    Initial issues with the LoPy
    15 Posts 9 Posters 4.5k Views 9 Watching
      digsatman @DarkHawk
      @DarkHawk Ive been able to update one of my two LoPy's with the standalone updater under Windows 7 without needing to link pins or anything. My other LoPy wont update from WIndows or OSX and just says failed after 30 seconds or so. Maybe one of mine is broken - how did you ascertain yours was broken?
      I thought there was a way of updating the LoPy via ftp but can't find a binary firmware image and am not sure if it is the same method as the WiPy/WiPy2
        It's the same method as the WiPy 1.0. Just rename the binary to appimg.bin and put it inside /flash/sys/.
          jeremy
          I just got the binary image from the updated package. There is information in the documentation on how to update the lopy via ftp. Make sure to rename the file to the correct format before updating
          I worked out my lopy was broken because changes to boot.py would not persist, and the exact same changes would persist on many other devices. Just this evening, @daniel helped me to get it working again.
            LoneTech @jeremy
            What's the solution for changes not persisting? I have a LoPy that doesn't accept firmware changes, immediately forgets any new files, and forgets any new data in boot.py. That is, the file size changes but the data is all NUL. Firmware updates don't seem to affect it either.
            Edit: solved, see thread How to solve the firmware update failures
              jeremy
              @LoneTech you should contact @daniel
              • K Offline
                Keptenkurk @jeremy
                @jeremy
                As for question 3:
                UART0 RX = P0
                UART0 TX = P1
                  matamune @abilio
                  @abilio said in Initial issues with the LoPy:
                  @jeremy About the Mac updater, at present time we're only supporting OS X 10.11.6 or newer. This can change in the future, but thanks for the feedback on a different version.
                  Hi there,
                  I just received my lopy and I wanted to update my lopys' firmware but I got the error LSOpenURLsWithRole() failed with error -10810 when I run open /Applications/Pycom\ Firmware\ Update.app/ and open /Applications/Pymakr.app/ and I am under macOS Siera (so 10.12).
                  Is there any way to upgrade the firmware and use the pymakr application ?
                  Thakn you :)
                    jobbyworld @jeremy
                    @jeremy
                    be sure to use machine.reset() after update
                    or
                    power off
                    Have the same issue on mac el captain, using Windows 10 works
                    On my mac pyserial don't work.
                    On mac you could try to extract lopy_0.9.1.b1_868 or lopy_0.9.1.b1_915 depends your countrie from app
                    and next ftp lopy firmware to /flash/sys/appimg.bin
                      matamune @matamune
                      @matamune said in Initial issues with the LoPy:
                      Hi there,
                      Thank you :)
                      So, I solved my issue.
                      It was due to an error with QT and libpng :
                      gabi@MacBook-Pro:/Applications/Pycom Firmware Update.app/Contents/MacOS$ DYLD_FRAMEWORK_PATH="${DIR}/Frameworks" DYLD_FALLBACK_LIBRARY_PATH="${DIR}/Resources/lib" "${DIR}/Frameworks/Python.framework/Versions/2.7/bin/pythonw" "${DIR}/Resources/src/lopyupdate.py" "$@" Traceback (most recent call last): File "/Applications/Pycom Firmware Update.app/Contents/Resources/src/lopyupdate.py", line 9, in <module> from PyQt4 import QtGui ImportError: dlopen(/Applications/Pycom Firmware Update.app/Contents/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages/PyQt4/QtGui.so, 2): Library not loaded: /opt/local/lib/libpng16.16.dylib Referenced from: /Applications/Pycom Firmware Update.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui Reason: Incompatible library version: QtGui requires version 38.0.0 or later, but libpng16.16.dylib provides version 35.0.0
                      So I had to install/update libpng with brew (brew install libpng) and then I manually copied the files from /usr/local/opt/libpng/bin into /opt/local/lib/ and it worked.
                        abilio @matamune
                        @matamune Thank you very much for your detailed post. It will be really helpful to improve the tool.
