    Core 1 panic'ed (IllegalInstruction) before importing anything!
    core dumpwipy1.20.0.rc11guru errorillegal
    11 Posts 2 Posters 255 Views 2 Watching
    • E Offline
      ElinhohHD
      Hello, everyone,
      I have a Wipy device (W01) running into the firmware Wipy 1.20.0.rc11,
      I was testing the stability of the system by restarting it every 5 secondes.
      And sometimes before importing anything, I receive this message , explaining me that I have made a IllegalInstruction.
      The error:
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:2156
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19208
      entry 0x400a05f4
      Initializing filesystem as LittleFS!
      Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
      Memory dump at 0x400eacfc: 0633a8c0 00000000 00000000
      Core 1 register dump:
      PC      : 0x400ead02  PS      : 0x00060d30  A0      : 0x800ecb80  A1      : 0x3ffd9cf0
      A2      : 0x3ffc5afc  A3      : 0x00000000  A4      : 0x3f94ee54  A5      : 0x00000018
      A6      : 0x000002b4  A7      : 0x00000870  A8      : 0x800945de  A9      : 0x3ffd9cf0
      A10     : 0xffffffac  A11     : 0x00000888  A12     : 0x00001000  A13     : 0x00000001
      A14     : 0x000000fe  A15     : 0x3f40b302  SAR     : 0x0000001a  EXCCAUSE: 0x00000000
      EXCVADDR: 0x00000000  LBEG    : 0x4009c069  LEND    : 0x4009c079  LCOUNT  : 0xfffffffe
      Backtrace: 0x400ead02:0x3ffd9cf0 0x400ecb7d:0x3ffd9d20 0x400ee6b4:0x3ffd9d60 0x401ccad9:0x3ffd9d80 0x40108e56:0x3ffd9db0 0x401cc5df:0x3ffd9de0 0x400f2ee8:0x3ffd9e00 0x400f3a5d:0x3ffd9e30 0x400dee72:0x3ffd9eb0 0x400df10d:0x3ffd9f50 0x400ddf43:0x3ffd9f70
      The code :
      print('------ BEGINNING ------')
      from machine    import Pin, UART, SPI, RTC, ADC, Timer, reset
      print("Main.py Machine OK")
      from time       import sleep, time, gmtime
      print("Main.py Time OK")
      from pycom      import nvs_set, nvs_erase_all, rgbled
      print("Main.py Pycom OK\n------ END ------")
      reset()
      Thank you for everything.
      • E Offline
        ElinhohHD
        I add that this event only acts on a single chip which has probably been too heated
          @ElinhohHD said in Core 1 panic'ed (IllegalInstruction) before importing anything!:
          When I try to reproduce your error, it does not print the whole message,
          load:0x3fff8020,len:8
          load:0x3fff8028,len:2140
          ho 0 tail 12 room 4
          load:0x4009fa00,len:19760
          entry 0x400a05bc
          Main.py Machine OK
          Main.py Time OK
          Main.�ets Jun  8 2016 00:22:57
          ho 0 tail 12 room 4
          entry 0x400a05bc
          Main.py Machine OK
          Main.py Time OK
          I believe it has something to do with the order of instructions, when I include only a little delay using sleep_ms() it does print everything.
          Now I still cannot reproduce your error however. Have you tried updating the firmware to the latest? (1.20.2.rc10)
          Let me know!
          • E Offline
            ElinhohHD @Gijs
            @Gijs I have this problem that only on 1 component.
              Can you elaborate?
              • E Offline
                ElinhohHD @Gijs
                @Gijs said in Core 1 panic'ed (IllegalInstruction) before importing anything!:
                Can you elaborate?
                I did the test on 3 different devices.
                Only 1 device shows me these errors after an average of 10 restarts
                We assume here that the device must have overheated, or that a component of the device is non-functional.
                  Did you try updating the firmware to the latest version? I do not think overheating or malfunctioning components will cause this problem.
                  • E Offline
                    ElinhohHD @Gijs
                    I did this in the past but these firmwares are not stable
                    But nevertheless, I will try to update and see the difference between these 2 firmwares.
                    E 1 Reply Last reply Reply Quote 1
                    • E Offline
                      ElinhohHD @ElinhohHD
                      @Gijs
                      I upgraded the Wipy to the latest , and I see the most of time a LoadProhibited error
                      ------ STARTING UP ------
                      import sleep
                      import reset
                      Main.py Importation WLAN
                      Main.py WLAN OK
                      Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                      PC      : 0x400edc8f  PS      : 0x00060930  A0      : 0x800edcdf  A1      : 0x3ffd8c90
                      A2      : 0x3f958390  A3      : 0x00000003  A4      : 0x3f4276a8  A5      : 0x3f427720
                      A6      : 0x3f428288  A7      : 0x3f4276b8  A8      : 0x00005959  A9      : 0x00009151
                      A10     : 0x17404004  A11     : 0x00000059  A12     : 0x00000010  A13     : 0x3f9583a0
                      A14     : 0x00000030  A15     : 0x00000001  SAR     : 0x0000001c  EXCCAUSE: 0x0000001c
                      EXCVADDR: 0x17404005  LBEG    : 0x4008e936  LEND    : 0x4008e941  LCOUNT  : 0x00000000
                      Backtrace: 0x400edc8c:0x3ffd8c90 0x400edcdc:0x3ffd8cc0 0x4010ba2e:0x3ffd8ce0 0x4010bc26:0x3ffd8d00 0x4010bcfb:0x3ffd8d60 0x4010bd89:0x3ffd8dc0 0x4010bdaa:0x3ffd8e30 0x400fd34f:0x3ffd8e60 0x400fd6ae:0x3ffd8e90 0x400f4a0d:0x3ffd8f70 0x400ffe75:0x3ffd8fb0 0x400f7a76:0x3ffd9050 0x400f4099:0x3ffd90b0 0x400f40c6:0x3ffd90d0 0x400fd2dc:0x3ffd90f0 0x400fd356:0x3ffd9180 0x400fd6ae:0x3ffd91b0 0x400f4a0d:0x3ffd9290 0x400ffe75:0x3ffd92d0 0x400f7a76:0x3ffd9370 0x400f4099:0x3ffd93a0 0x400f40c6:0x3ffd93c0 0x400d8031:0x3ffd93e0 0x400d82c9:0x3ffd9480 0x400d6dbc:0x3ffd94a0
                      Code here :
                      print('------ STARTING UP ------')
                      print('import sleep')
                      from machine import reset
                      print('import reset')
                      sleep(1)
                      from network import WLAN
                      print("Main.py WLAN OK")
                      wlan = WLAN()
                      print("Main.py wlan Instantiation OK")
                      wlan.deinit()
                      print('Main.py Disable Wifi')
                      from time       import time, gmtime
                      print("Main.py import pycom OK")
                      print("------ END ------")
                      sleep(0.5)
                      reset()
                      • E Offline
                        ElinhohHD
                        @Gijs
                        I have this problem after importing the WLAN class from network
                        Moreover on other cards I have no problems.
                        Would it be a manufacturing defect ?
                          I believe you are experiencing the same issues as discussed here:
                          https://forum.pycom.io/topic/5765/loadprohibited-core-panic-when-initialize-wlan
                          Can you review the discussion?
                          There are of course slight differences between the antennas etc. on the boards (manufacturing tolerances etc) and doing a full erase using the update firmware tool might help in that regard.
                          Let me know!
