Syncing RTC To Network Time
@dchappel
In my boot.py after connecting to WiFi, I open up a socket and query the NIST servers, they provide UTC time accurate to the second. You can the parse the string and initialize your RTC from there.
This is all you have to do. However, time will differ, unless you live on the prime meridian.>>import socket >>s=socket.socket() >>s.connect(socket.getaddrinfo("time.nist.gov",13)[0][-1]) >>s.recv(1024) >>'\n57777 17-01-24 16:42:49 00 0 0 595.8 UTC(NIST) * \n'Im using an older firmware that doesn`t include the RTC class, so I have a formula to calculate the epoch time during boot and save it to a variable. This works for most applications as epoch time is more common.
Hope this helps.
@dchappel - to communicate with a ntp server you need the socket.sendto(), however I believe this is not implemented yet.
Also, the rtc interrupts is not implemented yet, so you can't really power down the device int low power mode and wake it up again.
The RTC module is there, but in my opinion it is not yet usable.
I have been looking at the same issue tonight and came up with this script
# imports from machine import Pin import pycom import time import ustruct from machine import RTC import socket from socket import AF_INET, SOCK_DGRAM pycom.heartbeat(False) rtc = RTC() rtc.init((1970, 0, 0, 0, 0, 0, 0, 0)) def getNTPTime(host = "pool.ntp.org"): port = 123 buf = 1024 address = socket.getaddrinfo(host, port)[0][-1] msg = '\x1b' + 47 * '\0' msg = msg.encode() TIME1970 = 2208988800 # 1970-01-01 00:00:00 # connect to server client = socket.socket(AF_INET, SOCK_DGRAM) client.sendto(msg, address) msg, address = client.recvfrom(buf) t = ustruct.unpack("!12I", msg)[10] t -= TIME1970 rtc.calibration(t) return t def pin_handler(arg): print("Got an interrupt in pin %s" % (arg.id())) pycom.rgbled(0x0000ff) time.sleep(1) pycom.rgbled(0x000000) print(getNTPTime()) print(rtc.now()) # use the button on the expansion board P10 p_in = Pin('G17', mode=Pin.IN, pull=Pin.PULL_UP) # on button push trigger pin_handler p_in.callback(Pin.IRQ_FALLING, pin_handler)however the calibration method doesn't like it
>>> Got an interrupt in pin P10 Unhandled exception in interrupt handler Traceback (most recent call last): File "<stdin>", line 36, in pin_handler File "<stdin>", line 28, in getNTPTime OverflowError: overflow converting long int to machine word -
what you got when you do?:
print(str(ustruct.unpack("!12I", msg)[10])) -
t = ustruct.unpack("!12I", msg)[10]returns
1485764691which in python I can normally
>>> time.ctime(1485764691) 'Mon Jan 30 08:24:51 2017' -
@thefebruaryman
ok - then you succesfully got value
but issue is in calibration procedure
but i suppose you can fix problem by setting time byct = time.ctime(t) rtc.init((ct[0], ct[1], ct[2], ct[3], ct[4], ct[5], 0, 0)) -
Here is what I came up with (builds on Knoahlr contribution below):
import socket import machine s=socket.socket() s.connect(socket.getaddrinfo("66.199.22.67",13)[0][-1]) r=s.recv(1024).decode() s.close() year = 2000 + int(r[6:9]) month = int(r[10:12]) day = int(r[13:15]) hour = int(r[16:18]) min = int(r[19:21]) sec = int(r[22:24]) rtc = machine.RTC() rtc.init((year, month, day, hour, min, sec, 0, 0)) print(rtc.now())Current time (in seconds since 1970 / UNIX time) is now available using utime.time().
I found that I needed to use the numeric IP address for NIST. Alpha URL gave me a timeout. Since I got it to work with numeric I didn't go back and try to understand why...
@dchappel You might want to use RegEX,
Assuming Current time is your response from the NIST server.>>import re >>CurrentTime='\n57783 17-01-30 16:14:50 00 0 0 37.8 UTC(NIST) * \n' >>DateList=re.search("[0-9]+-[0-9]+-[0-9]+",CurrentTime).group(0).split("-") >>DateList ['17', '01', '30'] >>TimeList=re.search("[0-9]+:[0-9]+:([0-9]+.[0-9]+)",CurrentTime).group(0).split(":") >>TimeList ['16', '14', '50 00']Cheers.
