c <vflash_mem+1840>, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              13   process 12        xQueueGenericSend (xQueue=0x3ffb75fc, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              11   process 10        xQueueGenericSend (xQueue=0x3ffbac44, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              10   process 9         xQueueGenericSend (xQueue=0x3ffb7bc8, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              9    process 8         xQueueGenericSend (xQueue=0x3ffdab60, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              7    process 6         0x40092b55 in vTaskNotifyGiveFromISR (xTaskToNotify=0x0, pxHigherPriorityTaskWoken=0x0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:5044
                              6    process 5         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x8484, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                              5    process 4         xQueueGenericSend (xQueue=0x3ffbd494, pvItemToQueue=<optimized out>, xTicksToWait=100, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              4    process 3         0x40206db2 in littleFsErrorToErrno (littleFsError=393251) at littlefs/vfs_littlefs.c:175
                              3    process 2         xQueueGenericSend (xQueue=0x3ffbdab4, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
                              2    process 1         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                            * 1    <main task>       0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
                            Looking at
                            here.
                              andreas @sita
                                f.write(message)
                                f.write(' ')
                                f.write('\n')
                                f.close()
                              Could you stop opening and closing the file within such a tight loop? You might want to time.sleep_ms() for at least some milliseconds between iterations. To be safe, try to use longer intervals first and get shorter if things might become more stable.
                              When being at it, you might also want to think about optimizing things using a single write call like f.write(message + ' \n').
                                sita @andreas
                                Hello @andreas,
                                Thanks for the information. I kept time.sleep_ms(10) in the loop and will change f.write as you said.I will do the the experiment again and let you know if i got same again.
                                Thanks once again.
                                Have a nice day
                                  sita @andreas
                                  Hello @andreas ,
                                  I have changed the firmware to LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. I will do the experiment again and let you know if i got same issue again.
                                  Thanks once again & have a nice day
                                    sita @andreas
                                    Hello @andreas ,
                                    I have now flashed the latest firmware (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz). I got a new problem.When i try to upload my project, it gets struck while uploading the additional library files required. I attached the screenshot below.
                                    As far i understood, it is trying to compress the library files before uploading and it gets struck with that. I haven't observed this phenomenon with earlier firmware versions. Please have a look
                                    Thanks & Best regards,
                                    Have a nice weekend
                                      sita @andreas
                                      Hello all,
                                      I got an issue regarding uploading the project and connecting the port after updating new firmware LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz, the respective problem screenshots shown in the below.
                                      My doubt is, Is it related to new firmware update or any change in ATOM editor settings ??
                                      Could anyone please suggest me how to resolve this problem ?
                                      Safe booting device... (see settings for more info)
                                      Safe boot failed, uploading anyway.
                                      Upload failed: timeout. Please reboot your device manually.
                                      Connecting to COM12...
                                      Connection error: Error: timeout
                                      Thanks in advance & Have a nice day
                                        andreas @sita
                                        Dear @sita,
                                        sorry to hear that this didn't work out well. While I have to admit I haven't tested the firmware on a LoPy4 device, I just compiled it like any other Dragonfly builds I have done before.
                                        I haven't seen the error you are observing anytime before.
                                        So, to be better safe than sorry, downgrading to any other former release from [1] might help. If it doesn't you might want to downgrade to a regular release from Pycom using the regular firmware installer.
                                        Sorry for the hassle!
                                        With kind regards,
                                        Andreas.
                                        [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/
                                          sita @andreas
                                          Hello @andreas ,
                                          I have tested my devices all the versions in the [1] but in every version i observed the Guru meditation error. Is there any permanent solution for this problem ? It would be very helpful if i know exact reason behind issue ,if you know the reason could you please let me know..
                                          Thanks in advance & have a nice day
                                            andreas @sita
                                            Dear @sita,
                                            just a short question: Have you been able to run your MicroPython program successfully with LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel until the Guru Meditation error happened again? I am asking because it looked like you had other problems with this the other day.
                                            With kind regards,
                                            Andreas.
                                            • 1 / 3
