    LTE firmware update stuck at resetting
    9 Posts 3 Posters 216 Views 4 Watching
    • N Offline
      Nicolas Vandamme
      During an upgrade of the LTE firmware via USB to CAT-M1 5.2-48829, the upgrade process stopped at resetting with an sqnsupgrage Timeout Error :
      >>> sqnsupgrade.run('COM5','./CATM1-48829/CATM1-5.2-48829-1.dup',load_fff=False)
      <<< Welcome to the SQN3330 firmware updater [1.2.7] >>>
      Attempting AT wakeup...
      Sending 416448 bytes: [########################################] 100%
      Waiting for modem to finish the update...
      <<<=== DO NOT DISCONNECT POWER ===>>>
      Resetting.......................................................................................................................................................................................................................................................................Traceback (most recent call last):
        File ".\tools\lte_fw_updater\sqnsupgrade.py", line 1076, in run
          sqnup.upgrade_ext(port=port, ffile=ffile, mfile=mfile, resume=resume, debug=debug, pkgdebug=False, verbose=verbose, load_fff=load_fff, force_fff=force_fff)
        File ".\tools\lte_fw_updater\sqnsupgrade.py", line 948, in upgrade_ext
          if self.__run(file_path=ffile, resume=True if mfile is not None else resume, direct=False, port=port, debug=debug, pkgdebug=pkgdebug, verbose=verbose, load_fff=load_fff, fc=fc, force_fff=force_fff):
        File "H:\Workspace\Tech4Gaia\noehmi-embedded-node\esp32-arduino-tasks-events\tools\lte_fw_updater\sqnsupgrade.py", line 719, in __run
          self.wait_for_modem(send=False, echo_char='.', expected=b'+SYSSTART')
        File "H:\Workspace\Tech4Gaia\noehmi-embedded-node\esp32-arduino-tasks-events\tools\lte_fw_updater\sqnsupgrade.py", line 150, in wait_for_modem
          raise OSError('Timeout waiting for modem to respond!')
      OSError: Timeout waiting for modem to respond!
      After that i tried to power cycle and restart the upgrade process to no avail as the modem appears to be stuck (bricked ?) :
      >>> sqnsupgrade.reconnect_uart()
      Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
      Core 0 register dump:
      PC      : 0x4019077e  PS      : 0x00060830  A0      : 0x80190233  A1      : 0x3ffbaef0
      A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000005  A5      : 0x3ffc4410
      A6      : 0x3ffc421c  A7      : 0x3ffbb19c  A8      : 0x8009702d  A9      : 0x3ffbeb00
      A10     : 0x3ffbdd40  A11     : 0x00000001  A12     : 0x00000012  A13     : 0x00000001
      A14     : 0x000000fe  A15     : 0x00000001  SAR     : 0x00000000  EXCCAUSE: 0x0000001d
      EXCVADDR: 0x0000002d  LBEG    : 0x4009412c  LEND    : 0x4009415a  LCOUNT  : 0xffffffff
      Backtrace: 0x4019077e:0x3ffbaef0 0x40190230:0x3ffbaf10 0x40180098:0x3ffbaf30
      WDsAAAEAAAARAAAAbAEAAA==
      QJ77PzCu+z/Er/s/
      cK77P2Cv+z+c6wAAjEP8P4xD/D9Anvs/hEP8PwcAAABA0Ps/QND7P0Ce+z8AAAAA
      EgAAAMih+z90aVQApaWlpaWlpaWlpaUAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      YIpAPwAAAABQUAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
