Problems stopping alarm with KeyboardInterrupt
Hello.
I am testing out a FiPy along with the Pysense board. My current test-project is about reading the value of the ADC at a given interval, using the Alarm.Timer(). That part of the code is working (see my full main below):
# from machine import ADC, Timer, idle #from pysense import Pysense import pycom import utime import _thread print("Getting new readings from ADC every 10 ms!") data = [] times = [] adc = ADC() apin = adc.channel(pin='P16') dataread = apin() def adcread(): try: while True: t1 = utime.ticks_us() dataread = apin() data.append(dataread) times.append(t1) print("Data: ") print(dataread) print("Times: ") print(t1) except KeyboardInterrupt: alarm.cancel() print("Handler stopped") Timer.Alarm(lambda y: adcread(), ms = 10, arg = None, periodic=True)
However the KeyboardInterrupt does not let me stop the program. The REPL console does not react, and does not print the "handler stopped" message ever, when pressing Ctrl+C. I followed the documentation at https://docs.pycom.io/firmwareapi/pycom/machine/timer/, but still no success. Any help would be appreciated!
Another thing: When this code is running, i have a really hard time uploading another program to the FiPy, which otherwise would be a workaround to not being able to stop the program. Then it fails writing the individual files (lib's, boot and main). Any ideas?
Thanks in advance.
@robert-hh and @andreas Thank you for the help. Yeah the last one is kinda obvious now! :)
Dear @railmonitor,
indeed,
alarm
is an undefined reference. You should probably sayalarm = Timer.Alarm(...)
somewhere.
The REPL console does not react.
When this code is running, i have a really hard time uploading another program to the FiPy [...]While the system is under heavy load, it lacks resources to be responsive for any file upload. You might want to increase the interval
ms = 10
in order to reduce pressure.With kind regards,
Andreas.
Hi @robert-hh
Thanks for replying.
The firmware version is here:
So it seems my pybytes is outdated, however i did just run the firmware update tool. Is there another method for updating that i may have overlooked?
I added the 1 ms. sleep:
def adcread(): try: while True: t1 = utime.ticks_us() dataread = apin() data.append(dataread) times.append(t1) print("Data: ") print(dataread) print("Times: ") print(t1) utime.sleep_ms(1) except KeyboardInterrupt: alarm.cancel() print("Handler stopped")
but it still won't let me stop the handler when program is running on the FiPy.
EDIT: I was able to stop the program by hitting the reset button, and then tapping Ctrl-C a few times. But still no print of the "Handler stopped" message. Doing this produced following output:
@railmonitor Which firmware are you using? Pushing Ctrl-B should show it. The PyBytes version had the habit of disabling Keyboard Interrupt.
About slow response: Busy loops like the one below have the tendency to block background tasks like FTP or Telnet. Just add a time.sleep_ms(1) to the loop. That should improve the response.
