    Syncing RTC To Network Time
    24 Posts 8 Posters 13.8k Views 10 Watching
      livius @thefebruaryman
      @thefebruaryman
      ok - then you succesfully got value
      but issue is in calibration procedure
      but i suppose you can fix problem by setting time by
      ct = time.ctime(t)
      rtc.init((ct[0], ct[1], ct[2], ct[3], ct[4], ct[5], 0, 0))
        dchappel
        Here is what I came up with (builds on Knoahlr contribution below):
        s=socket.socket()
        s.connect(socket.getaddrinfo("66.199.22.67",13)[0][-1])
        r=s.recv(1024).decode()
        s.close()
        year = 2000 + int(r[6:9])
        month = int(r[10:12])
        day = int(r[13:15])
        hour = int(r[16:18])
        min = int(r[19:21])
        sec = int(r[22:24])
        rtc = machine.RTC()
        rtc.init((year, month, day, hour, min, sec, 0, 0))
        print(rtc.now())
        Current time (in seconds since 1970 / UNIX time) is now available using utime.time().
        I found that I needed to use the numeric IP address for NIST. Alpha URL gave me a timeout. Since I got it to work with numeric I didn't go back and try to understand why...
        • K Offline
          Knoahlr @dchappel
          @dchappel You might want to use RegEX,
          Assuming Current time is your response from the NIST server.
          >>import re
          >>CurrentTime='\n57783 17-01-30 16:14:50 00 0 0  37.8 UTC(NIST) * \n'
          >>DateList=re.search("[0-9]+-[0-9]+-[0-9]+",CurrentTime).group(0).split("-")
          >>DateList
          ['17', '01', '30']
          >>TimeList=re.search("[0-9]+:[0-9]+:([0-9]+.[0-9]+)",CurrentTime).group(0).split(":")
          >>TimeList
          ['16', '14', '50 00']
          Cheers.
            thefebruaryman
            Ok I got it. I have to use utime for localtime method to work with the large int else you get an error.
            from machine import Pin
            import utime
            import ustruct
            from machine import RTC
            from socket import AF_INET, SOCK_DGRAM
            pycom.heartbeat(False)
            rtc = RTC()
            rtc.init((1970, 0, 0, 0, 0, 0, 0, 0))
            def getNTPTime(host = "pool.ntp.org"):
                port = 123
                buf = 1024
                address = socket.getaddrinfo(host,  port)[0][-1]
                msg = '\x1b' + 47 * '\0'
                msg = msg.encode()
                TIME1970 = 2208988800 # 1970-01-01 00:00:00
                # connect to server
                client = socket.socket(AF_INET, SOCK_DGRAM)
                client.sendto(msg, address)
                msg, address = client.recvfrom(buf)
                t = ustruct.unpack("!12I", msg)[10]
                t -= TIME1970
                tuple_time = utime.localtime(t)
                rtc.init((tuple_time))
                client.close()
            def pin_handler(arg):
                print("Got an interrupt in pin %s" % (arg.id()))
                pycom.rgbled(0x0000ff)
                utime.sleep(1)
                pycom.rgbled(0x000000)
                getNTPTime()
                print(rtc.now())
            # use the button on the expansion board  P10
            p_in = Pin('G17',  mode=Pin.IN,  pull=Pin.PULL_UP)
            # on button push trigger pin_handler
            p_in.callback(Pin.IRQ_FALLING,  pin_handler)
              abilio
              We've just finished adding support for a NTP (SNTP) client. Syncing time will be as easy as:
              rtc = machine.RTC()
              rtc.ntp_sync("pool.ntp.org") # select an appropriate server
              By default it will resync every hour, but you can change the period by passing it as a parameter: rtc.ntp_sync("pool.ntp.org", 1200) # do it every 20 minutes
              This feature will probably be included in the next release. Hope you'll find it useful.