      /////34HGUAwCAYAMwIZgPCu+z8AAAAAAAAAAAUAAAAQRPw/HEL8P5yx+z8tcAmA
      AOv7P0Dd+z8BAAAAEgAAAAEAAAD+AAAAAQAAAAAAAAAdAAAALQAAACxBCUBaQQlA
      /////xIAAAABAAAAyDMIQOyy9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP////8sNghA5B79PySACUCbABiAEK/7P2Cm/T8wr/s/
      //8/swAAAAAAAAAAAAAAAAAAAAAwr/s/YKb9PwAAAADkHv0/5B79P+Ae/T/gHv0/
      AAAAAGCv+z8AAAAAAAAAADCm/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAA=
      lLH7P7DL/T8Qzf0/
      sMv9P7DM/T9u6wAAiEL8P4hC/D+Usfs/gEL8PxQAAAAAAAAACAAAAJSx+z8AAAAA
      BQAAABS9/T9TZXJ2ZXJzAIua+uNTRlgAAQAAABDN/T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
      LDQIQNJrCUAwBwYA5AIOgHDM/T9u6wAAQN37PwAAAAAA/wAAAAD/AAAAAP/SawmA
      UMz9PwEAAABu6wAAlLH7PwEAAAD+AAAAIAAAAAAAAAA80Pc/AAAAAB1KCUAzSglA
      +f///yw2CEABAAAAJIAJQDzQ9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAACMABgAA9fs/IAAAACAAAAAAAAAAkMz9PwAAAAABAAAA
      AAAAAAD/AAAAAP8AAAAA/wAAAACwzP0/AAAAAAAAAAAAAAAAAQAAAG5K/D8AAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAvMz9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      QLn7P6C3+z84ufs/
      oLf7P9C4+z/nS41hvL77PyRC/D9Aufs/HEL8PxkAAAAQN59xly4u20C5+z8AAAAA
      AAAAADy1+z9JRExFMAB9JxoMr4Ra1VMAAAAAADi5+z8AAAAAIQAGAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADdTjg==
      LDQIQJYQIkAwCgYAmnMXgGC4+z8AAAAAAAAAAAAAAAAAsPs/EN37PyAFBgAQkvw/
      /////4RB/D8kQvw/I14JgMA8/T8DAAAAIwAGAAAAAABguPs/AAAAAAAAAAAAAAAA
      AAAAACw2CEDAPP0/JIAJQFy89T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACIbgmAgLj7PyAAAAABAAAA
      dU78PwCw+z8Q3fs/IAUGAAAAAACguPs/AAAAAKxB/D8AAAAAbBT9PxBE/D8AAAAA
      AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      tL77PxC9+z+svvs/
      EL37P0C++z9BlRn+JEL8P0i5+z+0vvs/HEL8PxkAAAAy2gwiUVV24rS++z8AAAAA
      AAAAALC6+z9JRExFMQCwFg5XMiej5bQAAQAAAKy++z8AAAAAIQAGAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIq1+g==
      LDQIQJYQIkAwBQYAmnMXgNC9+z8AAAAAIwAGACAABgCAzvs/EN37PyAABgAjAAYA
      /////4RB/D8kQvw/I14JgOC8+z8DAAAAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
      AAAAACw2CEDgvPs/JIAJQMzB9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAACIbgmA8L37PyAAAAABAAAA
      f24JgPC9+z9A3fs/QN37PwAAAAAQvvs/AAAAAKxB/D8gAAAAbBT9PxRE/D8AAAAA
      AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      OE37P0BL+z8wTfs/
      QEv7P9BM+z9w6wAAEEL8P3xe+z84Tfs/CEL8PxMAAAAE6rzhYXOtLDhN+z8AAAAA
      BgAAADQ9+z9Mb1JhADmpc4zOsdcRqjEAAQAAADBN+z8AAAAAIQAGAAYAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIbqmA==
      LDQIQNJrCUAwAgYAvDIRgABM+z9w6wAAQN37P3wt+z8AAAAAAAAAAAAAAADSawmA
      4Ev7PwEAAABw6wAAOE37PwEAAAD+AAAAIwAGAAAAAAAATPs/ZHYAAAAAAAAAAAAA
      AAAAACw2CEABAAAAJIAJQFxQ9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAIEz7P9iZ/D9smvw/
      fC37PwAAAAAAAAAAAAAAAAAAAADQTPs/AAAAAAAAAADQTPs/AAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABcUPU/AAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADA8kM/AAAAAGya/D8AAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Ez7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      dF77PxA9/T8cP/0/
