FiPy FTP upload in C# returns (451) Local error in processing.
  • I'm writing a Windows Forms application in C# that allows a user to connect to a FiPy, update the firmware, and upload program files via FTP.
    I am able to connect to the server and update the firmware with the same code below without any issues and I can successfully upload program files to the FiPy via Filezilla. But when I run the code below I receive the error "The remote server returned an error: (451) Local error in processing." at the line "ftpstream.Close();" every single time no matter what file I try to upload, regardless of size or file type, and the new file does show up in Filezilla on the FiPy but with a size of 0 bytes.
    I ran format flash storage in Atom before I started so there's nothing on the FiPy other than the updated firmware so I know it has enough space.
    The WebException thrown shows no extra details in the InnerException and the StatusDescription comes back as an empty string.
    Can anyone help me out?
    My code:
                    var deviceFilepath = "ftp://192.168.4.1/flash/main.py";
                    var appFilepath = "rwis\\main.py";
                    string UserId = "micro";
                    string Password = "python";
                    FtpWebRequest ftp = (FtpWebRequest)FtpWebRequest.Create(deviceFilepath);
                    ftp.Credentials = new NetworkCredential(UserId, Password);
                    ftp.UsePassive = true;
                    ftp.Method = WebRequestMethods.Ftp.UploadFile;
                    var buffer = File.ReadAllBytes(appFilepath);
                    Stream ftpstream = ftp.GetRequestStream();
                    ftpstream.Write(buffer, 0, buffer.Length);
                    ftpstream.Close();
  • In case someone else comes across this post looking for help:
    I solved the issue by using a different third party FTP library that was suggested to me on the Stack Overflow post I made:
    https://stackoverflow.com/questions/67011710/ftpwebrequest-to-microcontroller-always-results-in-451-local-error-in-processi/67079870#67079870
    Not exactly sure what the underlying issue was, it might've been that the fipy explicitly wants you to change your working directory to the flash directory before uploading or it might've been something else in the library that handled it better. Either way, my FTP log now more closely matches the one from FileZilla and no more errors!
    My New Code:
            FtpClient client = new FtpClient("ftp://192.168.4.1");
            client.Credentials = new NetworkCredential(UserId, Password);
            client.DataConnectionType = FtpDataConnectionType.PASV;
            client.Connect();
            client.SetWorkingDirectory("/flash");
            client.UploadFile(appFilepath, "rwis_config.py", FtpRemoteExists.NoCheck);
            client.Disconnect();
    New FTP Log Output:
    # Connect()
    Status:   Connecting to ***:21
    Response: 220 Micropython FTP Server
    Command:  USER ***
    Response: 331
    Command:  PASS ***
    Response: 230
    Command:  FEAT
    Response: 211 no-features
    Status:   Text encoding: System.Text.ASCIIEncoding
    Command:  SYST
    Response: 215 UNIX Type: L8
    # SetWorkingDirectory("/flash")
    Command:  CWD /flash
    Response: 250
    # UploadFile("rwis\rwis_config.py", "rwis_config.py", NoCheck, False, None)
    # OpenWrite("rwis_config.py", Binary)
    Command:  TYPE I
    Response: 200
    # OpenPassiveDataStream(PASV, "STOR rwis_config.py", 0)
    Command:  PASV
    Response: 227 (192,168,4,1,7,232)
    Status:   Connecting to ***:2024
    Command:  STOR rwis_config.py
    Response: 150
    Status:   Disposing FtpSocketStream...
    Response: 226
    Status:   Testing connectivity using Socket.Poll()...
    Command:  QUIT
    Response: 221
  • @robert-hh Looks like I can just disable proxy and that error in the log goes away. I have no clue if I need that to be enabled or not, disabling didn't seem to affect anything else, still getting the 451 error and the FTP Proxy settings in Filezilla are set to None so I don't think that's the issue.
    System.Net Information: 0 : [24900] Current OS installation type is 'Client'.
    System.Net Information: 0 : [24900] FtpWebRequest#3741682::.ctor(ftp://192.168.4.1/flash/main.py)
    System.Net Information: 0 : [24900] FtpWebRequest#3741682::GetRequestStream(Method=STOR.)
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Created connection from 192.168.4.2:56579 to 192.168.4.1:21.
    System.Net Information: 0 : [24900] Associating FtpWebRequest#3741682 with FtpControlStream#43332040
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [220 Micropython FTP Server]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [USER micro]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [331 ]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [PASS ********]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [230 ]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [OPTS utf8 on]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [502 ]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [PWD]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [257 /]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [TYPE I]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [200 ]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [PASV]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [227 (192,168,4,1,7,232)]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Sending command [STOR flash/main.py]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [150 ]
    System.Net Information: 0 : [24900] FtpControlStream#43332040 - Received response [451 ]
    System.Net Information: 0 : [24900] FtpWebRequest#3741682::(Releasing FTP connection#43332040.)
  • @robert-hh Great..... I considered that when I first saw it but a quick google didn't come up with anything helpful. I'll look again. Any ideas for fixing it?
