GPY deepsleep High current
  • Hi,
    I'm having lot of issue putting my GPY in deepsleep mode.
    It's running on battery and using LTE CAT-M. I measure 0.7 to 0.8 mA in deepsleep mode . Is it normal? Anything i'm missing on the code part?
    ( I need to add timer making sure we are not stuck if network is not attaching, but it does not seem to be the thing draining the battery fast)
    from machine import Pin
    import utime
    import urequests
    from network import LTE
    def main():
        lte = LTE()
        lte.init()
        #Power the sensor
        pinPwr = Pin('P22', mode=Pin.OUT)
        pinPwr(True)
        lte.attach(band=XX, apn="XXXX")
        print("attaching..",end='')
        while not lte.isattached():
            time.sleep(0.25)
            print('.',end='')
            print(lte.send_at_cmd('AT!="fsm"'))         # get the System FSM
        print("attached!")
        lte.connect()
        print("connecting [##",end='')
        while not lte.isconnected():
            time.sleep(0.25)
            print('#',end='')
        print("] connected!")
        # initialize `P11` in gpio mode and make it an output to trigger sensor measure
        p_out = Pin('P11', mode=Pin.OUT)
        # initialize `P10` in gpio mode and make it an input to receive data from sensor
        p_in = Pin('P10', mode=Pin.IN)
        # Let the sensor settle for a while
        time.sleep(0.5)
        #set the gpio to high for 10 microsecond to indicate to the sensor we want a measurement
        p_out.value(1)
        time.sleep(0.00001) # wait 10 microseconds
        p_out.value(0)
        # Create variable start and give it current time
        start = utime.ticks_cpu()
        anti_stuck = utime.ticks_ms()
        # Refresh start value until the ECHO goes HIGH = until the wave is send by the sensor
        while ((p_in.value()==0) and (utime.ticks_diff(utime.ticks_ms(),anti_stuck) <= 5000)):
        # Assign the actual time to stop variable until the ECHO goes back from HIGH to LOW
        while ((p_in.value()==1) and (utime.ticks_diff(utime.ticks_ms(),anti_stuck) <= 5000)):
            stop = utime.ticks_cpu()
        # Calculate the time it took the wave to travel there and back
        measuredTime = (utime.ticks_diff(stop, start)) /1000000
        # Calculate the travel distance by multiplying the measured time by speed of sound
        distanceBothWays = measuredTime * 33112 # cm/s in 20 degrees Celsius
        # Divide the distance by 2 to get the actual distance from sensor to obstacle
        distance = distanceBothWays / 2
        # Print the distance
        print("Distance : {0:5.1f}cm".format(distance))
        data = '{\"distance\":' + str(distance) + '}'
        url = 'http://xxxxxxxxxxxxxx.com/telemetry'
        res = urequests.post(url, headers={"Content-Type": "application/json", "Accept": "application/json"}, data= data)
        res.close()
        time.sleep(2)
        lte.detach()
        lte.deinit(detach=False, reset=True)
        pinPwr(False)
        time.sleep(20)
        print("going to sleep now..")
        machine.deepsleep(21600000)
        # Run the main function when the script is executed
    if __name__ == "__main__":
        time.sleep(15)
        while(True):
            main()
  • Allow me to add some more comments. 220uA in deepsleep is too much, this is not expected. Outside of an Expansion board, just supplying vin and gnd, it should be 20-21 uA in deepsleep (with 3.75V supply). In an Expansion board 3.1 I see it as low as 57uA.
    Do you have jumpers (which) and/or SD card inserted? 57uA is without any.
  • I did not get started on this (Im only on parttime and there's lots of 'higher priority' issues to solve first, its still on my list though!). What I can tell you, is that ~220uA for deepsleep is is quite high, we're expecting around ~40uA (my colleague @peterp did some work on the pysense / pytrack deepsleeping as well, to bring the current draw even further down, theres some additional info on that here: https://github.com/pycom/pycom-libraries/issues/132). It could potentially be related to the modem firmware and my colleague attached the beta firmware here for NB-IoT, or email me at support@pycom.io for the Cat-M1 firmware (it requires some additional updating instructions)
    On the Pysense / Pytrack there is an option to cut the power to the module, bringing the deepsleep current closer to 0 (we use a PIC on the pysense / pytrack that keeps track of the wakeup time and turns the power back on)
  • Hi @Gijs , did you had time to work on this in the past weeks? This issue is preventing us from moving to preprod as we are draining the battery way too fast for the application. and it will be important for me to understand what to expect of the pycom platform.
