    GPY deepsleep High current
    28 Posts 5 Posters 462 Views 5 Watching
      tuftec @bouchard.claude
      @bouchard-claude
      I would expect that the power consumption should be pretty low with your test setup. I think we need some comment from Pycom on this one.
      I expect it is still tied up with the LTE modem power down bug.
        bouchard.claude @tuftec
        @tuftec You are right as this setup cannot be more simple and it show a consumption many more time the one I was planning for according to the doc, affecting greatly my estimated battery life ( wake up 2 time a day, so most of current is sleeping). I'm not sure how to get the attention of someone from Pycom as this is a community forum, but I think we will require this ( I really dont know what else I can test on my side).
        Ill try to understand how it work to contact them or if they read message on this board.
        Meanwhile thanks for the help.
        T K 2 Replies Last reply Reply Quote 0
          @bouchard-claude
          @Gijs can you help with this one. Maybe you could supply some clarity on the expected low power performance when using LTE.
          Peter.
          • K Offline
            kjm @bouchard.claude
            @bouchard-claude Try
            import pycom; pycom.lte_modem_en_on_boot(0); pycom.wifi_on_boot(0)
            at the start of your program to be sure both radios are off to begin with. My gpy (1.20.1.r1) deepsleeps at 40uA
              tuftec @kjm
              @kjm Sure just setting those boot flags once the program has started is too late. They will alter the next boot behaviour but not this one???????
              From what I have read a lte.init(); lte.deinit() cycle should power the modem down.
              Maybe the issue is actually the wlan. In my setup the wlan is on by default at boot and I specifically disable it with wlan.deinit() when I no longer need it, based on the status of a switch.
                @tuftec Yeah, my understaning too is that thoses flag are to be set once, cause once the main.py is loaded, its way too late. But I did try and set the wifi on boot to 0 using the shell over serial, and I did re-test with no difference. As for the LTE on boot, well, I really need to use it during operation ( data is sent overs CAT-1 LTE). I can try and test it tomorow, but that wont solve my problem :S ( but maybe it would point to a direction)
                  @bouchard-claude Yes, I understand you need LTE but do you use wifi (wlan).
                  In my application I use wlan, lora, sigfox & nb-iot. I make decisions at various stages in my code to enable/disable the relevant radio system that I need.
                  The wifi is typically on when the system boots so that you can set up a REPL connection over wifi. I deliberately turn it off and disable the REPL server at and early stage when I determine that I do not need it. turn it on only as a system configuration aide in the field. Otherwise, I need it to be off for security. You might need to explore turning off all the bits you do not need.
                    bouchard.claude
                    yes, exactly what i'm doing too. This project only required LTE, so im only powering one the LTE radio, and only during time for transmission and deinit it after. As for the Wifi, I did set the power_on_boot to off as a first setup thing once I pushed the initial code.
                    So I just did the test with the lte_on_boot and wifi_on_boot ( I set them manualy + put them in a empty main.py code with only thoses and a deepsleep command) and the current stayed a 266 uA all the time in the deepsleep. So even with the radio not on at boot the currect of the board is high
                    I'm using GPy with firmware version 1.20.2.r3 . Any way to see what changed between version?
                      @bouchard-claude You could try wading through all the release logs looking for changes, but I have not found a lot of joy in that previously. Maybe you need to test the old 1.20.1r1 release on you Gpy. Hopefully that will provide some insight.
                      I would also do the wlan init/deinit thing early in your code just to be sure it is off. Also disable the server in the same way. server.deinit() after you have defined it. The server interacts with the wlan. I am not sure if it enables it without you knowing. Worth a try anyway.
                        bouchard.claude
                        Yeah, but all the test im running now are with no code , Only the deepsleep and the stuff we are trying ( no lte on boot, no wifi on boot, lte deinit() ...) and it has the exact same current draw then with my complete code during deepsleep.
                        A weird things I just found is every time I run this to check my firmware version:
                        import sqnsupgrade
                        sqnsupgrade.info()
                        it give me the info, then immetiatly crash, core dump and restart . So maybe something is up with the whay the firmware deal with the modem? Ill try and switch versions to see if it help.. And also will try on a different GPy ( and a fipy) when ill have some time
                          @bouchard-claude Are you getting the crash with your current measuring device in circuit? Previously when I was doing low current measurements, on devices that were capable of considerably higher current draw, I would wire a shut switch across my meter so that I could bypass it when I needed full current. Usually a device capable of measuring ultra low currents is not capable of handling the full power requirements of the device.
