Wipy & Pytrack Firmware
Just updated Wipy and Pytrack firmwares to the latest releases and now it seems that I can get the imports to work anymore.
For example none of the examples are working, like pytrack and it doesn't import the Pytrack module correctly.Traceback (most recent call last):
File "<stdin>", line 2, in <module>
ImportError: no module named 'pytrack.Pytrack'How can I know that the /lib copy to the device is correct? Is there a way to view (viewer)?
Am I doing something wrong, what is the latest guide I should follow?
Tried in Atom and Vscode on two different Macs and the issue is the same.Any help would be welcome.
Cheers
Hugh
@htrifol If you have setup Wi-Fi, you can use FTP to view files on your device. Note that there are limitations to this, see the documentation for configuration settings.