  • That is definitely something I want to work on bringing together! A table of some sort with current specifications of what to expect in certain scenarios. For now, it can wildly vary with firmware versions (and LTE modem firmwares) as you probably followed above and in other threads as well. I cannot tell you when it will be finished, but when its done, it will be on the documentation!
  • @Gijs Thanks for the info. I wont worry about this then. would you be able to help us figuring out what is the deepsleep current we should be getting while powered by VIN with nothing plugged in? I'm not sure if I should contact pycom by email for this king of info?
    thanks
  • @tuftec we are aware the command sqnsupgrade.info() gives the information you need, and then coredumps (this also happened in r2, and sometimes in r1, especially on pybytes versions, ). Its not really 'mission critical' (there are other ways to get the information that do not coredump), but we will look at solving it, Thanks!
  • @kjm said in GPY deepsleep High current:
    @bouchard-claude My 40uA deepsleep is just the gpy, does not include any current drawn by an expansion board.
    Make sense. My 280 uA is measured without any expansion board either.
  • @bouchard-claude My 40uA deepsleep is just the gpy, does not include any current drawn by an expansion board.
  • @bouchard-claude Interesting.
    Just tried the sqnsupgrade.info() test with a FiPy on my breakout board (V3.1) and get exactly the same issue. It crashes after displaying the modem information. Something about a prohibited Store!!!!!
    >>> import sqnsupgrade
    2020/12/30 17:34:59: import sqnsupgrade
    >>> sqnsupgrade.info()
    2020/12/30 17:35:20: sqnsupgrade.info()
    <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
    >>> FiPy with firmware version 1.20.2.r3
    2020/12/30 17:35:29: Your modem is in application mode. Here is the current version:
    2020/12/30 17:35:31: UE6.0.0.0
    LR6.0.0.0-41019
    IMEI: 354346090972786
    Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
    Core 0 register dump:
    PC      : 0x4019072a  PS      : 0x00060830  A0      : 0x801901df  A1      : 0x3ffbaef0
    A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000005  A5      : 0xffffffff
    A6      : 0x00021266  A7      : 0x00060021  A8      : 0x8018fde0  A9      : 0x3ffbaeb0
    A10     : 0x0000002c  A11     : 0x00000000  A12     : 0x3ffb9f28  A13     : 0x00000000
    A14     : 0x3ffb9f38  A15     : 0x00000001  SAR     : 0x00000000  EXCCAUSE: 0x0000001d
    EXCVADDR: 0x0000002d  LBEG    : 0x4009412c  LEND    : 0x4009415a  LCOUNT  : 0xffffffff
    Backtrace: 0x4019072a:0x3ffbaef0 0x401901dc:0x3ffbaf10 0x40180044:0x3ffbaf30
    MDwAAAEAAAARAAAAbAEAAA==
    tJ/7PzCu+z/Er/s/
    0K37P2Cv+z/EEgIAjEP8P4xD/D+0n/s/hEP8PwcAAAAIn/s/CJ/7P7Sf+z8AAAAA
