    Pycom FiPy ADR not working on AS923 (TTN and Chirpstack)
    38 Posts 3 Posters 713 Views 4 Watching
      Thanks for the great explanation. On Monday, I'll look at this again and might test it with a Chirpstack environment as well. I was not aware of the dwelltime workings.
      I took my data from table 68 and 69 there from the same paper and the sourcecode, but I might have missed the dwelltime factor.
      RegionAS923AdrNext function which constantly returns datarate = 2
      This is what I got as well, though I never received any updates from TTN. On 868, this function did return different parameters when we received the LinkAdrReq.
      What I can also do for you, is straight up copy the ADR code from EU868 over to AS923 (as it should work the same right?) and change the limits to reflect the correct limits in AS923. It could be possible we're both missing a typo. Next to that, I can compile in additional debug statements so you can test this along with me, lets get to the bottom of this
        bcwong71 @Gijs
        @Gijs
        Many thanks in advance for the effort you are about to take. Great to know that we are looking at the same picture over this matter. Yes, the ADR code for both EU868 and AS923 should be exactly similar apart from the regional data rate limit and the dwell times. Shall wait for your update.
        Words cannot express how much I appreciate your help. Thanks.
          No worries! I have compiled the firmware for you here. It provides additional debug statements about the whole TX/RX and ADR process. You can upload the firmware in the pycom firmware updater tool, by selecting a file
          Let me know what you get!
          Note that I still was not able to get it working on A923 in TTN, but the platform gives me limited feedback about the ADR settings, on 868, it did work..
            bcwong71 @Gijs
            @Gijs
            Hi Gijs. Thank you so much. I will try it now. By the way, do you have advice on why the the spreading factor was constant at 10 even when I have manually set the spreading factor to another value and have the adr turned off when on AS923?
            Thanks.
            Wong
              If you set the spreading factor in lora.join(), it only holds for the join requests. The datarate set in the s.setsockopt(socket.SOL_LORA, socket.SO_DR, 2 ) should hold though, if adr is disabled, but here DR2 = SF10BW125, you should be able to see that in the debug prints on the firmware I attached above.
              Edit: It worked for me this time!
              datarate out 2, txpowout 0
              [modlora] TASK_LoRa: taking semaphore 1
              [LoRaMac] PrepareFrame: adrNext[LoRaMac] ScheduleTx: next channel 6, RX channel DR: 2
              [RegionAS923] RegionAS923ComputeRxWindowParameters: datarate 2
              [LoRaMac] SendFrameOnChannel: channel 6
              [LoRaMac] SendFrameOnChannel: uplink frequency 923000000
              [RegionAS923] RegionAS923RxConfig: RX config channel 6, frequency 923000000, datarate 2
              [RegionAS923] RegionAS923RxConfig: RX config channel 6, frequency 923200000, datarate 2
              [RegionAS923] LinkAdrReq: status variables drOut: 5, txPowOut:0, nbRepOut 1, nbBytesParsed:5 <-- see this line!
              [modlora] McpsConfirm: Giving semaphore 4
              b''
              datarate out 5, txpowout 0
              [LoRaMac] PrepareFrame: adrNext[LoRaMac] ScheduleTx: next channel 5, RX channel DR: 5
              [RegionAS923] RegionAS923ComputeRxWindowParameters: datarate 5
              [LoRaMac] SendFrameOnChannel: channel 5
              [LoRaMac] SendFrameOnChannel: uplink frequency 922800000
              [RegionAS923] RegionAS923RxConfig: RX config channel 5, frequency 922800000, datarate 5
              [RegionAS923] RegionAS923RxConfig: RX config channel 5, frequency 923200000, datarate 2
              b''
                bcwong71 @Gijs
                @Gijs
                How about if I set the spreading factor directly at lora.init() ? That should be an absolute hold right?
