    LoPy Nano-Gateway
    62 Posts 27 Posters 50.6k Views 31 Watching
      borjam @Feiko
      @Feiko Are both devices close? Try lowering the transmission power to the minimum (2 dBm) and move them several meters apart (or use an attenuator).
      I have been doing tests between a LoPy and a Raspberry with a Dragino Lora/GPS hat (SX1276 based) and with just 2 dBm I can receive packets reliably with the RPi and the LoPy in different flats and at the opposite sides of the building. Depending on the antenna positioning I even registered an average SNR of -8 dB, which is amazing.
      • F Offline
        Feiko @borjam
        The distance and the power do not seem to be the problem. I tried running the test over 100 meters. If I put a time.sleep(0.2) after lora_sock.recv(512) and lora_sock.send(pkg) on both server side and client side, the code runs. In previous firmware the code run straight out of the box. I think the OSError:[Enro 11] is caused by a cue in the send buffer. Sometimes there are still receive messages left in the buffer, even after a soft reset. I use the code
        recv_dumpbuffer = lora_sock.recv(512)
        time.sleep(0.2)
        to make sure the receivebuffer is empty.
        the 200ms waits in between Lora commands are hardly ideal. On previous firmware versions the code run straight out of the box.
        • F Offline
          Feiko
          Just run the Nano-Gateway with the latest firmware 1.3.0.b1. All problems are resolved :D. Thanks Pycom team.
            gouao
              microman7k
              On "Nano-Gateway" with the latest firmware 1.3.0.b1 i'm still getting "ValueError: buffer too small" after hour of two running posted sample code. Is this problem with the sample code or is it firmware problem?
                gouao
                • F Offline
                  FelixDonkers @gertjanvanhethof
                  @gertjanvanhethof I'm also interrested to use LoPy as a LoRaWan gateway. Looking forward to a solution.
                    Colateral @Roberto
                    @Roberto We setup a test bench with 3 LoPy following the idea of your code. We did the test with blocking socket and thread and non blocking sockets. The result is the same.
                    2 are the nodes configured as tx_iq and and one is the Gw (rx_iq).
                    The script is simple: each device (node and GW) is sending 29 bytes message size (_MSG_FORMAT = "!HHLBB%ds") each 2 seconds. In the msg data we are printing a counter (that varies from device). That counter is also in the header (see above)
                    We noticed that sometimes if you start the gw after the nodes... randomly some of the nodes are not receiving the data, despite the fact the GW is receiving the data from the nodes. And we observed also that sometimes when we start the node after the GW, the GW is not receiving the data from the nodes.
                    You need to reset the node or GW in order to get the broadcasted data from to the others... and this hazardous and not at all good in real deployment.
                    BUT THE MOST PROBLEMATIC is the fact that the 29bytes are partially received, sometimes you are getting 15bytes or whatever number less than 29bytes.
                    Have you experience this connection issue related with nodes/gw starting order?
                    Does LoPy stack is guarantee the receiving of msg in one chunk? ( if you send 29bytes you got 29bytes)
                    Here are some samples:
                    good msg receive
                    to: 0
                    Flags: 0
                    PayloadSize: 18
                    Payload: b'3058- 1234567890 '
                    <<< beat msgId 3066
                    bufferSize 29
                    pkgSize 28
                    data_size 18
                    remaining buffer 0
                    bad msg receive
                    to: 0
                    Flags: 0
                    PayloadSize: 18
                    Payload: b'3059- 1234567890 '
                    bufferSize 15
                    buffer too small <<< ustruct exception
                      Roberto @Colateral
                      Hi @Colateral,
                      Yes, i have noticed that sometimes some messages arrive malformed or with bytes missing. This could be due to LoRa message collision between devices. If two devices send at the same time in the same band this can happen.
                      There is a new blog here in the forum with a new code suggestion that includes.
                      1. Message length check on the nano-gateway
                      2. Message retry on the nodes
                      3. Max timeout in the nodes
                      Number 3 will help with the fact that you have to have the nano-gateway on before you start the nodes. In this code, after sending a message the node waits in an infinite loop for the ack. The problem with this approach is that if no ack is received (the nano-gateway was not connected yet) the node will stay in that loop until reseted.
                      Keep in ming that both this and the new code are just examples for specific usages and they require adaptation depending on your needs.
                      The link for the new post is LoPy Nano-Gateway Extended (Timeout and Retry)
                      Best,
                      Roberto
                      • F Offline
                        feabhas @Roberto
                        @Roberto I have successfully got a 2 node and 1 gateway setup working based on your code, thanks very much. One minor query, In the gateway you use
                        _LORA_PKG_FORMAT = "!BB%ds"
                        but in the node_1.py you miss off the !, e.g.
                        _LORA_PKG_FORMAT = "BB%ds"
                        Shouldn't they be consistent?