    EgAAAMih+z90aVQAZEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIAoGABIAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
    GIpAPwAAAABQUAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
    /////yoHGUAwCAYA3wEZgPCu+z8AAAAAAAAAAAUAAAD/////ZhICACEABgDg/RiA
    sK77PywAAAAAAAAAKJ/7PwAAAAA4n/s/AQAAAAAAAAAdAAAALQAAACxBCUBaQQlA
    /////yif+z8AAAAAyDMIQFyz9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAABcAGIAAr/s/aBX9PzCv+z9HABiAEK/7P9Cl/T8wr/s/
    AAAAADCv+z94ZxhAAAAAAAAAAAAwr/s/0KX9PwAAAADkHv0/5B79P+Ae/T/gHv0/
    AAAAAGCv+z8AAAAAAAAAAKCl/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    OE37P0BL+z8wTfs/
    QEv7P9BM+z+SEgIAnEL8P5xC/D84Tfs/lEL8PxMAAAC6nCwNw5N71ThN+z8AAAAA
    BgAAADQ9+z9Mb1JhAAYr8MybzgQ3L9MAAQAAADBN+z8AAAAAIAoGAAYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH2MGQ==
    LDQIQNJrCUAwAQYAaDIRgABM+z+SEgIAQN37P3wt+z8AAAAAAAAAAAAAAADSawmA
    4Ev7PwEAAACSEgIAOE37PwEAAAD+AAAAIAAGAAAAAADMUPU/AAAAAAAAAAAAAAAA
    AAAAACw2CEABAAAAJIAJQMxQ9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAKWlpaWlpaWlpaWlpaWlpaUAAAAAIEz7P9iZ/D9smvw/
    fC37PwAAAAAAAAAAAAAAAAAAAADQTPs/AAAAAAAAAADQTPs/AAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADMUPU/AAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQ8kM/AAAAAGya/D8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Ez7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    HLP7PxDM/T9wzf0/
    EMz9PxDN/T+SEgIAiEL8P4hC/D8cs/s/gEL8PxQAAAAAAAAAAAAAAByz+z8AAAAA
    BQAAAHS9/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAHDN/T8AAAAAIQAGAAUAAAAAAAAA
    LDQIQNJrCUAwAQYA3AIOgNDM/T+SEgIAQN37PwAAAAAA/wAAAAD/AAAAAP/SawmA
    sMz9PwEAAACSEgIAHLP7PwEAAAD+AAAAIAAAAAAAAAAAAAAAAAAAAB1KCUAzSglA
    +f///yw2CEABAAAAJIAJQAzR9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAByz+z8BAAAA/gAAACAAAAAAAAAA8Mz9PwAAAAAAAAAA
    AAAAAAD/AAAAAP8AAAAA/wAAAAAQzf0/AAAAAAAAAAAAAAAAAQAAAG5K/D8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHM39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    QLn7P6C3+z84ufs/
    oLf7P9C4+z+gPXvJvL77PyRC/D9Aufs/HEL8PxkAAABy4B5rJEUlk0C5+z8AAAAA
    AAAAADy1+z9JRExFMABZoLydZSS6sAUAAAAAADi5+z8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGBMtQ==
    LDQIQEIQIkAwCgYARnMXgGC4+z8AAAAAAAAAAAAAAACQePs/AwAAACMABgAQkvw/
    /////4RB/D8kQvw/I14JgJB4+z8DAAAAIwAGAAAAAABguPs/BEUPQAAAAAAAAAAA
    AAAAACw2CECQePs/JIAJQMy89T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACIbgmAgLj7PyAAAAABAAAA
    //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAAKxB/D8AAAAAbBT9PxBE/D8AAAAA
    AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    tL77PxC9+z+svvs/
    EL37P0C++z+B++S7JEL8P0i5+z+0vvs/HEL8PxkAAAB6smU13UbsQLS++z8AAAAA
    AAAAALC6+z9JRExFMQAjT19MxZ3cnXoAAQAAAKy++z8AAAAAIQAGAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAO3vPw==
    LDQIQEIQIkAwDwYARnMXgNC9+z8AAAAAIwAGAKwF/D+oBfw/AAAAACAABgD//z+z