                          Typically I would start the system with the shut switch closed, then place the device into its low power state and open the switch just to take the low current measuement. This avoids any issues with large voltage drops across you meter when the current ramps up.
                            @tuftec Exactly what I do too ;) I have a shut switch that i open once the device is deepsleeping only. ( my test that make it crash is using the USB connection and the breakout board to a computer, no current measurement taken during this test.)
                              @bouchard-claude Interesting.
                              Just tried the sqnsupgrade.info() test with a FiPy on my breakout board (V3.1) and get exactly the same issue. It crashes after displaying the modem information. Something about a prohibited Store!!!!!
                              >>> import sqnsupgrade
                              2020/12/30 17:34:59: import sqnsupgrade
                              >>> sqnsupgrade.info()
                              2020/12/30 17:35:20: sqnsupgrade.info()
                              <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
                              >>> FiPy with firmware version 1.20.2.r3
                              2020/12/30 17:35:29: Your modem is in application mode. Here is the current version:
                              2020/12/30 17:35:31: UE6.0.0.0
                              LR6.0.0.0-41019
                              IMEI: 354346090972786
                              Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
                              Core 0 register dump:
                              PC      : 0x4019072a  PS      : 0x00060830  A0      : 0x801901df  A1      : 0x3ffbaef0
                              A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000005  A5      : 0xffffffff
                              A6      : 0x00021266  A7      : 0x00060021  A8      : 0x8018fde0  A9      : 0x3ffbaeb0
                              A10     : 0x0000002c  A11     : 0x00000000  A12     : 0x3ffb9f28  A13     : 0x00000000
                              A14     : 0x3ffb9f38  A15     : 0x00000001  SAR     : 0x00000000  EXCCAUSE: 0x0000001d
                              EXCVADDR: 0x0000002d  LBEG    : 0x4009412c  LEND    : 0x4009415a  LCOUNT  : 0xffffffff
                              Backtrace: 0x4019072a:0x3ffbaef0 0x401901dc:0x3ffbaf10 0x40180044:0x3ffbaf30
                              MDwAAAEAAAARAAAAbAEAAA==
                              tJ/7PzCu+z/Er/s/
                              0K37P2Cv+z/EEgIAjEP8P4xD/D+0n/s/hEP8PwcAAAAIn/s/CJ/7P7Sf+z8AAAAA
                              EgAAAMih+z90aVQAZEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIAoGABIAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                              GIpAPwAAAABQUAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                              /////yoHGUAwCAYA3wEZgPCu+z8AAAAAAAAAAAUAAAD/////ZhICACEABgDg/RiA
                              sK77PywAAAAAAAAAKJ/7PwAAAAA4n/s/AQAAAAAAAAAdAAAALQAAACxBCUBaQQlA
                              /////yif+z8AAAAAyDMIQFyz9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAABcAGIAAr/s/aBX9PzCv+z9HABiAEK/7P9Cl/T8wr/s/
                              AAAAADCv+z94ZxhAAAAAAAAAAAAwr/s/0KX9PwAAAADkHv0/5B79P+Ae/T/gHv0/
                              AAAAAGCv+z8AAAAAAAAAAKCl/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              OE37P0BL+z8wTfs/
                              QEv7P9BM+z+SEgIAnEL8P5xC/D84Tfs/lEL8PxMAAAC6nCwNw5N71ThN+z8AAAAA
                              BgAAADQ9+z9Mb1JhAAYr8MybzgQ3L9MAAQAAADBN+z8AAAAAIAoGAAYAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH2MGQ==
                              LDQIQNJrCUAwAQYAaDIRgABM+z+SEgIAQN37P3wt+z8AAAAAAAAAAAAAAADSawmA
                              4Ev7PwEAAACSEgIAOE37PwEAAAD+AAAAIAAGAAAAAADMUPU/AAAAAAAAAAAAAAAA
                              AAAAACw2CEABAAAAJIAJQMxQ9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAKWlpaWlpaWlpaWlpaWlpaUAAAAAIEz7P9iZ/D9smvw/
