WiPy connection problem after upgrade to 1.5.0.b2
 after updating my WiPy (pycom 2.0) to the latest firmware (1.5.0.b2) I get the following message from Pymakr: "Could not enter friendly repl. (click to attempt to reconnect)" (see picture).
 WiPy is currently connected via USB alternatively I tried to connect via WLAN (factory setting) but with the same result. I also tried putty (serial connection) and FileZilla: no connection.After downgrading to 1.3.0.b1 everything works fine again. I am using Win10 and the latest release of Pymakr. Any ideas? Thanks for your support. Best,
 Makkus
 @Makkus Thinking that a lot of us have the same problem! hope that it's stabilized in the next release!
 @Makkus
 strange but great that you finally solve the problem :)
 @livius Yes, I did, several times :-)
 What helped (this time) was restarting Windows...
 @Makkus
 did you restart your Wipy after upgrade? Maybe you forgot?
 I have also Win10 and no problem.
 @livius After a reboot of my computer it now seems to work (I did the same yesterday, with no effect, strange...). Let's see how stable it is, maybe a problem with the COM-driver? Thanks for your fast reply!
 @livius I flashed the firmware again, but with the same result... :-(
 @Makkus
 strange that you have same problem with filezilla and putty
 try flash firmware once againi have also wipy2 and i can connect to it by ftp and COM