    q6sAACS/+z+Uz/s/aOH7PwAAAAAgAgYAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
    AAAAACw2CEAAAAAAJIAJQDzC9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAsNghAbBT9PySACUCIbgmA8L37PyAAAAABAAAA
    //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAAKxB/D8gAAAAbBT9PxRE/D8AAAAA
    AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    dF77PxA9/T8cP/0/
    ED39P7A+/T+TEgIAEEL8PxBC/D90Xvs/CEL8PxMAAACgA5P7Bj1mz3Re+z8AAAAA
    BgAAACAx/T9TaWdmb3gAI3CY/uFAZHIAAAAAABw//T8AAAAAIQAGAAYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcDAA==
    LDQIQNJrCUAwDAYAAoQggNA9/T+TEgIAQN37P2hc+z8AAAAAAAAAAAAAAADSawmA
    sD39PwAAAACTEgIAdF77PwEAAAD+AAAAIwAGABEAAACsQvc/AAAAAKwyCUC3MglA
    /////yw2CEABAAAAJIAJQKxC9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA8D39P2Qv/T9gL/0/
    aFz7PwAAAAAAAAAAAAAAAAAAAACwPv0/AAAAAAAAAAAsNAhA6IMgQDAABQAAAAAA
    sD79PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    rEL3PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALw+/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
    IMv7P8DJ+z8Yy/s/
    wMn7P7DK+z8AAAAA/EH8P/xB/D8gy/s/9EH8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
    CgAAABzB+z9UbXIgU3ZjAPtyN2/k2mYAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH/K/w==
    LDQIQLl9CUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAgRPw/GET8PwEAAAC5fQmA
    YMr7PwAAAABA3fs/dEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAACw2CEAAAAAAJIAJQKzO9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAKzO9T8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
    AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    MHz7P7Cc+z84nvs/
    sJz7P9Cd+z8GtqDZtLH7P4zX+z8wfPs/mEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
    GAAAADya+z9pcGMxAOlHce47sQIDU/YAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGUKxw==
    LDQIQMRaCUAwAwYA3DEIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAADEWgmA
    UJ37PwEAAAD/////QN37PxBE/D/+AAAAIAMGABwAAAAAAD4AAAAAAKwyCUC3MglA
    /////yw2CEAQRPw/JIAJQMyh9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAoyCICQnfs/wKr9PwEAAAAAAAAAsJ37PyxB/D8kQfw/
    AAAAACcAAAAAAAAAIAMGAP////8AAAAALEH8PxhB/D8kfPs/AAAAANh7+z8BAAAA
    AAAAANCd+z8AAAAAAAAAAEwbF0DAqv0/AAAAAAAAAACkFAiAgH3+PwABAADoDQBA
    AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    rLH7P9C7/T9svf0/
    0Lv9PwC9/T+AuAAA3N79Pzh8+z+ssfs/mEH8PxQAAAAUOQhA0LH7P6yx+z8AAAAA
    BQAAAHCt/T9TbWFydENvbmZpZwBCAAAAAQAAAGy9/T8AAAAAIQAGAAUAAAAAAAAA
    2020/12/30 17:35:32: AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
    LDQIQPC/AEAwAAYA7GYJgJC8/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
    q6sAABDd+z8jAAYArLH7PwEAAAD+AAAAeAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAACw2CEABAAAAJIAJQPzA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAoLz9P0Dd+z8FAAAA