                              fC37PwAAAAAAAAAAAAAAAAAAAADQTPs/AAAAAAAAAADQTPs/AAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADMUPU/AAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQ8kM/AAAAAGya/D8AAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Ez7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              HLP7PxDM/T9wzf0/
                              EMz9PxDN/T+SEgIAiEL8P4hC/D8cs/s/gEL8PxQAAAAAAAAAAAAAAByz+z8AAAAA
                              BQAAAHS9/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAHDN/T8AAAAAIQAGAAUAAAAAAAAA
                              LDQIQNJrCUAwAQYA3AIOgNDM/T+SEgIAQN37PwAAAAAA/wAAAAD/AAAAAP/SawmA
                              sMz9PwEAAACSEgIAHLP7PwEAAAD+AAAAIAAAAAAAAAAAAAAAAAAAAB1KCUAzSglA
                              +f///yw2CEABAAAAJIAJQAzR9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAByz+z8BAAAA/gAAACAAAAAAAAAA8Mz9PwAAAAAAAAAA
                              AAAAAAD/AAAAAP8AAAAA/wAAAAAQzf0/AAAAAAAAAAAAAAAAAQAAAG5K/D8AAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHM39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              QLn7P6C3+z84ufs/
                              oLf7P9C4+z+gPXvJvL77PyRC/D9Aufs/HEL8PxkAAABy4B5rJEUlk0C5+z8AAAAA
                              AAAAADy1+z9JRExFMABZoLydZSS6sAUAAAAAADi5+z8AAAAAIQAGAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGBMtQ==
                              LDQIQEIQIkAwCgYARnMXgGC4+z8AAAAAAAAAAAAAAACQePs/AwAAACMABgAQkvw/
                              /////4RB/D8kQvw/I14JgJB4+z8DAAAAIwAGAAAAAABguPs/BEUPQAAAAAAAAAAA
                              AAAAACw2CECQePs/JIAJQMy89T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACIbgmAgLj7PyAAAAABAAAA
                              //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAAKxB/D8AAAAAbBT9PxBE/D8AAAAA
                              AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              tL77PxC9+z+svvs/
                              EL37P0C++z+B++S7JEL8P0i5+z+0vvs/HEL8PxkAAAB6smU13UbsQLS++z8AAAAA
                              AAAAALC6+z9JRExFMQAjT19MxZ3cnXoAAQAAAKy++z8AAAAAIQAGAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAO3vPw==
                              LDQIQEIQIkAwDwYARnMXgNC9+z8AAAAAIwAGAKwF/D+oBfw/AAAAACAABgD//z+z
                              q6sAACS/+z+Uz/s/aOH7PwAAAAAgAgYAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
                              AAAAACw2CEAAAAAAJIAJQDzC9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAsNghAbBT9PySACUCIbgmA8L37PyAAAAABAAAA
                              //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAAKxB/D8gAAAAbBT9PxRE/D8AAAAA
                              AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              dF77PxA9/T8cP/0/
                              ED39P7A+/T+TEgIAEEL8PxBC/D90Xvs/CEL8PxMAAACgA5P7Bj1mz3Re+z8AAAAA
                              BgAAACAx/T9TaWdmb3gAI3CY/uFAZHIAAAAAABw//T8AAAAAIQAGAAYAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcDAA==
                              LDQIQNJrCUAwDAYAAoQggNA9/T+TEgIAQN37P2hc+z8AAAAAAAAAAAAAAADSawmA
                              sD39PwAAAACTEgIAdF77PwEAAAD+AAAAIwAGABEAAACsQvc/AAAAAKwyCUC3MglA
                              /////yw2CEABAAAAJIAJQKxC9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA8D39P2Qv/T9gL/0/
                              aFz7PwAAAAAAAAAAAAAAAAAAAACwPv0/AAAAAAAAAAAsNAhA6IMgQDAABQAAAAAA
                              sD79PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              rEL3PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALw+/T8AAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                              IMv7P8DJ+z8Yy/s/
                              wMn7P7DK+z8AAAAA/EH8P/xB/D8gy/s/9EH8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
                              CgAAABzB+z9UbXIgU3ZjAPtyN2/k2mYAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH/K/w==
                              LDQIQLl9CUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAgRPw/GET8PwEAAAC5fQmA
