    Guru Meditation Error: sqnsupgrade.info()
    Scheduled Pinned Locked Moved Support & Troubleshooting
    5 Posts 2 Posters 51 Views 2 Watching
      Aleksandr Podgaysky
      Hello. I faced with problems while testing LTE modem on GPy. Modem is not able to find any network. I decided to update the LTE firmware but faced with problem. sqnsupgrade.info() finishes with Guru Meditation Error.
      Backtrace translation is
      ppp_close
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/netif/ppp/ppp.c:326
      pppapi_do_ppp_close
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/netif/ppp/pppapi.c:372
      tcpip_thread
      /home/peter/docs/pycom-esp-idf/components/lwip/lwip/src/api/tcpip.c:124
      Moreover, sqnspudate.run('COM','xxx,dup') freezes on "Attempting AT wakeup..." and nothing happens.
      I tried to power GPy from both DC source and Li-Ion battery but behaviour was the same in both cases. How can I solve my problem and make LTE modem work?
        The issue is only with sqnsupgrade.info() (as you decoded, the closing of the ppp), and does not affect the rest of the modem operation, nor the update functionality.
        Concerning your issue with sqnsupgrade.run(), could you add the debug=True flag in the command? This should give more insight in the AT commands being send. Note that you'll have to close the Pymakr connection to your Gpy.
          Aleksandr Podgaysky
          Now the process goes successfully.
          import sqnsupgrade
          sqnsupgrade.run('COM7','CATM1-5.2-48829-1.dup',debug=True)
          Welcome to the SQN3330 firmware updater [1.2.7] >>>
          File CATM1-5.2-48829-1.dup has size 416448
          file_path? CATM1-5.2-48829-1.dup mirror? False recover? False resume? False direct? False atneg_only? False bootrom? False load_fff? True
          baudrate: 921600 target_baudrate: 921600
          Setting port COM7
          Setting baudrate to 921600
          Initial prepartion complete...
          Loading CATM1-5.2-48829-1.dup
          Attempting AT wakeup... [921600]
          b'\r\nOK\r\n'
          AT+BIND=AT returned b'\r\nOK\r\n'
          ATE0 returned b'\r\nOK\r\n'
          Entering upgrade mode...
          Sending AT+SMLOG?
          AT+SMLOG? returned b'\r\n+SMLOG: LOG_INHERIT\r\nOK\r\n'
          AT+SMOD? returned 2
          AT+SQNSUPGRADENTF="started" returned b'\r\n\r\nOK\r\n'
          Sending AT+SQNWL="sqndcc",2
          AT+SQNWL="sqndcc",2 returned b'\r\n+SQNWL: "sqndcc",2\r\n\r\nOK\r\n'
          Sending AT+CFUN=4
          AT+CFUN=4 returned b'\r\nOK\r\n\r\n+CEREG: 0\r\n'
          Starting STP [FFF]
          Sending AT+SMSTPU
          Starting STP code upload with pkgdebug=False
          running m.wipe
          running m.reset
          magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0x0
          Correct SRSP signature: 0x74736166
          running m.open_session
          running push(m)
          Sending 416448 bytes: [########################################] 100%
          running dev.set_timeout(2)
          running m.reset(True)
          start returned True type <class 'bool'>
          Code download done, returning to user mode
          Waiting for modem to finish the update...
          This might take several minutes!
          <<<=== DO NOT DISCONNECT POWER ===>>> [921600]
          b'\r\nOK\r\n'
          AT+SMUPGRADE? returned b'\x00' [timeout: 0.4780917167663574]
          AT+SMUPGRADE? returned b'\r\n+SYSSTART\r\n' [timeout: 5.001538515090942]
          AT+SMUPGRADE? returned b'\r\n+SMUPGRADE: success\r\n\r\nOK\r\n' [timeout: 5.478849411010742]
          AT+SMSWBOOT? returned b'\r\nFFF\r\nOK\r\n'
          This is my result: success
          Sending AT+SQNSUPGRADENTF="success"
          AT+SQNSUPGRADENTF="success" returned b'\r\nOK'
          Your modem has been successfully updated.
          Here is the current firmware version:
          file_path? None mirror? False recover? False resume? True direct? True atneg_only? False bootrom? False load_fff? False
          Setting port COM7
          SYSTEM VERSION
          FIRMWARE VERSION
          Bootloader0 : 5.1.1.0 [43818]
          Bootloader1* : 5.2.1.0 [48829]
          Bootloader2 : NA
          NV Info : 1.1,0,0
          Software : 5.1.1.0 [43818] by robot-soft at 2019-05-29 15:58:56
          UE : 5.0.0.0d
          COMPONENTS
          ZSP0 : 1.0.99-13616
          ZSP1 : 1.0.99-12376
          IMEI: 354347097005992
            Aleksandr Podgaysky @Aleksandr Podgaysky
            There are two files in archive provided by pycom: CATM1-5.2-48829-1.dup and CATM1-5.2-48829-2.dup. What should i do with CATM1-5.2-48829-2.dup ?
              As mentioned on the LTE modem firmware update page: https://docs.pycom.io/updatefirmware/ltemodem/ the 5.2-48829 update is a two-step process. You'll first need to load file 1, and then file 2: https://docs.pycom.io/updatefirmware/ltemodem/#note-on-updating-to-cat-m1-52-48829 :)