      ED39P7A+/T9v6wAAQE37PxBC/D90Xvs/CEL8PxMAAACOH9WNUidf3XRe+z8AAAAA
      BgAAACAx/T9TaWdmb3gA48Yg9ZZOLAIAAAAAABw//T8AAAAAIQAGAAYAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMG3ng==
      LDQIQNJrCUAwDAYAVoQggNA9/T9v6wAAQN37P2hc+z8AAAAAAAAAAAAAAADSawmA
      sD39PwAAAABv6wAAdF77PwEAAAD+AAAA8tZFPxEAAAA8Qvc/AAAAAKwyCUC3MglA
      /////yw2CEABAAAAJIAJQDxC9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAHRe+z8BAAAA/gAAAPLWRT8AAAAA8D39P2Qv/T9gL/0/
      aFz7PwAAAAAAAAAAAAAAAAAAAACwPv0/AAAAAAAAAAAsNAhAPIQgQDAABQAAAAAA
      sD79PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      PEL3PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALw+/T8AAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
      IMv7P8DJ+z8Yy/s/
      wMn7P7DK+z8AAAAA/EH8P/xB/D8gy/s/9EH8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
      CgAAABzB+z9UbXIgU3ZjAPgVFiYvAKYAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOD4A==
      LDQIQLl9CUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAgRPw/GET8PwEAAAC5fQmA
      YMr7PwAAAABA3fs/dEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAACw2CEAAAAAAJIAJQDzO9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAADzO9T8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
      AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      MHz7P7Cc+z84nvs/
      sJz7P9Cd+z96XEp2LLD7P4zX+z8wfPs/mEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
      GAAAADya+z9pcGMxACFOj+Bx2wii/w0AAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAN/HIg==
      LDQIQMRaCUAwAwYA3DEIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAADEWgmA
      UJ37PwEAAAD/////QN37PxBE/D/+AAAAIAMGABwAAAAAAD4AAAAAAKwyCUC3MglA
      /////yw2CEAQRPw/JIAJQFyh9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAoyCICQnfs/YKr9PwEAAAAAAAAAsJ37PyxB/D8kQfw/
      AAAAABEAAAAAAAAAIAMGAP////8AAAAALEH8PxhB/D8kfPs/AAAAANh7+z8BAAAA
      AAAAANCd+z8AAAAAAAAAAKAbF0Bgqv0/AAAAAAAAAACkFAiAgH3+PwABAADoDQBA
      AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      JLD7P3C7/T8Mvf0/
      cLv9P6C8/T8gAAAAJN39Pzh8+z8ksPs/mEH8PxQAAABAkQAAAQAAACSw+z8AAAAA
      BQAAABCt/T9TbWFydENvbmZpZwAAAAAAAQAAAAy9/T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
      LDQIQPC/AEAwAAYA7GYJgDC8/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
      q6sAABDd+z8jAAYAJLD7PwEAAAD+AAAAqAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEABAAAAJIAJQCzA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAQLz9P0Dd+z8FAAAA
      MHEOgGC8/T8BAAAAFET8PySw+z8BAAAA/gAAACADBgAAAAAAgLz9PwAAAAAAAAAA
      EET8P0Dd+z+EQfw/iEL8PwAAAACgvP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArLz9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      HN39P4Db/T8U3f0/
      gNv9P7Dc/T+aRNb6tFr7Pyyw+z8c3f0/mEH8PxQAAACdHgP24PU5Dxzd/T8AAAAA
      BQAAABjN/T9Tb2NrZXQgT3BlcmF0aW8AAQAAABTd/T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAABUzfg==
      LDQIQPC/AEAwAAYA7GYJgEDc/T8AAAAAIwAGACAABgBgqv0/VQAAAHC8/T///z+z
      q6sAABDd+z8jAAYAHN39PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEABAAAAJIAJQDzg9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADGeAmAUNz9P0Dd+z8GAAAA