  • @Tasha-Weidler said in FiPy FTP upload in C# returns (451) Local error in processing.:
    I guess the line below points at the problem.
    System.Net Error: 0 : [6548] Can't retrieve proxy settings for Uri 'ftp://192.168.4.1//flash/main.py'. Error code: 12180.
  • @robert-hh Right, I am stumped. And that error message is less than helpful. This is what the file structure looks like in FileZilla so the flash directory exists and there's a top level folder labelled "/" so that's where the slash for PWD comes from. Anything look fishy there?
    Then I tried var deviceFilepath = "ftp://192.168.4.1//flash/main.py"; to see if that helped anything with the file name and I got this output. STOR changed to /flash/main.py but PWD stayed as "/". Maybe I could try to manually set PWD to /flash?
    System.Net Information: 0 : [6548] Current OS installation type is 'Client'.
    System.Net Information: 0 : [6548] FtpWebRequest#3741682::.ctor(ftp://192.168.4.1//flash/main.py)
    System.Net Information: 0 : [6548] FtpWebRequest#3741682::GetRequestStream(Method=STOR.)
    System.Net Information: 0 : [6548] RAS supported: True
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Created connection from 192.168.4.2:60371 to 192.168.4.1:21.
    System.Net Information: 0 : [6548] Associating FtpWebRequest#3741682 with FtpControlStream#34640832
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [220 Micropython FTP Server]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [USER micro]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [331 ]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [PASS ********]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [230 ]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [OPTS utf8 on]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [502 ]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [PWD]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [257 /]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [TYPE I]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [200 ]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [PASV]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [227 (192,168,4,1,7,232)]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Sending command [STOR /flash/main.py]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [150 ]
    System.Net Information: 0 : [6548] FtpControlStream#34640832 - Received response [451 ]
    System.Net Information: 0 : [6548] FtpWebRequest#3741682::(Releasing FTP connection#34640832.)
  • @Tasha-Weidler Looking into the code, it tells that the actual file open of flash/main.py succeeds, but writing to that file fails. That is strange. The port used for data transfer is 2024. Since filezilla works, that should not be a problem.
  • @Tasha-Weidler No, it lloks okay. PWD is / so the file name has to be flash/main.py.
  • This post is deleted!
  • @robert-hh Ah, I see, that makes sense. Thanks for your response!
    I'm not sure what you mean, are you saying var deviceFilepath = "ftp://192.168.4.1/flash/main.py"; should be var deviceFilepath = "ftp://192.168.4.1/main.py";?
    FTP Log:
    System.Net Information: 0 : [28564] Current OS installation type is 'Client'.
    System.Net Information: 0 : [28564] FtpWebRequest#3741682::.ctor(ftp://192.168.4.1/flash/main.py)
    System.Net Information: 0 : [28564] FtpWebRequest#3741682::GetRequestStream(Method=STOR.)
    System.Net Information: 0 : [28564] RAS supported: True
    System.Net Error: 0 : [28564] Can't retrieve proxy settings for Uri 'ftp://192.168.4.1/flash/main.py'. Error code: 12180.
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Created connection from 192.168.4.2:62970 to 192.168.4.1:21.
    System.Net Information: 0 : [28564] Associating FtpWebRequest#3741682 with FtpControlStream#34640832
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [220 Micropython FTP Server]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [USER micro]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [331 ]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [PASS ********]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [230 ]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [OPTS utf8 on]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [502 ]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [PWD]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [257 /]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [TYPE I]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [200 ]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [PASV]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [227 (192,168,4,1,7,232)]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Sending command [STOR flash/main.py]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [150 ]
    System.Net Information: 0 : [28564] FtpControlStream#34640832 - Received response [451 ]
    System.Net Information: 0 : [28564] FtpWebRequest#3741682::(Releasing FTP connection#34640832.)
  • @Tasha-Weidler appimg.bin will not be written to the file system. Instead it is stored directly to the unused firmware partition. So the problem lies in the file name you use. Can you try just main.py as file name. Can you get hold of the raw ftp log to see, which ftp commands are generated.
  • @livius No luck, same error is thrown when exiting the using block.
    I've also tried this way and get the same error from the UploadFile function:
                    WebClient client = new WebClient();
                    client.UploadFile(deviceFilepath, appFilepath);
    I can't figure out why it works fine for writing fipy.bin to flash/sys/appimg.bin for the firmware but it doesn't work for writing a .py/.txt/etc directly to the flash directory. I wondered if its maybe a permissions issue but the permissions looked fine and worked fine in Filezilla and I'm not sure how to check them directly on the fipy.
  • @Tasha-Weidler
    it should work but try different way:
    using (Stream fileStream = File.OpenRead(appFilepath))
    using (Stream ftpStream = request.GetRequestStream())
        fileStream.CopyTo(ftpStream);
  • @livius Thank you for your quick response! But unfortunately I tried that too and I get the same error result...
  • @Tasha-Weidler
    add ftpstream.Flush(); before close
15 out of 15