                  The spreading factor in lora.init() is only meant for the RAW lora connection, as the LoRaMAC uses the Datarate parameter in the socket to determine the spreading factor and bandwidth combination
                    bcwong71 @Gijs
                    @Gijs
                    Hi Gijs, I flashed my FiPy with the firmware you provided and tried AS923 on TTN. See the debug prints below:
                    [modlora] lora_init_helper: Giving semaphore 3
                    [LoRaMac] adr set enable: 1
                    [LoRaMac] PrepareFrame: adrNext[LoRaMac] ScheduleTx: next channel 0, RX channel DR: 2
                    [LoRaMac] SendFrameOnChannel: channel 0
                    [LoRaMac] SendFrameOnChannel: uplink frequency 923200000
                    [RegionAS923] RegionAS923RxConfig: RX config channel 0, frequency 923200000, datarate 2
                    [LoRaMac] PrepareFrame: adrNext[LoRaMac] ScheduleTx: next channel 1, RX channel DR: 2
                    [LoRaMac] SendFrameOnChannel: channel 1
                    [LoRaMac] SendFrameOnChannel: uplink frequency 923400000
                    [RegionAS923] RegionAS923RxConfig: RX config channel 1, frequency 923400000, datarate 2
                    [RegionAS923] RegionAS923RxConfig: RX config channel 1, frequency 923200000, datarate 2
                    I could not find any prints showing LinkAdrReq. Could it be a problem with the configurations on my TTN account?
                    Can you please check if my micropython source code is fine?
                    lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AS923, adr=True  )
                    dev_addr = struct.unpack(">l", ubinascii.unhexlify(""))[0];
                    nwk_swkey = ubinascii.unhexlify("");
                    app_swkey = ubinascii.unhexlify("");
                    lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey), dr=2)
                    s = socket.socket(socket.AF_LORA, socket.SOCK_RAW);
                    s.setsockopt(socket.SOL_LORA, socket.SO_DR, 6 )
                    #s.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, True);
                    while( True ):
                        try:
                            # make the socket blocking
                            s.setblocking(True)
                            # send some data
                            s.send(bytes([0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 ]))
                            s.setblocking(False)
                            data = s.recv(512)
                            pycom.rgbled(0x00FF00)
                            time.sleep(1)
                            pycom.rgbled(0x000000)  # Green
                            time.sleep(29)
                        except Exception as e:
                            print( e )
                    Thanks.
                    Wong
                      For me it took a while (like 100 packets while). Im using this script to test the setup on TTN, AS923: (very similar to yours)
                      from network import LoRa
                      import ubinascii
                      # Initialise LoRa in LORAWAN mode.
                      # Please pick the region that matches where you are using the device:
                      # Asia = LoRa.AS923
                      # Australia = LoRa.AU915
                      # Europe = LoRa.EU868
                      # United States = LoRa.US915
                      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AS923, adr=True)
                      # create an OTAA authentication parameters, change them to the provided credentials
                      app_eui = ubinascii.unhexlify('')
                      app_key = ubinascii.unhexlify('')
                      #uncomment to use LoRaWAN application provided dev_eui
                      dev_eui = ubinascii.unhexlify('')
                      # join a network using OTAA (Over the Air Activation)
                      #uncomment below to use LoRaWAN application provided dev_eui
                      #lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0)
                      while not lora.has_joined():
                          time.sleep(2.5)
                          print('Not yet joined...')
                      print('Joined')
                      # create a LoRa socket
                      # set the LoRaWAN data rate
                          # send some data
                          data = s.recv(64)
                          print(data)
                          time.sleep(5)
                        bcwong71 @Gijs
                        Alright. Give me some time to work out the possible difference. The only obvious difference I can see now is the different activation modes. Mine is ABP and yours is OTAA. I will come back to you with more information.
                          Some more data points for you
                          This is the view from TTN node when we receive a ADR REQ
                          Screenshot 2021-02-15 at 15.40.10.png . There is no metadata in the packet visible.