      DmEOgHDc/T8BAAAAFET8Pxzd/T8BAAAA/gAAALCd+z8AAAAAkNz9PwAAAAAAAAAA
      EET8P0Dd+z+EQfw/iEL8PwAAAACw3P0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAvNz9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      rFr7PxBZ+z+kWvs/
      EFn7P0Ba+z9idwBksOL9PyTd/T+sWvs/mEH8PxEAAABUPPs/VDz7P6xa+z9MPPs/
      CAAAAKhO+z9Mb1JhX1RpbWVyX2NhbGwAAQAAAKRa+z8AAAAAIQAGAAgAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALFAbA==
      LDQIQMRaCUAwAAYAwB0RgNBZ+z8oPPs/EFr7P3Q8+z8AAAAAfDz7PwAAAADEWgmA
      sFn7PwEAAAD/////QN37PxBE/D/+AAAAIAEGAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQMxd9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEFr7P5Sb/D8AAAAA
      AAAAABsAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAADMXfU/AAAAAAAAAAAAAAAA
      AAAAAEBa+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATFr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      qOL9P0Ai/j9YJP4/
      QCL+P/Aj/j85gVOucHr7P7Ra+z+o4v0/mEH8Pw4AAAAws/s/MLP7P6ji/T8os/s/
      CwAAAFwE/j9JUlFzAKqC3gwG2SwZAjwAAQAAAFgk/j8AAAAAIQAGAAsAAAAAAAAA
      AAAAAIwj/j8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAlCKug==
      LDQIQMRaCUAwAQYAnEgPgAAj/j8Es/s/oCP+P1Cz+z8AAAAAWLP7PwAAAADEWgmA
      4CL+PwEAAAD/////QN37PxBE/D/+AAAAAAAAAAAAAAB8J/g/AAAAAAAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQHwn+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAYAAAApaWlpaWlpaVoCg6AQCP+P5iS/D+gI/4/
      AAAAAIMAAAClpaWlpaWlpf////9AI/4/xJX8P6Aj/j8AAAAAAQAAAEhk+z/8////
      AAAAANAj/j+Mkvw/AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAjJL8PwAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgI/4/
      ABwAAGiU/D9olPw/AAAAAHwn+D8AAAAAAAAAAAAAAABolPw/CgAAAIRB/D8AQ/w/
      AAAAAPAj/j8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAD8I/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      aHr7P+B4+z9gevs/
      4Hj7PwB6+z/5oxAkhHL7P7Di/T9oevs/mEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
      GAAAAGR2+z9pcGMwAOZ34dPin5WWU04AAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD2rdw==
      LDQIQMRaCUAwDAYA3DEIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAADEWgmA
      gHn7PwAAAAD/////QN37PxBE/D/+AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQIx99T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PyhB/D8AAAAA
      AAAAAEJ3AAD+AAAAAQAAAP////8AAAAAKEH8PxhB/D8Advs/AAAAAAEAAAAAAAAA
      AAAAAAB6+z8AAAAAAAAAACR8CEAAAAAAAAAAAAAAAAAZFAiAIDz+P4BB/D9XbEA/
      AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      fHL7P+Bw+z90cvs/
      4HD7PxBy+z+BK+mbzPn9P3B6+z98cvs/mEH8PwMAAABAQPw/QED8P3xy+z84QPw/
      FgAAAHhm+z9lc3BfdGltZXIAQYtE53EAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAhM1A==
      LDQIQMRaCUAwDAYA/SMNgKBx+z8UQPw/AAAAAGBA/D8AAAAAFED8PwAAAADEWgmA
      gHH7PwAAAAD/////QN37PxBE/D/+AAAAIAAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQJx19T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4HH7P2hA/D9wQPw/
      AAAAAJHEAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACcdfU/AAAAAAAAAAAAAAAA
      AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHBA/D8gAAAD