                              YMr7PwAAAABA3fs/dEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAACw2CEAAAAAAJIAJQKzO9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAKzO9T8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
                              AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAA=
                              MHz7P7Cc+z84nvs/
                              sJz7P9Cd+z8GtqDZtLH7P4zX+z8wfPs/mEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                              GAAAADya+z9pcGMxAOlHce47sQIDU/YAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGUKxw==
                              LDQIQMRaCUAwAwYA3DEIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAADEWgmA
                              UJ37PwEAAAD/////QN37PxBE/D/+AAAAIAMGABwAAAAAAD4AAAAAAKwyCUC3MglA
                              /////yw2CEAQRPw/JIAJQMyh9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAoyCICQnfs/wKr9PwEAAAAAAAAAsJ37PyxB/D8kQfw/
                              AAAAACcAAAAAAAAAIAMGAP////8AAAAALEH8PxhB/D8kfPs/AAAAANh7+z8BAAAA
                              AAAAANCd+z8AAAAAAAAAAEwbF0DAqv0/AAAAAAAAAACkFAiAgH3+PwABAADoDQBA
                              AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAA=
                              rLH7P9C7/T9svf0/
                              0Lv9PwC9/T+AuAAA3N79Pzh8+z+ssfs/mEH8PxQAAAAUOQhA0LH7P6yx+z8AAAAA
                              BQAAAHCt/T9TbWFydENvbmZpZwBCAAAAAQAAAGy9/T8AAAAAIQAGAAUAAAAAAAAA
                              2020/12/30 17:35:32: AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                              LDQIQPC/AEAwAAYA7GYJgJC8/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                              q6sAABDd+z8jAAYArLH7PwEAAAD+AAAAeAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                              AAAAACw2CEABAAAAJIAJQPzA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAoLz9P0Dd+z8FAAAA
                              hHEOgMC8/T8BAAAAFET8P6yx+z8BAAAA/gAAACADBgAAAAAA4Lz9PwAAAAAAAAAA
                              EET8P0Dd+z+EQfw/iEL8PwAAAAAAvf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADL39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              1N79PzDd/T/M3v0/
                              MN39P2De/T8Inbcg8OT9P7Sx+z/U3v0/mEH8PxQAAABJtporXy+TxdTe/T8AAAAA
                              BQAAANDO/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAMze/T8AAAAAIQAGAAUAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAANny9A==
                              LDQIQPC/AEAwAAYA7GYJgPDd/T8AAAAAIwAGACAABgDAqv0/VQAAANC8/T///z+z
                              q6sAABDd+z8jAAYA1N79PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                              AAAAACw2CEABAAAAJIAJQFzi9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAAN79P0Dd+z8GAAAA
                              YmEOgCDe/T8BAAAAFET8P9Te/T8BAAAA/gAAALCd+z8AAAAAQN79PwAAAAAAAAAA
                              EET8P0Dd+z+EQfw/iEL8PwAAAABg3v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbN79PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              6OT9P0Ai/j9YJP4/
                              QCL+P/Aj/j+pchOmtFr7P9ze/T/o5P0/mEH8Pw4AAACkzf0/pM39P+jk/T+czf0/
                              CwAAAFwE/j9JUlFzAI9f5PepypoivzEAAQAAAFgk/j8AAAAAIQAGAAsAAAAAAAAA
                              AAAAAIwj/j8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApGujA==
                              LDQIQMRaCUAwCgYAZEgPgAAj/j94zf0/oCP+P8TN/T8AAAAAzM39PwAAAADEWgmA
                              4CL+PwEAAAD/////QN37PxBE/D/+AAAAAAAAAAAAAADsJ/g/AAAAAAAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQOwn+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAuAAAApaWlpaWlpaVgCg6AQCP+P5iS/D+gI/4/
                              AAAAACEBAAClpaWlpaWlpf////9AI/4/xJX8P6Aj/j8AAAAAAQAAAABk+z/8////
                              AAAAANAj/j+Mkvw/AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAjJL8PwAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgI/4/
                              ABwAAGiU/D9olPw/AAAAAOwn+D8AAAAAAAAAAAAAAABolPw/CgAAAIRB/D8AQ/w/