    hHEOgMC8/T8BAAAAFET8P6yx+z8BAAAA/gAAACADBgAAAAAA4Lz9PwAAAAAAAAAA
    EET8P0Dd+z+EQfw/iEL8PwAAAAAAvf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADL39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    1N79PzDd/T/M3v0/
    MN39P2De/T8Inbcg8OT9P7Sx+z/U3v0/mEH8PxQAAABJtporXy+TxdTe/T8AAAAA
    BQAAANDO/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAMze/T8AAAAAIQAGAAUAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAANny9A==
    LDQIQPC/AEAwAAYA7GYJgPDd/T8AAAAAIwAGACAABgDAqv0/VQAAANC8/T///z+z
    q6sAABDd+z8jAAYA1N79PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAACw2CEABAAAAJIAJQFzi9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAAN79P0Dd+z8GAAAA
    YmEOgCDe/T8BAAAAFET8P9Te/T8BAAAA/gAAALCd+z8AAAAAQN79PwAAAAAAAAAA
    EET8P0Dd+z+EQfw/iEL8PwAAAABg3v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbN79PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    6OT9P0Ai/j9YJP4/
    QCL+P/Aj/j+pchOmtFr7P9ze/T/o5P0/mEH8Pw4AAACkzf0/pM39P+jk/T+czf0/
    CwAAAFwE/j9JUlFzAI9f5PepypoivzEAAQAAAFgk/j8AAAAAIQAGAAsAAAAAAAAA
    AAAAAIwj/j8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApGujA==
    LDQIQMRaCUAwCgYAZEgPgAAj/j94zf0/oCP+P8TN/T8AAAAAzM39PwAAAADEWgmA
    4CL+PwEAAAD/////QN37PxBE/D/+AAAAAAAAAAAAAADsJ/g/AAAAAAAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQOwn+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAuAAAApaWlpaWlpaVgCg6AQCP+P5iS/D+gI/4/
    AAAAACEBAAClpaWlpaWlpf////9AI/4/xJX8P6Aj/j8AAAAAAQAAAABk+z/8////
    AAAAANAj/j+Mkvw/AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAjJL8PwAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgI/4/
    ABwAAGiU/D9olPw/AAAAAOwn+D8AAAAAAAAAAAAAAABolPw/CgAAAIRB/D8AQ/w/
    AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAD8I/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAA=
    rFr7PxBZ+z+kWvs/
    EFn7P0Ba+z/5qHhThHL7P/Dk/T+sWvs/mEH8PxEAAABUPPs/VDz7P6xa+z9MPPs/
    CAAAAKhO+z9Mb1JhX1RpbWVyX2NhbGwAAQAAAKRa+z8AAAAAIQAGAAgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKljAg==
    LDQIQMRaCUAwAAYAbB0RgNBZ+z8oPPs/EFr7P3Q8+z8AAAAAfDz7PwAAAADEWgmA
    sFn7PwEAAAD/////QN37PxBE/D/+AAAAIwAGAAAAAAAQWvs/AAAAAAAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQDxe9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAsNghABwAAACSACUAAAAAAEFr7P5Sb/D8AAAAA
    AAAAACEBAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAA8XvU/AAAAAAAAAAAAAAAA
    AAAAAEBa+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATFr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    fHL7P+Bw+z90cvs/
    4HD7PxBy+z92J2sRcHr7P7Ra+z98cvs/mEH8PwMAAABAQPw/QED8P3xy+z84QPw/
    FgAAAHhm+z9lc3BfdGltZXIALtTkX3IAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACbvIw==
    LDQIQMRaCUAwDAYA9SMNgKBx+z8UQPw/AAAAAGBA/D8AAAAAFED8PwAAAADEWgmA