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      xPn9P5BF/T8gR/0/
      kEX9P8BG/T/E+f0/9EX8P4Ry+z/E+f0/mEH8Pw0AAAB89/0/fPf9P8T5/T909/0/
      DAAAACQ//T9MVEVfVUFSVF9FVlQAN54AAQAAACBH/T8AAAAAIQAGAAwAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOP7Q==
      LDQIQMRaCUAwAAYAukMRgFBG/T9Q9/0/kEb9P5z3/T8AAAAApPf9PwAAAADEWgmA
      MEb9PwEAAAD/////QN37PxBE/D/+AAAANAYAAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQExK9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkEb9P6Sb/D8AAAAA
      AAAAAG3rAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAABMSvc/AAAAAAAAAAAAAAAA
      AAAAAMBG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzEb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      7EX8P/Ck/T8Irf0/
      8KT9P6Cs/T9t6wAAoEH8P8z5/T/sRfw/mEH8Pw4AAABg+/0/YPv9P+xF/D9Y+/0/
      CwAAAAx9/T9NaWNyb1B5AAAAAAAAAAAAAQAAAAit/T8AAAAAIQAGAAsAAAABAAAA
      fGP7PxSU/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
      LDQIQLAfCEAwDgYAxFoJgLCl/T8BAAAA/////0Dd+z8QRPw//gAAAGCl/T+wHwiA
      kKX9P+AA8D8BAAAAEN37PwEAAAD+AAAAAAAAAA8AAADoMP0/cKX9PyxBCUBaQQlA
      /////yw2CEABAAAAJIAJQCyw9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAL39GIDApf0/FND7PwEAAABU/RiA0KX9PzT7/T8AAAAA
      UQIYgACm/T9oFf0/MKb9P1gCGIAQpv0/5AC8PwAAAAAAAAAAbesAAP4AAABgpf0/
      /////wAAAAAgAAAAAAAAAID7/T8AAAAANPv9PwAAAADoAhmAMKb9PygCGUBgpv0/
      besAAAEAAAD+AAAAhPxFPwRBEYBgpv0/AAAAAAAAAAABAAAAKAIZQGCm/T/kALw/
      aBX9PwEAAAALAAAAAQAAAHlIEYCgpv0/AAAAAAEAAABRIRCAAAAAAABIEUAAAAAA
      AQAAAJCm/T9QA0Q/xQQAAMT5/T8AAAAADAAAAAAIAABRIRCAwKb9P3BIEUAAAAAA
      AAgAAAAAAADUAQAApwMAAHTlD4Dgpv0/LAVEPwAAAAAAAAAAAQAAAAoAAABgqP0/
      2vQPgACn/T8sBUQ/AAAAAAAAAAA8qP0/uKb9PxYTAAB05Q+AIKf9P+AIlT8AAAAA
      AAAAADyo/T8DAAAAIwAGAATmD4BAp/0/4AiVPwAAAAAAAAAAPKj9PwIAAABAqf0/
      2qUQgGCn/T8AAAAAAAAAAAAAAAA8qP0/AgAAADIJAAB/IhCAgKf9PwQAAACuyUI/
      NKj9Pzio/T+op/0/EKj9P3TlD4AgqP0/EPOUP2iU/D/AqP0/AAAAAH8iEICAp/0/
      CAAAAECo/T88qP0/NKj9PwAAAAADAAAAAAAAAAAAAAAssPc/AAAAAHTlD4AgqP0/
      EPOUP2iU/D8mmBCAIAsGAAcAAAA0qP0/AAAAAAMAAAAAAAAAIKj9P0Co/T88qP0/
      gKn9PwAAAAAjAwYAIAMGADSo/T8w////r8lCPzSo/T8E5g+AgKj9P2D4lD8AAAAA
      YPiUP63JQj8wqP0/NKj9P2iU/D/gCJU/AAAAABYTAAAAAAAAAAAAAKwyCUC3MglA
      AAAAAAAAAAAAAAAATjQIQCCo/T+Aqf0/AAAAAFCo/T/apRCAoKj9PwAAAAAAAAAA
      AAAAAICp/T8kcPQ/AAAAAH8iEIDAqP0/BAAAAIgJlT94qf0/UKn9P+io/T9Qqf0/
      dOUPgGCp/T9olPw/aJT8PwCq/T8Aqf0/fyIQgMCo/T8IAAAAgKn9P3yp/T90qf0/
      AAAAAAMAAAAUlPw/JIAJQAAAAAAAAAAAdOUPgGCp/T9olPw/aJT8PyaYEIAAAAAA
      CAAAAHSp/T8AAAAAAwAAAAAAAABgqf0/gKn9P3yp/T8AAAAANKn9PwEAAAADAAAA
      eKn9PzD///+JCZU/AwAAAKHlD4DAqf0/AAGVPwAAAAAAAZU/hwmVP3Cp/T90qf0/
      aJT8PywIQT9g+JQ/AAAAAJFACICwqf0/0Kn9PwAAAAAAAAAAAAAAAOAIlT8AAAAA
      YKn9PwAAAAAAAAAAkKn9P4AWDoDgqf0/AAGVPwAAAAAAAAAAAAAAAAUAAAAAAAAA
      CxkOgACq/T8AAZU/FgAAAAAAAAAAAAAAAAAAABgJlT/EAQ6AoKr9PwUZQD8AAAAA
      AAAAADCq/T8LGQ6AAKr9PxBP/D8AAAAAFgAAAFwAAAAiAAAACAAAAA0AAADwTvw/
      DQAAAA4AAADEAQ6AoKr9PwUZQD8AAAAA/BUOgEAMlT8ADJU/gKr9P6Cq/T/JGEA/
      AAAAAPBO/D8cAAAAMPOUPxYAAACgqv0/WOsAAAAAAAAWAAAAXAAAACIAAAAIAAAA
      AAAAAOCq/T9E+Ps/CKz9PyAAAAAcAAAAkO6UPwgAAAAAAAAA4Kr9PwAAAAAIrP0/