                              AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAD8I/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAA=
                              rFr7PxBZ+z+kWvs/
                              EFn7P0Ba+z/5qHhThHL7P/Dk/T+sWvs/mEH8PxEAAABUPPs/VDz7P6xa+z9MPPs/
                              CAAAAKhO+z9Mb1JhX1RpbWVyX2NhbGwAAQAAAKRa+z8AAAAAIQAGAAgAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKljAg==
                              LDQIQMRaCUAwAAYAbB0RgNBZ+z8oPPs/EFr7P3Q8+z8AAAAAfDz7PwAAAADEWgmA
                              sFn7PwEAAAD/////QN37PxBE/D/+AAAAIwAGAAAAAAAQWvs/AAAAAAAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQDxe9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAsNghABwAAACSACUAAAAAAEFr7P5Sb/D8AAAAA
                              AAAAACEBAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAA8XvU/AAAAAAAAAAAAAAAA
                              AAAAAEBa+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATFr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              fHL7P+Bw+z90cvs/
                              4HD7PxBy+z92J2sRcHr7P7Ra+z98cvs/mEH8PwMAAABAQPw/QED8P3xy+z84QPw/
                              FgAAAHhm+z9lc3BfdGltZXIALtTkX3IAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACbvIw==
                              LDQIQMRaCUAwDAYA9SMNgKBx+z8UQPw/AAAAAGBA/D8AAAAAFED8PwAAAADEWgmA
                              gHH7PwAAAAD/////QN37PxBE/D/+AAAAIAAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQAx29T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4HH7P2hA/D9wQPw/
                              AAAAACyJAQAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAMdvU/AAAAAAAAAAAAAAAA
                              AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHBA/D8PAAAG
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              aHr7P+B4+z9gevs/
                              4Hj7PwB6+z+rUUObMEf9P4Ry+z9oevs/mEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                              GAAAAGR2+z9pcGMwAFD6cyC5jEFHYuUAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMVNbg==
                              LDQIQMRaCUAwDAYA3DEIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAADEWgmA
                              gHn7PwAAAAD/////QN37PxBE/D/+AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQPx99T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PyhB/D8AAAAA
                              AAAAAJmbAQD+AAAAAQAAAP////8AAAAAKEH8PxhB/D8Advs/AAAAAAEAAAAAAAAA
                              AAAAAAB6+z8AAAAAAAAAACR8CEAAAAAAAAAAAAAAAAAZFAiAIDz+P4BB/D8PbEA/
                              AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              KEf9P5BF/T8gR/0/
                              kEX9P8BG/T94HRg79EX8P3B6+z8oR/0/mEH8Pw0AAABg/f0/YP39PyhH/T9Y/f0/
                              DAAAACQ//T9MVEVfVUFSVF9FVlQAgmcAAQAAACBH/T8AAAAAIQAGAAwAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALeEw==
                              LDQIQMRaCUAwAAYAZkMRgFBG/T80/f0/kEb9P4D9/T8AAAAAiP39PwAAAADEWgmA
                              MEb9PwEAAAD/////QN37PxBE/D/+AAAAXAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQLxK9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEb9P6Sb/D8AAAAA
                              AAAAAJESAgAAAAAAAAAAAP////8AAAAAAAAAAAAAAAC8Svc/AAAAAAAAAAAAAAAA
                              AAAAAMBG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzEb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              7EX8P4Ck/T9orf0/
                              gKT9PwCt/T+REgIAoEH8PzBH/T/sRfw/mEH8Pw4AAADI//0/yP/9P+xF/D/A//0/
                              CwAAAGx9/T9NaWNyb1B5AAAAAAAAAAAAAQAAAGit/T8AAAAAIQAGAAsAAAABAAAA
                              lH/7PxSU/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
                              LDQIQMRaCUAwCAYAAP0YgECl/T+c//0/AAAAAOj//T8AAAAAnP/9PwAAAADEWgmA
                              IKX9PwEAAAD/////QN37PxBE/D/+AAAA0KT9Pw4AAAD4vgCAAKX9PyxBCUBaQQlA
                              /////yw2CEAQRPw/JIAJQPyw9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAP0BGIBwpf0/aBX9P6Cl/T8EAhiAgKX9P+QAvD8AAAAA