    gHH7PwAAAAD/////QN37PxBE/D/+AAAAIAAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQAx29T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4HH7P2hA/D9wQPw/
    AAAAACyJAQAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAMdvU/AAAAAAAAAAAAAAAA
    AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHBA/D8PAAAG
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    aHr7P+B4+z9gevs/
    4Hj7PwB6+z+rUUObMEf9P4Ry+z9oevs/mEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
    GAAAAGR2+z9pcGMwAFD6cyC5jEFHYuUAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMVNbg==
    LDQIQMRaCUAwDAYA3DEIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAADEWgmA
    gHn7PwAAAAD/////QN37PxBE/D/+AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQPx99T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PyhB/D8AAAAA
    AAAAAJmbAQD+AAAAAQAAAP////8AAAAAKEH8PxhB/D8Advs/AAAAAAEAAAAAAAAA
    AAAAAAB6+z8AAAAAAAAAACR8CEAAAAAAAAAAAAAAAAAZFAiAIDz+P4BB/D8PbEA/
    AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    KEf9P5BF/T8gR/0/
    kEX9P8BG/T94HRg79EX8P3B6+z8oR/0/mEH8Pw0AAABg/f0/YP39PyhH/T9Y/f0/
    DAAAACQ//T9MVEVfVUFSVF9FVlQAgmcAAQAAACBH/T8AAAAAIQAGAAwAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALeEw==
    LDQIQMRaCUAwAAYAZkMRgFBG/T80/f0/kEb9P4D9/T8AAAAAiP39PwAAAADEWgmA
    MEb9PwEAAAD/////QN37PxBE/D/+AAAAXAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQLxK9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEb9P6Sb/D8AAAAA
    AAAAAJESAgAAAAAAAAAAAP////8AAAAAAAAAAAAAAAC8Svc/AAAAAAAAAAAAAAAA
    AAAAAMBG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzEb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    7EX8P4Ck/T9orf0/
    gKT9PwCt/T+REgIAoEH8PzBH/T/sRfw/mEH8Pw4AAADI//0/yP/9P+xF/D/A//0/
    CwAAAGx9/T9NaWNyb1B5AAAAAAAAAAAAAQAAAGit/T8AAAAAIQAGAAsAAAABAAAA
    lH/7PxSU/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
    LDQIQMRaCUAwCAYAAP0YgECl/T+c//0/AAAAAOj//T8AAAAAnP/9PwAAAADEWgmA
    IKX9PwEAAAD/////QN37PxBE/D/+AAAA0KT9Pw4AAAD4vgCAAKX9PyxBCUBaQQlA
    /////yw2CEAQRPw/JIAJQPyw9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAP0BGIBwpf0/aBX9P6Cl/T8EAhiAgKX9P+QAvD8AAAAA
    AAAAAJISAgD+AAAA0KT9P/////8AAAAAIAAAAAAAAACUAhmAoKX9P9QBGUDQpf0/
    lAIZgKCl/T/UARlA0KX9P5ISAgABAAAA/gAAABT8RT+wQBGA0KX9PwAAAAAAAAAA
    AQAAANQBGUDQpf0/5AC8P2gV/T8BAAAACwAAAAEAAAAlSBGAEKb9PwAAAAABAAAA
    /SAQgAAAAAAASBFAAAAAAAEAAAAApv0/4AJEP8QEAAAoR/0/AAAAAAwAAAAACAAA
    /SAQgDCm/T8cSBFAAAAAAAAIAAAAAAAAEQIAALoFAAA85Q+AUKb9P7wERD8AAAAA
    AAAAAAEAAAAKAAAA0Kf9P6b0D4Bwpv0/vAREPwAAAAAAAAAArKf9Pyim/T8SEwAA
    POUPgJCm/T+wDJU/AAAAAAAAAACsp/0/AAAAAJYQAADM5Q+AsKb9P7AMlT8AAAAA
    AAAAAKyn/T+gzEA/BLZAP4alEIDQpv0/AAAAAAAAAAAAAAAArKf9PwIAAAAyCQAA
    KyIQgPCm/T8EAAAAPslCP6Sn/T+op/0/GKf9P4Cn/T885Q+AkKf9P0D1lD9A9ZQ/
    EKj9PwAAAAArIhCA8Kb9PwgAAACwp/0/rKf9P6Sn/T8AAAAAAwAAAEA8QD9Eg0I/
    EKj9P2Cn/T885Q+AkKf9P0D1lD9A9ZQ/0pcQgAAAAAAHAAAApKf9PwAAAAADAAAA
