    LoPy To MultiTech Conduit
    25 Posts 6 Posters 10.8k Views 6 Watching
      johncaipa @cmsedore
      Hi @cmsedore You give me to understand that it is a problem with the firmware? Hopefully the Pycom team will take it into account.
      Sorry but I do not know where the repository is, you can share the link as soon as you can, sorry for the inconvenience.
        livius
        https://github.com/pycom/pycom-micropython/pulls
          dchappel @johncaipa
          @johncaipa
          Until the firmware is updated, here is the workaround I came up with. Since the current firmware insists on using all the channels, this distributes the the desired sub-band frequencies among them all.
          It's not pretty, but it works!
          from network import LoRa
          import binascii
          import utime
          def select_subband(lora, subband):
              if (type(subband) is int):
                  if ((subband<1) or (subband>8)):
                      raise ValueError("subband out of range (1-8)")
                  raise TypeError("subband must be 1-8")
              for channel in range(0, 72):
                  lora.remove_channel(channel)
              index = (subband-1)*8
              for channel in range(0, 7):
                  lora.add_channel(channel, frequency=902300000+index*200000, dr_min=0, dr_max=3)
                  index+=1
              for channel in range(8, 15):
                  index+=1
              for channel in range(16, 23):
                  index+=1
              for channel in range(24, 31):
                  index+=1
              for channel in range(32, 39):
                  index+=1
              for channel in range(40, 47):
                  index+=1
              for channel in range(48, 55):
                  index+=1
              for channel in range(56, 63):
                  index+=1
              for channel in range(64, 71):
                  index+=1
          lora = LoRa(mode=LoRa.LORAWAN, adr=False, public=True, tx_retries=0)
          sb = 2 #Change to desired conduit frequency sub-band
          select_subband(lora,sb)
          app_eui = binascii.unhexlify('00 00 00 00 00 00 00 00'.replace(' ',''))
          app_key = binascii.unhexlify('00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'.replace(' ',''))
          while not lora.has_joined():
              time.sleep(5)
              print('Not yet joined on frequency sub-band '+str(sb)+'...')
          if(lora.has_joined()):print("Successful join on frequency sub-band "+str(sb)+"!")
          s.setblocking(False)
          pressure = 1
          while lora.has_joined():
              payload = '{"pressure":'+str(pressure)+',"tst":'+str(utime.time())+'}'
              print(payload)
              s.send(payload)
              time.sleep(6)
              pressure +=1
              if pressure > 100:
                  pressure = 1
            johncaipa @dchappel
            @dchappel do you know if the error was already corrected in the new firmware (1.5.0.b2)?
              dchappel
              I don't know if this got fixed. Haven't gone back and checked.
              • I Offline
                iannucci @dchappel
                @dchappel I built my own version of the firmware with this fix in it. But as this is the first time I've built ESP32 / LoPy firmware, I am having a small problem. The make process seems to work properly, and the flashing process seems to work. But when I remove the jumper wire and reboot the LoPy, it runs a different version of firmware, not the one I just flashed.
                I've tried the safe boot tricks to no avail.
                Any ideas how to get the LoPy to come up running the version of firmware just uploaded via make?
                • I Offline
                  iannucci @iannucci
                  @iannucci Just re-tried this and was able to compile, flash and boot. Initial test indicates the issue is resolved, but I will do some additional testing.
                  • I Offline
                    iannucci @iannucci
                    @iannucci Sadly, the fix does not work for me. Benefit: does not seem to hang. Downside: the first seven packets get through (according to the Loriot dashboard). After that, nothing.
                      cmsedore @iannucci
                      @iannucci I just was back in the office today and ran some tests--I couldn't create a scenario where it did not work as expected (all packets went through). Do you have source you could share? Does it behave better if you reconfigure all the channels as @dchappel suggested? (the code is in the post below)
                      • I Offline
                        iannucci @cmsedore
                        @cmsedore I just ran a test with @dchappel's code -- 4000+ messages and counting, no drops. Good news!
                          @cmsedore Sorry for the delay in merging your code. I'm testing it now and everything looks solid. This will be on the next release. Thanks for your contribution!
                          • 2 / 2