                              AAAAAJISAgD+AAAA0KT9P/////8AAAAAIAAAAAAAAACUAhmAoKX9P9QBGUDQpf0/
                              lAIZgKCl/T/UARlA0KX9P5ISAgABAAAA/gAAABT8RT+wQBGA0KX9PwAAAAAAAAAA
                              AQAAANQBGUDQpf0/5AC8P2gV/T8BAAAACwAAAAEAAAAlSBGAEKb9PwAAAAABAAAA
                              /SAQgAAAAAAASBFAAAAAAAEAAAAApv0/4AJEP8QEAAAoR/0/AAAAAAwAAAAACAAA
                              /SAQgDCm/T8cSBFAAAAAAAAIAAAAAAAAEQIAALoFAAA85Q+AUKb9P7wERD8AAAAA
                              AAAAAAEAAAAKAAAA0Kf9P6b0D4Bwpv0/vAREPwAAAAAAAAAArKf9Pyim/T8SEwAA
                              POUPgJCm/T+wDJU/AAAAAAAAAACsp/0/AAAAAJYQAADM5Q+AsKb9P7AMlT8AAAAA
                              AAAAAKyn/T+gzEA/BLZAP4alEIDQpv0/AAAAAAAAAAAAAAAArKf9PwIAAAAyCQAA
                              KyIQgPCm/T8EAAAAPslCP6Sn/T+op/0/GKf9P4Cn/T885Q+AkKf9P0D1lD9A9ZQ/
                              EKj9PwAAAAArIhCA8Kb9PwgAAACwp/0/rKf9P6Sn/T8AAAAAAwAAAEA8QD9Eg0I/
                              EKj9P2Cn/T885Q+AkKf9P0D1lD9A9ZQ/0pcQgAAAAAAHAAAApKf9PwAAAAADAAAA
                              AAAAAJCn/T+wp/0/rKf9PygLlT/HhEI/ooRCPyALlT+kp/0/MP///z/JQj+kp/0/
                              +KQQgPCn/T+Q+pQ/AAAAAJD6lD89yUI/oKf9P6Sn/T9A9ZQ/sAyVPwAAAAASEwAA
                              AAAAACw2CEAoC5U/JIAJQAAAAAAAAAAAAAAAAAAAAACQp/0/KAuVPwAAAADAp/0/
                              KyIQgBCo/T8AAAAA1oRCPwAAAAAoC5U/AAAAAAEAAAA85Q+AsKj9P0D1lD9olPw/
                              IKn9P0Co/T8rIhCAEKj9PwgAAABUC5U/UAuVP0gLlT8DAAAADAAAAAjPQD8Wz0A/
                              FJT8P+D0lD885Q+AsKj9P0D1lD9olPw/0pcQgAjPQD8IAAAASAuVPwAAAAAJAAAA
                              AAAAABALlT9UC5U/UAuVP+Cp/T8UlPw/BwAAAALRdgEkC5U/MP///9eEQj8AAAAA
                              zOUPgOCo/T9QCpU/AAAAAAAAAAAAAAAAAAAAAE40CEAQC5U/4Kn9PzAAAACwqP0/
                              hqUQgACp/T8AAAAAAAAAAAAAAADgqf0/JHD0PwAAAAArIhCAIKn9PwQAAAC4C5U/
                              2Kn9P7Cp/T9Iqf0/sKn9PzzlD4DAqf0/aJT8P2iU/D9gqv0/YKn9PysiEIAgqf0/
                              CAAAAOCp/T/cqf0/1Kn9PwAAAAADAAAAAQAAAPTQQD8AAAAAAAAAADzlD4DAqf0/
                              aJT8P2iU/D/SlxCAIAAAAAgAAADUqf0/AAAAAAMAAAAAAAAAwKn9P+Cp/T/cqf0/
                              AAAAAJSp/T8BAAAAAwAAANip/T8w////uQuVPwMAAABp5Q+AIKr9PzADlT8AAAAA
                              MAOVP7cLlT/Qqf0/1Kn9P2iU/D+8B0E/UAqVPwAAAACRQAiAEKr9PzCq/T8AAAAA
                              AAAAAAAAAAAQC5U/AAAAAMCp/T8AAAAAAAAAAPCp/T94Fg6AQKr9PzADlT8AAAAA
                              AAAAAAAAAAAFAAAAAAAAAAMZDoBgqv0/MAOVPxYAAAAAAAAAAAAAAAAAAABIC5U/
                              vAEOgACr/T8FGUA/AAAAAAAAAACQqv0/AxkOgGCq/T8QT/w/AAAAABYAAABcAAAA
                              IgAAAAgAAAANAAAA8E78Pw0AAAAAAAAAvAEOgACr/T8FGUA/AAAAAPQVDoBwDpU/
                              MA6VP+Cq/T8Aq/0/yRhAPwAAAADwTvw/EgAAAGD1lD8WAAAAAKv9PyvpAQAAAAAA
                              FgAAAFwAAAAiAAAACAAAAAAAAABAq/0/RPj7P2is/T8gAAAAEgAAANDslD9orP0/
                              mM9DP0Cr/T+wR/w/aKz9P1Cr/T/gqv0/7Ef8PwAQAAAAAAAAAK39PwAAAAAAAAAA
                              AQAAAKWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                              paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                              paWlpaWlpaWlpaWlpaWlpSw0CEAc/Q1AMAAFAAAAAAAArf0/AAAAAAAAAAAAAAAA
                              AAAAAAEAAAAAAAAAgB0dAAEAAAD/////////////////////mqwqNAAAAAAAAAAA
                              AAAAAADwHwBAq/0/AAAAAAAAKAAAAAAAAAAAAAAAAAABAAAAAAAAAAEAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAADK39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                              hNf7P1B7/T8Eff0/
                              UHv9P6B8/T+HyTvSOHz7P6BB/D+E1/s/mEH8PwUAAABY0fs/WNH7P4TX+z9Q0fs/
                              FAAAAAhx/T9ldmVudFRhc2sAF+s7N9gAAAAAAAR9/T8AAAAAIQAGABQAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABbWIg==
                              LDQIQMRaCUAwAAYAfHQXgBB8/T8s0fs/UHz9P3jR+z8AAAAAgNH7PwAAAADEWgmA
                              8Hv9PwAAAAD/////QN37PxBE/D/+AAAAKNH7PwAAAAClpaWlpaWlpQAAAAAAAAAA