    AAAAAJCn/T+wp/0/rKf9PygLlT/HhEI/ooRCPyALlT+kp/0/MP///z/JQj+kp/0/
    +KQQgPCn/T+Q+pQ/AAAAAJD6lD89yUI/oKf9P6Sn/T9A9ZQ/sAyVPwAAAAASEwAA
    AAAAACw2CEAoC5U/JIAJQAAAAAAAAAAAAAAAAAAAAACQp/0/KAuVPwAAAADAp/0/
    KyIQgBCo/T8AAAAA1oRCPwAAAAAoC5U/AAAAAAEAAAA85Q+AsKj9P0D1lD9olPw/
    IKn9P0Co/T8rIhCAEKj9PwgAAABUC5U/UAuVP0gLlT8DAAAADAAAAAjPQD8Wz0A/
    FJT8P+D0lD885Q+AsKj9P0D1lD9olPw/0pcQgAjPQD8IAAAASAuVPwAAAAAJAAAA
    AAAAABALlT9UC5U/UAuVP+Cp/T8UlPw/BwAAAALRdgEkC5U/MP///9eEQj8AAAAA
    zOUPgOCo/T9QCpU/AAAAAAAAAAAAAAAAAAAAAE40CEAQC5U/4Kn9PzAAAACwqP0/
    hqUQgACp/T8AAAAAAAAAAAAAAADgqf0/JHD0PwAAAAArIhCAIKn9PwQAAAC4C5U/
    2Kn9P7Cp/T9Iqf0/sKn9PzzlD4DAqf0/aJT8P2iU/D9gqv0/YKn9PysiEIAgqf0/
    CAAAAOCp/T/cqf0/1Kn9PwAAAAADAAAAAQAAAPTQQD8AAAAAAAAAADzlD4DAqf0/
    aJT8P2iU/D/SlxCAIAAAAAgAAADUqf0/AAAAAAMAAAAAAAAAwKn9P+Cp/T/cqf0/
    AAAAAJSp/T8BAAAAAwAAANip/T8w////uQuVPwMAAABp5Q+AIKr9PzADlT8AAAAA
    MAOVP7cLlT/Qqf0/1Kn9P2iU/D+8B0E/UAqVPwAAAACRQAiAEKr9PzCq/T8AAAAA
    AAAAAAAAAAAQC5U/AAAAAMCp/T8AAAAAAAAAAPCp/T94Fg6AQKr9PzADlT8AAAAA
    AAAAAAAAAAAFAAAAAAAAAAMZDoBgqv0/MAOVPxYAAAAAAAAAAAAAAAAAAABIC5U/
    vAEOgACr/T8FGUA/AAAAAAAAAACQqv0/AxkOgGCq/T8QT/w/AAAAABYAAABcAAAA
    IgAAAAgAAAANAAAA8E78Pw0AAAAAAAAAvAEOgACr/T8FGUA/AAAAAPQVDoBwDpU/
    MA6VP+Cq/T8Aq/0/yRhAPwAAAADwTvw/EgAAAGD1lD8WAAAAAKv9PyvpAQAAAAAA
    FgAAAFwAAAAiAAAACAAAAAAAAABAq/0/RPj7P2is/T8gAAAAEgAAANDslD9orP0/
    mM9DP0Cr/T+wR/w/aKz9P1Cr/T/gqv0/7Ef8PwAQAAAAAAAAAK39PwAAAAAAAAAA
    AQAAAKWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
    paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
    paWlpaWlpaWlpaWlpaWlpSw0CEAc/Q1AMAAFAAAAAAAArf0/AAAAAAAAAAAAAAAA
    AAAAAAEAAAAAAAAAgB0dAAEAAAD/////////////////////mqwqNAAAAAAAAAAA
    AAAAAADwHwBAq/0/AAAAAAAAKAAAAAAAAAAAAAAAAAABAAAAAAAAAAEAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAADK39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
    hNf7P1B7/T8Eff0/
    UHv9P6B8/T+HyTvSOHz7P6BB/D+E1/s/mEH8PwUAAABY0fs/WNH7P4TX+z9Q0fs/
    FAAAAAhx/T9ldmVudFRhc2sAF+s7N9gAAAAAAAR9/T8AAAAAIQAGABQAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABbWIg==
    LDQIQMRaCUAwAAYAfHQXgBB8/T8s0fs/UHz9P3jR+z8AAAAAgNH7PwAAAADEWgmA
    8Hv9PwAAAAD/////QN37PxBE/D/+AAAAKNH7PwAAAAClpaWlpaWlpQAAAAAAAAAA
    AAAAACw2CEAQRPw/JIAJQJyA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
    AAAAAAAAAAAAAAAAAAAAAKB8/T8AAAAAAAAAAAAAAAAAAAAAUHz9P7wU/T8AAAAA
    AAAAAAAAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAKB8/T8AAAAAAAAAAJyA9z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAAAAAACsfP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    AAAAAA==
    Rebooting...
    ets Jun  8 2016 00:22:57
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2128
    load:0x4009fa00,len:19760
    entry 0x400a05bc
    2020/12/30 17:35:37: SYSTEM RESTART?```
    Maybe @gijs can help here.