                          This is the view from TTN Gateway, when we send a ADR REQ:
                          And this is the content of the packet: (not sure if that means anything to you)
                          60EA680126A5000003507F000136141F26
                          It seems like this happens every 65 packets on my side now, I just got another one at 129. I have the gateway setup to ttn-router-jp on AS923-1
                          Another edit, I just used the regular firmware, and can agree that I do not get a downlink message listed anywhere to change the datarate in AS923. It does however work for EU868 at 65 packet-intervals, both again on TTN.
                          B 2 Replies Last reply Reply Quote 1
                            bcwong71 @Gijs
                            @Gijs
                            Hi, good news on my side as well. Using exactly your sample source employing either Activation via OTAA or ABP on Fipy flashed with the firmware your provided, I have successfully got ADR to work on both TTN and Chirpstack Server. On TTN server, the LinkAdrReq was transmitted by the gateway after every 65 packets (Exactly as what you shared). On Chirpstack server, the LinkAdrReq was transmitted by the gateway after every packet it had received. I would say that we have successfully solved the problem I was facing. However, can you please highlight again the changes that you have made to the source code of the firmware? Maybe these changes can be introduced in the next firmware version. Thank you very much and I appreciate your help greatly.
                              bcwong71 @Gijs
                              @Gijs
                              Hi Gijs, I have been evaluating the ADR performance on the Chirpstack server. I found that the lorawan stack failed to change the data rate even when adr request was transmitted by the gateway. See the debug prints below. I have this feeling that there is still some kind of error somewhere. What is your advice?
                              Joined
                              b''
                              [RegionAS923] LinkAdrReq: status variables drOut: 5, txPowOut:1, nbRepOut 1, nbBytesParsed:5
                              Trying to send uplink
                              b''
                              [RegionAS923] RegionAS923ComputeRxWindowParameters: datarate 0
                              [RegionAS923] LinkAdrReq: status variables drOut: 5, txPowOut:2, nbRepOut 1, nbBytesParsed:5
                              b''
                              [modlora] McpsConfirm: Giving semaphore 4```
                              No issue on TTN so far.
                                I would love to help you out there, but I do not really have a clue there unfortunately..
                                Maybe somebody else on the forum has a better idea on what is happening here, or you could try the Chirpstack forum (I believe you mention its Chirpstack related?)
                                  bcwong71 @Gijs
                                  @Gijs
                                  Hi Gijs, Thanks for your reply. My concern was why: the next datarate out debug print still showing 2 even when the LinkAdrReq was clearly requesting for data rate = 5. Thanks
                                    Do you notice any other differences in that line between TTN and Chirpstack?
                                    Comparing to mine:
                                    [RegionAS923] LinkAdrReq: status variables drOut: 5, txPowOut:2, nbRepOut 1, nbBytesParsed:5 <-- yours (Chirpstack?)
                                    [RegionAS923] LinkAdrReq: status variables drOut: 5, txPowOut:0, nbRepOut 1, nbBytesParsed:5 <-- mine (TTN)
                                    It could be the txPowOut set by Chirpstack is outside the bounds, its a stretch though..
                                    B 2 Replies Last reply Reply Quote 0
                                      bcwong71 @Gijs
                                      @Gijs
                                      In the source code, max_tx power out for AS923 is 0 and the min_tx power out is 7. So, they are within the bounds. If you dont mind, can you pinpoint to me the location where the source code interprets the linkadrreq? I believe that would be RegionAS923AdrNext. The reason why the next transmission defaulted to dr= 2 and tx=0 was because of the output of the ReguonAS923AdrNext function right?
                                        bcwong71 @Gijs
                                        @Gijs
                                        Chirpstack Debugging
                                        Hi Gijs, I think I have identified the lines in the function RegionAS923ADNext that have been invoked resulting in the data rate being defaulted to 2 and the Tx power being set to MAX. Can you please add a debug print to track the value of AdrNext->AdrAckCounter?
                                        Thanks.