              T K R 3 Replies Last reply Reply Quote 4
                thefebruaryman @abilio
                @abilio that's great news and much easier to use. Cheers for the good work!
                • K Offline
                  Knoahlr @abilio
                  @abilio Will the method sync the RTC to local time or UTC ?
                    abilio @Knoahlr
                    @Knoahlr, to UTC, but then you'll be able to set the time offset calling:
                    time.timezone(3600) # GMT +1 for the Netherlands
                    A call to time.localtime() will return the time using the provided offset. If you want the number of seconds since Epoch adjusted to the timezone, you can do something like:
                    time.time() + time.timezone()
                    Also, time.gmtime() will be included, working like time.localtime(), but without adjusting for the offset.
                    So far, this is what would be available in the release.
                    • K Offline
                      Knoahlr @abilio
                      @abilio Great, amazing feature.
                        rdixey @abilio
                        @abilio Apparently this is not yet implemented in 1.6.1.b1 ?
                        '1.6.1.b1'
                        >>> os.uname()
                        (sysname='LoPy', nodename='LoPy', release='1.6.1.b1', version='v1.8.6-450-g31ef5170 on 2017-02-15', machine='LoPy with ESP32', lorawan='1.0.0')
                        >>> import machine
                        >>> rtc = machine.RTC()
                        AttributeError: 'RTC' object has no attribute 'ntp_sync'
                        >>> import time
                        >>> time.timezone(3600)
                        AttributeError: 'module' object has no attribute 'timezone'
                          abilio @rdixey
                          @rdixey, you are totally right and I must personally apologize for it. We forgot to merge it with master just to realize it after making the release (yeah, it happened twice :( ) . I will work so is included in the next firmware release.
                            rdixey @abilio
                            @abilio These new rtc.ntp_sync() & time.timezone() functions work nicely with the 1.6.4.b1 update. They are very convenient!
                            I think there is a typo on the Utime doc page though. The first function listed there is utime.mktime([secs]), is this intended to be utime.gmtime()?
                            Thanks for the good work on this :)
                            L S 2 Replies Last reply Reply Quote 0
                              livius @rdixey
                              @rdixey said in Syncing RTC To Network Time:
                              mktime
                              It is standard in many languages - google for it ;-)
                              R 1 Reply Last reply Reply Quote -1
                                santorcuato @rdixey
                                Its not working for me :-(
                                Can you post a working example?
                                  rdixey @santorcuato
                                  @santorcuato I used it as a function in the boot.py of my LoPy. I had to set a delay to allow for the round trip to pool.ntp.org or else the function completed before ntp_sync and RTC remained = Unix Epoch . When I ping pool.ntp.org from my LAN the longest round trip was 630ms so I set sleep at 750ms. Less than that was too short.
                                  def setRTCLocalTime():
                                      rtc = machine.RTC()
                                      utime.sleep_ms(750)
                                      utime.timezone(-18000)
                                  Connecting to a LoPy...
                                  Connected
                                  PYB: soft reboot
                                  RTC Set from NTP to UTC: (2017, 2, 26, 13, 18, 54, 225113, None)
                                  Adjusted from UTC to EST timezone (2017, 2, 26, 8, 18, 54, 6, 57)
                                    rdixey @livius
                                    @livius Excuse Me :) I already know what mktime() is. And I don't need anyone to give me instructions on using google to find info. I was pointing out a typo in the doc's.
                                    https://docs.pycom.io/pycom_esp32/library/utime.html
                                    mktime is the first function in the list and is described as 'Convert a time expressed in seconds since the Epoch.' I believe this is an error and should be gmtime().
                                    mktime is listed again as the third functon and described correctly.
                                    gmtime() is not in the list at all.
                                    L 1 Reply Last reply Reply Quote 2
                                      livius @rdixey
                                      instructions
                                      Without explanation that function is twice in doc - this was my first hint ;-)
                                        santorcuato @rdixey
                                        @rdixey Ok, it seems interesting. Will try!