    I have not seen this previously.
    Maybe something to do with firmware V 1.20.2.r3 ????
  • @tuftec Exactly what I do too ;) I have a shut switch that i open once the device is deepsleeping only. ( my test that make it crash is using the USB connection and the breakout board to a computer, no current measurement taken during this test.)
  • @bouchard-claude Are you getting the crash with your current measuring device in circuit? Previously when I was doing low current measurements, on devices that were capable of considerably higher current draw, I would wire a shut switch across my meter so that I could bypass it when I needed full current. Usually a device capable of measuring ultra low currents is not capable of handling the full power requirements of the device.
    Typically I would start the system with the shut switch closed, then place the device into its low power state and open the switch just to take the low current measuement. This avoids any issues with large voltage drops across you meter when the current ramps up.
  • Yeah, but all the test im running now are with no code , Only the deepsleep and the stuff we are trying ( no lte on boot, no wifi on boot, lte deinit() ...) and it has the exact same current draw then with my complete code during deepsleep.
    A weird things I just found is every time I run this to check my firmware version:
    import sqnsupgrade
    sqnsupgrade.info()
    it give me the info, then immetiatly crash, core dump and restart . So maybe something is up with the whay the firmware deal with the modem? Ill try and switch versions to see if it help.. And also will try on a different GPy ( and a fipy) when ill have some time
  • @bouchard-claude You could try wading through all the release logs looking for changes, but I have not found a lot of joy in that previously. Maybe you need to test the old 1.20.1r1 release on you Gpy. Hopefully that will provide some insight.
    I would also do the wlan init/deinit thing early in your code just to be sure it is off. Also disable the server in the same way. server.deinit() after you have defined it. The server interacts with the wlan. I am not sure if it enables it without you knowing. Worth a try anyway.
  • yes, exactly what i'm doing too. This project only required LTE, so im only powering one the LTE radio, and only during time for transmission and deinit it after. As for the Wifi, I did set the power_on_boot to off as a first setup thing once I pushed the initial code.
    So I just did the test with the lte_on_boot and wifi_on_boot ( I set them manualy + put them in a empty main.py code with only thoses and a deepsleep command) and the current stayed a 266 uA all the time in the deepsleep. So even with the radio not on at boot the currect of the board is high
    I'm using GPy with firmware version 1.20.2.r3 . Any way to see what changed between version?
  • @bouchard-claude Yes, I understand you need LTE but do you use wifi (wlan).
    In my application I use wlan, lora, sigfox & nb-iot. I make decisions at various stages in my code to enable/disable the relevant radio system that I need.
    The wifi is typically on when the system boots so that you can set up a REPL connection over wifi. I deliberately turn it off and disable the REPL server at and early stage when I determine that I do not need it. turn it on only as a system configuration aide in the field. Otherwise, I need it to be off for security. You might need to explore turning off all the bits you do not need.
  • @tuftec Yeah, my understaning too is that thoses flag are to be set once, cause once the main.py is loaded, its way too late. But I did try and set the wifi on boot to 0 using the shell over serial, and I did re-test with no difference. As for the LTE on boot, well, I really need to use it during operation ( data is sent overs CAT-1 LTE). I can try and test it tomorow, but that wont solve my problem :S ( but maybe it would point to a direction)
  • @kjm Sure just setting those boot flags once the program has started is too late. They will alter the next boot behaviour but not this one???????
    From what I have read a lte.init(); lte.deinit() cycle should power the modem down.
    Maybe the issue is actually the wlan. In my setup the wlan is on by default at boot and I specifically disable it with wlan.deinit() when I no longer need it, based on the status of a switch.
  • @bouchard-claude Try
    import pycom; pycom.lte_modem_en_on_boot(0); pycom.wifi_on_boot(0)
    at the start of your program to be sure both radios are off to begin with. My gpy (1.20.1.r1) deepsleeps at 40uA
  • @bouchard-claude
    @Gijs can you help with this one. Maybe you could supply some clarity on the expected low power performance when using LTE.
    Peter.
7 out of 28
