    Deep Sleep and Battery Consumption.
    ttn lopydeep sleepbatteryconsumptionlora
    18 Posts 3 Posters 201 Views 3 Watching
      jcaron @hm97
      @hm97 said in Deep Sleep and Battery Consumption.:
      Out of curiosity, what happens if you exceed the allowed 30 seconds airtime? will TTN simply not accept data from your device until the next day?
      I have no idea. I'm not even sure this is actually enforced.
      Then, in that case, I would have to spread my messages across the day so if I have 100ms airtime for example, then that allows me 300 messages spread over 86400s in the day (which is 288s per message?).
      Yes.
      if you use 1.5 seconds, then that means that single you cannot be "on the air" over 1% of the time, then you cannot be sending more often than once per 150 seconds.
      Alright so just to get the maths down here, if I use an SF7 which is about 50ms airtime, then I could potentially send a message every 5 seconds max? so in my case, I would have to look at what TTN tells me my estimated airtime is (which seems to be currently ~414ms) and then divide that by 1% to get my allowed time per message which I can then adjust by changing the deep sleep time I'm assuming.
      I'm not sure I follow. The TTN rules are actually stricter than the EU rules (EU rules say you are allowed 1% airtime, so that's 864 seconds per day). The EU rules would apply if you use your own network or another network. They are also enforced by the LoRaWAN stack IIRC, so even if you "forgot" about the TTN rules, they would still be there.
      But indeed, setting aside the TTN rules, at SF7 with small frames you could potentially send one frame every 5 seconds. However the airtime goes up with the frame size, and deep sleep is pretty much useless and probably counterproductive at that rate, you can forget running on battery.
      Then in that case, if I can send a message every 5 seconds and i am permitted 600 messages per day on TTN, then I would use up all my allowed messaged in 3000seconds (50 mins) is that correct?
      Yes.
      another question is I don't specify these things in my code when I create the LoRa object. So can I assume that SF7 and BW is 125kHz by default? (although my airtime is still quite large).
      Don't remember all the details off the top of my head, but I believe it's a combination of defaults, parameters you set, whether ADR is enabled or not, and what the network tells the device on join or later through MAC commands. Isn't the data rate/SF shown in TTN logs?
      If I am indeed using an SF7 and my airtime is quite large (~413.7ms) then would that be because my Data Rate set in my socket is too low? I have set it to 1:
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 1)
      It seems that the lora documentation (https://lora-alliance.org/sites/default/files/2018-05/2015_-_lorawan_specification_1r0_611_1.pdf#page=34) indicates that the various data rates correspond with a specific SF. Is this data rate the same one as the above socket options? or am I confusing the 2?
      Yes, for each region the data rates map to a combination of modulation, bandwidth and SF. DR1 is SF11BW125. Doesn't quite exactly match the airtime, though.
      In this case, then would an SF in the LoRa object have to be specified or is it informed by the socket options?
      IIRC you set it with the socket options, but that works only if ADR is off. If ADR is on then the stack and network decide. I don't remember if you can specify a starting point in that case.
      Remember you can log lora.stats after sending to check a few things.
      H 1 Reply Last reply Reply Quote 1
        jcaron @hm97
        @rcolistete said in Deep Sleep and Battery Consumption.:
        ''There is a cycle delay in the sensor data sent, so 2nd LoRaWan package uses data sent in #1 cycle.''
        can this explain why I am having a relatively high airtime? The first reading I sent to TTN gives me an airtime of about 103ms while all the following readings give me an airtime of ~413.7ms. So when you said the LoRaWAN package uses data sent in #1 cycle is that to say that it is sending more data in the subsequent readings and thus takes more airtime?
        What @rcolistete means is that if you use the method they gave, then there's always an offset of one sleep cycle between data collection and sending it: each time you send the data you collected during the previous cycle. This allows you to run data collection in parallel to the RX windows delays: when you send data over LoRaWAN, the device always waits at least 1 second, then listens for a downlink in RX1, then waits another second, then listens for a downlink in RX2. So that always takes at least 2 seconds (unless you receive a downlink in RX1).
        With the traditional get data-then-send method, your total awake time is time to boot + time to get data + time to send-and-wait-for-RX. With the parallel method, the total awake time is time to boot + max(time to get data, time to send-and-wait-for-RX). If time to get data is significant, as is the case for some sensors, this can save quite a bit of awake time on each cycle. The drawback is that you get the data one cycle later.
        H 1 Reply Last reply Reply Quote 2
        • H Offline
          hm97 @jcaron
          @jcaron
          Then in that case I will just go with the limiting factor.
          This is important for me. I don't quite understand why the airtime is going up. I tested yesterday, setting my Data rate as 3 in the socket options (SF9 / 125 kHz). However, looking at the metadata from TTN, the first sensor value that got sent actually used the set data rate and the airtime was 103ms. The subsequent messages had an airtime of 413.7ms and used SF11. Why does the frame size go up after the first message? and why is it changing my data rate after the first message?
          I am planning on running this on battery soon. Do you think it will last at least a week with an interval of one message per 20mins. I think the time it is active is about 10 seconds from boot up after deep-sleep until it records and goes back to sleep.
          Yes, it is, upon looking more carefully, the metadata does show this info thanks.