      tGD7PwAAAAABAAAAAAAAAAAAAACgrP0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
      AAAAAAAAAaXoAAAA6QAAAAEAAAAABAAA+P8f0AAAAAD//////////6WlpaWlpaWl
      AQAIAAAAAAClpaWlpaWlpaWlpaWlpaWlpaWlpQAAAACkXkA/paWlpaWlpaWlpaWl
      paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
      LDQIQCT9DUAwAAUAAAAAAKCs/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAABAHh0A
      AAAAAP////////////////////8+oc1MAAAAAAAAAAAAAAAAAPAfAOCq/T8AAAAA
      AAAoAAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAALRH/D8AAAAAAAAAAAAAAAAAAAAA
      AQAAAAAAAACsrP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      hNf7P1B7/T8Eff0/
      UHv9P6B8/T/sjVOBOHz7P6BB/D+E1/s/mEH8PwUAAABY0fs/WNH7P4TX+z9Q0fs/
      FAAAAAhx/T9ldmVudFRhc2sAcYS0V0EAAAAAAAR9/T8AAAAAIQAGABQAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAImMeQ==
      LDQIQMRaCUAwAAYA0HQXgBB8/T8s0fs/UHz9P3jR+z8AAAAAgNH7PwAAAADEWgmA
      8Hv9PwAAAAD/////QN37PxBE/D/+AAAAKNH7PwAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAACw2CEAQRPw/JIAJQCyA9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAKB8/T8AAAAAAAAAAAAAAAAAAAAAUHz9P7wU/T8AAAAA
      AAAAAAAAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAKB8/T8AAAAAAAAAACyA9z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAACsfP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAA==
      Is the modem bricked ? What can i do ?
        I do not believe your modem would be bricked by this. But lets go through the troubleshooting steps:
        1. You appear to be using sqnsupgrade.reconnect_uart() though the documentation suggest sqnsupgrade.uart(True). Let me know of the output.
        2. Are you able to get the version number from the LTE modem by using sqnsupgrade.info() (in the latest version this gives a coredump after returning the version information, we're working on fixing that, but it poses no operational issue)
        3. Can you connect to a LTE network still?
        Let me know!
        • N Offline
          Nicolas Vandamme
          Thanks for the feedback.
          Either sqnsupgrade.info() or sqnsupgrade.uart(True) raise a core dump...
          • N Offline
            Nicolas Vandamme @Nicolas Vandamme
            @Nicolas-Vandamme
            >>> import sqnsupgrade
            >>> sqnsupgrade.info()
            <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
            >>> FiPy with firmware version 1.20.2.r4
            Cannot determine modem state!
            A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000005  A5      : 0xffffffff
            A6      : 0x1496bca8  A7      : 0x00060021  A8      : 0x8018fe34  A9      : 0x3ffbaeb0
            A10     : 0x0000003a  A11     : 0x00000000  A12     : 0x3ffbd060  A13     : 0x00000000
            A14     : 0x3ffbd070  A15     : 0x00000001  SAR     : 0x00000000  EXCCAUSE: 0x0000001d
            Rebooting...
            ets Jun  8 2016 00:22:57
            • N Offline
              @Nicolas-Vandamme
              >>> import sqnsupgrade
              >>> sqnsupgrade .uart(True)
              Could not detect your modem!