Ok I got it. I have to use utime for localtime method to work with the large int else you get an error.
from machine import Pin import pycom import utime import ustruct from machine import RTC import socket from socket import AF_INET, SOCK_DGRAM pycom.heartbeat(False) rtc = RTC() rtc.init((1970, 0, 0, 0, 0, 0, 0, 0)) def getNTPTime(host = "pool.ntp.org"): port = 123 buf = 1024 address = socket.getaddrinfo(host, port)[0][-1] msg = '\x1b' + 47 * '\0' msg = msg.encode() TIME1970 = 2208988800 # 1970-01-01 00:00:00 # connect to server client = socket.socket(AF_INET, SOCK_DGRAM) client.sendto(msg, address) msg, address = client.recvfrom(buf) t = ustruct.unpack("!12I", msg)[10] t -= TIME1970 tuple_time = utime.localtime(t) rtc.init((tuple_time)) client.close() def pin_handler(arg): print("Got an interrupt in pin %s" % (arg.id())) pycom.rgbled(0x0000ff) utime.sleep(1) pycom.rgbled(0x000000) getNTPTime() print(rtc.now()) # use the button on the expansion board P10 p_in = Pin('G17', mode=Pin.IN, pull=Pin.PULL_UP) # on button push trigger pin_handler p_in.callback(Pin.IRQ_FALLING, pin_handler) -
We've just finished adding support for a NTP (SNTP) client. Syncing time will be as easy as:
import machine rtc = machine.RTC() rtc.ntp_sync("pool.ntp.org") # select an appropriate serverBy default it will resync every hour, but you can change the period by passing it as a parameter:
rtc.ntp_sync("pool.ntp.org", 1200) # do it every 20 minutesThis feature will probably be included in the next release. Hope you'll find it useful.
@abilio that's great news and much easier to use. Cheers for the good work!
@abilio Will the method sync the RTC to local time or UTC ?
@Knoahlr, to UTC, but then you'll be able to set the time offset calling:
time.timezone(3600) # GMT +1 for the NetherlandsA call to
time.localtime()will return the time using the provided offset. If you want the number of seconds since Epoch adjusted to the timezone, you can do something like:time.time() + time.timezone()Also,
time.gmtime()will be included, working liketime.localtime(), but without adjusting for the offset.So far, this is what would be available in the release.
@abilio Great, amazing feature.
@abilio Apparently this is not yet implemented in 1.6.1.b1 ?
'1.6.1.b1' >>> os.uname() (sysname='LoPy', nodename='LoPy', release='1.6.1.b1', version='v1.8.6-450-g31ef5170 on 2017-02-15', machine='LoPy with ESP32', lorawan='1.0.0') >>> import machine >>> rtc = machine.RTC() >>> rtc.ntp_sync("pool.ntp.org") Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: 'RTC' object has no attribute 'ntp_sync' >>> >>> import time >>> time.timezone(3600) Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: 'module' object has no attribute 'timezone' -
@rdixey, you are totally right and I must personally apologize for it. We forgot to merge it with master just to realize it after making the release (yeah, it happened twice :( ) . I will work so is included in the next firmware release.
@abilio These new rtc.ntp_sync() & time.timezone() functions work nicely with the 1.6.4.b1 update. They are very convenient!
I think there is a typo on the Utime doc page though. The first function listed there is utime.mktime([secs]), is this intended to be utime.gmtime()?
Thanks for the good work on this :)
@rdixey said in Syncing RTC To Network Time:
mktime
It is standard in many languages - google for it ;-)
Its not working for me :-(
Can you post a working example?
@santorcuato I used it as a function in the boot.py of my LoPy. I had to set a delay to allow for the round trip to pool.ntp.org or else the function completed before ntp_sync and RTC remained = Unix Epoch . When I ping pool.ntp.org from my LAN the longest round trip was 630ms so I set sleep at 750ms. Less than that was too short.
def setRTCLocalTime(): rtc = machine.RTC() rtc.ntp_sync("pool.ntp.org") utime.sleep_ms(750) print('\nRTC Set from NTP to UTC:', rtc.now()) utime.timezone(-18000) print('Adjusted from UTC to EST timezone', utime.localtime(), '\n')Connecting to a LoPy... Connected >>> PYB: soft reboot RTC Set from NTP to UTC: (2017, 2, 26, 13, 18, 54, 225113, None) Adjusted from UTC to EST timezone (2017, 2, 26, 8, 18, 54, 6, 57)