                          Roberto @feabhas
                          Hi @feabhas
                          yeah, that sounds about right. Change that please. Ill edit the post accordingly Thanks
                            Colateral @Roberto
                            @Roberto Your example it is a good start but looping and blocking might not be a good approach.
                            We built another script that is using threads with blocking socket ... and run the script on a minimal Lora "star" network: one GW and 2 NODES. For each device you have to configure tx,rx and device id in cfg file . and upload the script and cfg file on it and run the script in Putty (not Pymakr). We didn't faced with this script clashing issues.. but we faced other issues.
                            You will see that after awhile on GW, the script is ending with a memory leak... but this is never happening on the nodes.
                            If you run the script from 3 Pymakr instances ... sometimes is working for hours and after that the GW is stop sending.
                            We conclude that is something wrong on the stack.
                            The issue might be related only to rx_iq configuration.
                            https://drive.google.com/drive/folders/0BzRE8IpnMMnLNHBseDJWblN4VGM?usp=sharing
                              Roberto @Colateral
                              Hi @Colateral
                              As i wrote in my last message, there is a new example of the nano-gateway with a non-blocking loop approach.
                              Regarding the memory issues we will look into this. I left the code on the other post running for 3 hours without any problems. I will leave it running today on a test bench for 24+ h to see if there are any problems and monitor the memory while it transmits. Will let you know the results.
                              The link to the new code is
                              https://forum.pycom.io/post/3242
                                Colateral @Roberto
                                @Roberto HI Roberto. Thanks. I ran the last script and is running fine. Regarding the memory leak, I believe is related with socket blocking approach. If we change the script and move to non blocking (as your script does) everything works fine.
                                  Roberto @Colateral
                                  @Colateral
                                  Thanks for the quick response, i'll try a blocking approach to see if i can reproduce the error and check whats the root of it.
                                    assia
                                    @Colateral said in LoPy Nano-Gateway:
                                    Hi @Roberto i am bbegginer in LoRa and i don't understand the use of rx_iq and tx_iq.!
                                    thanks
                                      borjam @assia
                                      @assia said in LoPy Nano-Gateway:
                                      It's easy. A LoRaWAN network is not a peer to peer network. There is a master (the gateway) that communicates with the nodes, but there is no node to node communication.
                                      Imagine that one of your nodes has the receiver active and another one transmits. The transmission is intended to be received by the gateway, of course (we said that there is no node-to-node communication) but the receiving node will get the packet anyway, if only to discard it.
                                      That reception and discarding has an energy cost. How do you avoid it? By having the nodes transmit in a mode that a node can't understand, only the gateway.
                                      Now, imagine this scenario: you make the nodes use tx_iq inversion (which is a sort of signal inversion) and the gateway use rx_iq inversion.
                                      In this case, a signal transmitted by a node will be inverted, and the gateway will successfully decode it. But other nodes, expecting a non inverted signal, won't detect the inverted signal. So you have just avoided the unintended packet reception problem.
                                      A C 2 Replies Last reply Reply Quote 1
                                        assia @borjam
                                        @borjam
                                        Thanks for the quick response, It's much clearer now.
                                          Colateral @borjam
                                          @borjam So how you can implement a mesh network using Lora? You put the GW in both tx and rx ?
                                            assia
                                            Hi @Roberto I tried to modify your code because I need to send a payload that contains the current time with a header containing mac address of the node and the length of the payload. Everything went well on the node side but rated nano gateway I have an Index Error: bytes index out of rang. it is because the adresse mac ? knowing that lora.mac() give : b'p\xb3\xd5I\x95kA\xf3' with length=8 but i don't understand what does mean the : b'p......' and how the length is 8 !!
                                            thanks
                                            node
                                            # LoRa node
                                            SRC_ADR_MAC=lora.mac()
                                            #compteur packets
                                            PACKETs_Cnt=5
                                            while(PACKETs_Cnt>0):
                                                # Package send containing a simple string
                                                msg=time.time()
                                                msg_len=len(str(msg))
                                                pkg = struct.pack('!%dsBi' % len(SRC_ADR_MAC), SRC_ADR_MAC, msg_len, msg)
                                                lora_sock.send(pkg)
                                                PACKETs_Cnt=PACKETs_Cnt-1
                                                time.sleep(5)
                                            nano GW
                                            # LoRa GW
                                            while (True):
                                                recv_pkg = lora_sock.recv(255)
                                                if (len(recv_pkg) > 2):
                                                    device_adr_mac, msg_len, msg = struct.unpack('!%dsBi' %8 ,   recv_pkg)
                                            # %8 because len(lora.mac())=8
                                                    print('Device: %s - Pkg:  %s' % (device_adr_mac, msg))
                                                time.sleep(5)
                                            • 3 / 4