              Please try to power off your device and restart in safeboot mode.
              A6      : 0x0002cf98  A7      : 0x00060021  A8      : 0x8018fe34  A9      : 0x3ffbaeb0
              A10     : 0x00000041  A11     : 0x00000000  A12     : 0x3ffbd060  A13     : 0x00000000
              Rebooting...
                peterp
                Please post the output of sqnsupgrade.info(debug=True) and sqnsupgrade.uart(True, debug=True)
                N 1 Reply Last reply Reply Quote 1
                • N Offline
                  Nicolas Vandamme @peterp
                  @peterp said in LTE firmware update stuck at resetting:
                  info(debug=True)
                  >>> import sqnsupgrade
                  The current delay is 1000
                  Response (+++ #1): b'\x00'
                  Response (AT #1) None
                  Response (AT #3) b'\x00'
                  Response (AT #4) None
                  Response (AT #1 @ 115200) b'\x80'
                  Response (AT #2 @ 115200) b'\x80'
                  The current delay is 2000
                  Response (AT #3) b'\x00\x00'
                  Response (AT #4) b'\x00\xfe\x00'
                  Response (AT #1 @ 115200) b'\x80\x80'
                  The current delay is 3000
                  Response (AT #1) b'\x00'
                  Response (AT #2) None
                  Response (+++ #2): b'\x00'
                  Response (AT #4) b'\x00\x00\x00\x00'
                  Response (AT #1 @ 115200) b'\x80\x80\x00'
                  Response (AT #2 @ 115200) b'\x80\xc0'
                  The current delay is 4000
                  Response (AT #3) b'\x00\x00\x00'
                  Response (AT #1 @ 115200) b'\xc0\x80\x80'
                  Response (AT #2 @ 115200) b'\x80\x80\x80\x80'
                  The current delay is 5000
                  Response (AT #3) b'\x00\x00\x00\x00'
                  Response (AT #4) b'\x00\x00\x00\x00\x00'
                  Response (AT #1 @ 115200) b'\x80\x80\x00\x80'
                  Response (AT #2 @ 115200) b'\x80\x00\x00\x80'
                  Modem state: None
                  A6      : 0x05ab7e19  A7      : 0x00060021  A8      : 0x8018fe34  A9      : 0x3ffbaeb0
                  A10     : 0x00000016  A11     : 0x00000000  A12     : 0x3ffbd060  A13     : 0x00000000
                  Rebooting...
                  Response (AT #4) b'\x00'
                  Response (AT #1 @ 115200) b'\x00'
                  Response (AT #4) b'\xff'
                  Response (AT #1 @ 115200) b'\xc0\xc0'
                  Response (AT #2 @ 115200) b'\xc0\x80'
                  Response (AT #4) b'\x00\x00'
                  Response (AT #2 @ 115200) b'\x80\x80\x80'
                  Response (AT #4) b'\x00\x90\x00\x00\x00'
                  Response (AT #1 @ 115200) b'\x80\x80\xc0'
                  Response (AT #2 @ 115200) b'\xc0\x80\x00\x80'
                  Response (AT #4) b'\x00\x00\x00\x00\x00\x00'
                  Response (AT #1 @ 115200) b'\x80\x80\x00\x00'
                  Response (AT #2 @ 115200) b'\x80\xc0\x80\xc0'
                  Modem state: None
                  A6      : 0x00014b51  A7      : 0x00060021  A8      : 0x8018fe34  A9      : 0x3ffbaeb0
                  A10     : 0x00000012  A11     : 0x00000000  A12     : 0x3ffbd060  A13     : 0x00000000
                  Rebooting...
                    peterp @Nicolas Vandamme
                    @Nicolas-Vandamme Thanks. Ok, this is not good - please contact support, so we can debug in more detail https://pycom.io/community/contact-support/
                    • N Offline
                      @peterp thanks for your help, i'll contact the support then.
