Bricked?
 Im getting this from my fipy? rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
 flash read err, 1000
 ets_main.c 371
 ets Jun 8 2016 00:22:57rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
 ets_main.c 371
 ets_main.c 371
 ets_main.c 371
 ets_main.c 371
 ets_main.c 371
 ets_main.c 371
 ets_main.c 371Is it broken? Is so how do i return for replacement? I have 2 doing this?
 I had the same issue on LOPY4 boards and seems is related with the watchdog.
 If the watchdog is started and you do P2+GND (bootloader mode) then press reset... always you got this cycled error.
 The workaround is to put P2+GND (bootloader mode) and unplug then plug powerThe issue is reproduced on several boards with LOPY4.
 Was this issue resolved? I am having the same problem with the lopy4.
 @misterlisty How are you powering the FiPy?
 @misterlisty That looks like an interface problem. Do you use an expansion board? Maybe that is broken or has broken or worn contacts.
 Tried reflashing but something is wrong...sometimes it connects ie serial com working..sometime scrambled characters
 @misterlisty Since the devicve is complaining, it is not dead. Try to re-flash the firmware. Maybe you loaded the wrong firmware to the device. Also: check cables, power supply, ...