          • H Offline
            hm97 @jcaron
            @jcaron I see, Thanks @rcolistete. I'm not entirely sure how I would implement this though so for now, I will stick with what I have but I will get back to this should I need to but this sounds quite useful.
              jcaron @hm97
              @hm97 I don't remember if the TTN logs show message size? I have a hard time reconciling SF9BW125 and 103 ms airtime.
              There are two things that have an influence on airtime:
              • The data rate (SF and BW)
              • The amount of data sent
              When you join, the network (TTN) can send various settings to the node to control which channels, data rates, etc. are used. Some are sent right away in the join answer, others are sent in MAC commands piggybacked to downlinks (which are themselves sent in response to uplinks).
              So you can have:
              • Join request
              • Join accept -> some settings are sent to the node
              • First uplink -> uses one SF
              • Network replies with a downlink (empty data, only MAC commands) and changes more settings
              • Second uplink -> uses different SF due to new settings
              If ADR is enabled, it is also possible for the node to change settings spontaneously, so IIRC that takes quite a bit more time (and should go towards faster data rates unless frames get lost).
              I don't quite reconcile the airtime values you get with those computed with TTN's airtime calculator, but the ratio seems indeed to be coherent.
              At one message per 20 minutes with 10 seconds awake, counting 20 µA sleeping and 100 mA awake, you should get:
              ((20 * 60 - 10) * 0.02 + 10 * 100) / (20 * 60) = 0.85 mA average current.
              To last a week, you need 0.85 * 24 * 7 = 142.8 mAh.
              Pack a 2500 mAh battery and you should be quite safe :-)
              Be sure to check the current during deep sleep. There have been quite a few cases where it was way more than 20 µA (more like several mA), and that would kill your battery life completely.
              Add monitoring of the battery voltage. It's quite crude, but it will give you a rough idea of where you stand.
              • H Offline
                hm97 @jcaron
                @jcaron
                yes I have seen some of these posts and I have an odd feeling I might find my system dying too quickly but how do i check the current during deep sleep? do you mean using an ammeter? Unfortunately I don't have access to that currently.
                I will setup a function that returns the battery voltage. Do I need to do anything on the hardware side before it can read the voltage to me? or is it all just in the code? (don't want to accidentally mess up my system, I have almost no experience with circuitry)
                • H Offline
                  hm97 @hm97
                  @jcaron sorry i could not edit my previous post but just to add, the LoPy4 datasheet indicates under their power consumption section (section 10) that the deep sleep power consumption under 5V (not sure what the voltage entails) is 19.5mA which is very high and the LoRa Transmit is 105mA. I'm not sure if this power consumption they are talking about is the same one we are talking about but was just confused when I saw that.
                  https://docs.pycom.io/gitbook/assets/specsheets/Pycom_002_Specsheets_LoPy4_v2.pdf
                    jcaron @hm97
                    @hm97 That's a typo. It should be µA, not mA (for deep sleep). Though as I wrote earlier, you need to check it, there have been instanced where it did end up being mA.
                    LoRa transmit depends on TX power settings and a few other things, but the device is not transmitting the whole time its awake, just when it's actually sending the frame (the airtime, from a few ms to a few seconds depending on frame size, SF, BW). It's also listening for a short time during the RX1 and RX2 windows.
                    The usual power profile during the awake period is something like:
                    • boot, takes 1-2 seconds, very irregular with quite a few spikes.
                    • data collection, depends on lot on what you are doing
                    • LoRA TX, >100 mA for the duration of transmit
                    • idle waiting for RX1, about 30 mA, 1 second (unless the network says more)
                    • RX1, short spike at 40 mA or so
                    • idle waiting for RX2, about 30 mA, 1 second
                    Overall, the average during awake time is probably around 50 mA or so, but it can vary quite a bit depending on various parameters (mostly TX duration). 100 mA average is probably a worst case.
                    Again, measuring your power profile during a cycle is strongly recommended. Measuring deep sleep current just requires a multimeter and a resistor. Measuring the active cycle requires a bit more hardware, but if you don't have the budget, even something very cheap like this can reveal a wealth of information.
                    Nordic recently announced their new power profiler, I wonder if it's usable for any device or if there any sort of coupling with their own.
                    • H Offline
                      hm97 @jcaron
                      @jcaron said in Deep Sleep and Battery Consumption.:
                      so is that 100mA for the whole awake time or 100mA for just the LoRa TX transmit period? because in your breakdown you also have current draw during RX1 and RX2? do I add this to the 100mA?
                        jcaron @hm97
                        @hm97 current is like a speed, it’s a an instantaneous value which varies up or down over time, and you can average it. So you get a curve that varies during the whole awake time between 30 and over 100 mA.
                        You can then integrate this (multiply each value by the time the current stays at that value) to get mAh (or mAs or anything that is amperes x time), which is what is important when it comes to battery capacity. If current is a speed, this would be the distance travelled, or the length of wire out of spool. This one can only increase over time.
                        It’s like the difference between power (measured in W) and energy (measured in Wh or more commonly kWh). The only difference here is the voltage factor. If you have a 1000 W heater that runs for 8 hours, then it will have used 8000 Wh (8 kWh).
                        • H Offline
                          hm97 @jcaron
                          @jcaron
                          Ah I see. I think I confused myself when I saw the LoRa transmit in the documentation of 105mA and thought it was somehow the overall current draw of the awake time because it was similar to the 100mA you had mentioned before but I get it now. So the current draw is about 100mA (conservative) on average over the awake time.
                          You've been a really great help. Thanks for all your patience :)
