No successful Sigfox connectivity after latest update with FiPy & PyTracker [SOLVED]
@pmb_nl
Sorry for the basic question but have you connected an antenna (and which) to the connector next to the LED? -
@jmarcelino Haha yes, I have used the antenna from the Pycom store.
@jmarcelino Despite my antenne (LoRa (868MHz/915MHz) & Sigfox Antenna Kit) near the LED I receive value 0 with the command (sigfox.rssi()). Does that mean that there is zero signal received or am I using the command the wrong way?
Hi @pmb_nl
rssi() only works for the last received message. For Sigfox that means you’d need to schedule a downlink (and to have it sent the backend would need to receive an uplink first)
The only way to check the signal in Sigfox (and other ISM band networks like LoRa) is to check the received signal at the backend.
Maybe coverage in your area isn’t very good. Have you tried outdoors?
@jmarcelino Thanks for clarification! I did check once outside. I have contact with Aerea (Dutch Sigfox provider) and they will check from the network side. There should be country wide coverage.
Hi all,
I got the exact same issue, did anyone manage to solve it?Thanks
@giorgioscibilia I still have the same problem so also interested in a possible solution.
@pmb_nl it sounds weird, I know that.. but updating the pymakr plugin actually made it work for me .
Hope that can help! -
@giorgioscibilia I solved it by using another antenna and putting it out of the window.
@pmb_nl i have the same problem, do You have some solution about it? Thanks