                                        Wong
                                          Sorry for my late reply,
                                          I'll add some additional debug statements, and I'll share the code I changed:
                                          bool RegionAS923AdrNext( AdrNextParams_t* adrNext, int8_t* drOut, int8_t* txPowOut, uint32_t* adrAckCounter )
                                              bool adrAckReq = false;
                                              int8_t datarate = adrNext->Datarate;
                                              int8_t txPower = adrNext->TxPower;
                                              GetPhyParams_t getPhy;
                                              PhyParam_t phyParam;
                                              // Report back the adr ack counter
                                              *adrAckCounter = adrNext->AdrAckCounter;
                                              printf("[RegionAS923] AdrNext: AdrAckCounter %d, AdrEnabled: %d, old datarate %d\n", adrNext->AdrAckCounter,adrNext->AdrEnabled, datarate);
                                              if( adrNext->AdrEnabled == true )
                                                  if( datarate == AS923_TX_MIN_DATARATE )
                                                      *adrAckCounter = 0;
                                                      adrAckReq = false;
                                                  else
                                                      if( adrNext->AdrAckCounter >= AS923_ADR_ACK_LIMIT ) // ACK_LIMIT = 64
                                                          adrAckReq = true;
                                                          txPower = AS923_MAX_TX_POWER;
                                                      else
                                                          adrAckReq = false;
                                                      if( adrNext->AdrAckCounter >= ( AS923_ADR_ACK_LIMIT + AS923_ADR_ACK_DELAY ) )
                                                          if( ( adrNext->AdrAckCounter % AS923_ADR_ACK_DELAY ) == 1 )
                                                              // Decrease the datarate
                                                              getPhy.Attribute = PHY_NEXT_LOWER_TX_DR;
                                                              getPhy.Datarate = datarate;
                                                              getPhy.UplinkDwellTime = adrNext->UplinkDwellTime;
                                                              phyParam = RegionAS923GetPhyParam( &getPhy );
                                                              datarate = phyParam.Value;
        // We must set adrAckReq to false as soon as we reach the lowest datarate
        adrAckReq = false;
        if( adrNext->UpdateChanMask == true )
        // Re-enable default channels
        ChannelsMask[0] |= LC( 1 ) + LC( 2 ) + LC( 3 ); //this line seems to be different!
                                              printf("datarate out %d, txpowout %d\n", datarate, txPower);
                                              *drOut = datarate;
                                              *txPowOut = txPower;
                                              return adrAckReq;
                                          On my side, the AdrAckCounter increases to 64 (as specified by the AS923_ADR_ACK_LIMIT) and then does the AdrReq function. AS923_ADR_ACK_DELAY is 32.
                                          I have attached the firmware with even more debug statements here
                                          B 1 Reply Last reply Reply Quote 3
                                            bcwong71 @Gijs
                                            @Gijs
                                            Thanks for your reply Gijs. Your addition of the debug prints helps me understand the flow better.
                                            Okay, as you have pointed out earlier, the difference between the linkadrreq from TTN and Chirpstack is the Tx Power. On TTN, it was 0 and the on Chirpstack it was 2. Now I suspect the culprit is in function: RegionAS923LinkAdrReq
                                            line:
                                            status = RegionCommonLinkAdrReqVerifyParams( &linkAdrVerifyParams, &linkAdrParams.Datarate, &linkAdrParams.TxPower, &linkAdrParams.NbRep );
                                            I need an additional debug print to find out if the status is true or false. I have a feeling that the status is false on Chirpstack, therefore, the data rate of the next frame did not change.
                                            Can you also show me the location of the function RegionCommonLinkAdrReqVerifyParams which I believe in the underlying reason why ADR breaks on chirpstack. Best if you can pinpoint to me the exact piece of code that rejects Tx Power = 2.
                                            P/S: My deployment in Singapore is now going smoothly with TTN, thanks to your help. However, I would also like for adr to work on Chirpstack for research purpose.
                                            Thanks.
                                            Wong