                              AAAAACw2CEAQRPw/JIAJQJyA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                              AAAAAAAAAAAAAAAAAAAAAKB8/T8AAAAAAAAAAAAAAAAAAAAAUHz9P7wU/T8AAAAA
                              AAAAAAAAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAKB8/T8AAAAAAAAAAJyA9z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAAAAAACsfP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                              AAAAAA==
                              Rebooting...
                              ets Jun  8 2016 00:22:57
                              configsip: 0, SPIWP:0xee
                              mode:DIO, clock div:1
                              load:0x3fff8020,len:8
                              load:0x3fff8028,len:2128
                              load:0x4009fa00,len:19760
                              entry 0x400a05bc
                              2020/12/30 17:35:37: SYSTEM RESTART?```
                              Maybe @gijs can help here.
                              I have not seen this previously.
                              Maybe something to do with firmware V 1.20.2.r3 ????
                              • K Offline
                                @bouchard-claude My 40uA deepsleep is just the gpy, does not include any current drawn by an expansion board.
                                  bouchard.claude @kjm
                                  @kjm said in GPY deepsleep High current:
                                  Make sense. My 280 uA is measured without any expansion board either.
                                    @tuftec we are aware the command sqnsupgrade.info() gives the information you need, and then coredumps (this also happened in r2, and sometimes in r1, especially on pybytes versions, ). Its not really 'mission critical' (there are other ways to get the information that do not coredump), but we will look at solving it, Thanks!
                                      bouchard.claude @Gijs
                                      @Gijs Thanks for the info. I wont worry about this then. would you be able to help us figuring out what is the deepsleep current we should be getting while powered by VIN with nothing plugged in? I'm not sure if I should contact pycom by email for this king of info?
                                      thanks
                                        That is definitely something I want to work on bringing together! A table of some sort with current specifications of what to expect in certain scenarios. For now, it can wildly vary with firmware versions (and LTE modem firmwares) as you probably followed above and in other threads as well. I cannot tell you when it will be finished, but when its done, it will be on the documentation!
                                          bouchard.claude
                                          Hi @Gijs , did you had time to work on this in the past weeks? This issue is preventing us from moving to preprod as we are draining the battery way too fast for the application. and it will be important for me to understand what to expect of the pycom platform.
                                            I did not get started on this (Im only on parttime and there's lots of 'higher priority' issues to solve first, its still on my list though!). What I can tell you, is that ~220uA for deepsleep is is quite high, we're expecting around ~40uA (my colleague @peterp did some work on the pysense / pytrack deepsleeping as well, to bring the current draw even further down, theres some additional info on that here: https://github.com/pycom/pycom-libraries/issues/132). It could potentially be related to the modem firmware and my colleague attached the beta firmware here for NB-IoT, or email me at support@pycom.io for the Cat-M1 firmware (it requires some additional updating instructions)
                                            On the Pysense / Pytrack there is an option to cut the power to the module, bringing the deepsleep current closer to 0 (we use a PIC on the pysense / pytrack that keeps track of the wakeup time and turns the power back on)
