    LoPy To MultiTech Conduit
    25 Posts 6 Posters 10.8k Views 6 Watching
      livius
      https://github.com/pycom/pycom-micropython/pulls
        dchappel @johncaipa
        @johncaipa
        Until the firmware is updated, here is the workaround I came up with. Since the current firmware insists on using all the channels, this distributes the the desired sub-band frequencies among them all.
        It's not pretty, but it works!
        from network import LoRa
        import binascii
        import utime
        def select_subband(lora, subband):
            if (type(subband) is int):
                if ((subband<1) or (subband>8)):
                    raise ValueError("subband out of range (1-8)")
                raise TypeError("subband must be 1-8")
            for channel in range(0, 72):
                lora.remove_channel(channel)
            index = (subband-1)*8
            for channel in range(0, 7):
                lora.add_channel(channel, frequency=902300000+index*200000, dr_min=0, dr_max=3)
                index+=1
            for channel in range(8, 15):
                index+=1
            for channel in range(16, 23):
                index+=1
            for channel in range(24, 31):
                index+=1
            for channel in range(32, 39):
                index+=1
            for channel in range(40, 47):
                index+=1
            for channel in range(48, 55):
                index+=1
            for channel in range(56, 63):
                index+=1
            for channel in range(64, 71):
                index+=1
        lora = LoRa(mode=LoRa.LORAWAN, adr=False, public=True, tx_retries=0)
        sb = 2 #Change to desired conduit frequency sub-band
        select_subband(lora,sb)
        app_eui = binascii.unhexlify('00 00 00 00 00 00 00 00'.replace(' ',''))
        app_key = binascii.unhexlify('00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'.replace(' ',''))
        while not lora.has_joined():
            time.sleep(5)
            print('Not yet joined on frequency sub-band '+str(sb)+'...')
        if(lora.has_joined()):print("Successful join on frequency sub-band "+str(sb)+"!")
        s.setblocking(False)
        pressure = 1
        while lora.has_joined():
            payload = '{"pressure":'+str(pressure)+',"tst":'+str(utime.time())+'}'
            print(payload)
            s.send(payload)
            time.sleep(6)
            pressure +=1
            if pressure > 100:
                pressure = 1
          johncaipa @dchappel
          @dchappel do you know if the error was already corrected in the new firmware (1.5.0.b2)?
            dchappel
            I don't know if this got fixed. Haven't gone back and checked.
            • I Offline
              iannucci @dchappel
              @dchappel I built my own version of the firmware with this fix in it. But as this is the first time I've built ESP32 / LoPy firmware, I am having a small problem. The make process seems to work properly, and the flashing process seems to work. But when I remove the jumper wire and reboot the LoPy, it runs a different version of firmware, not the one I just flashed.
              I've tried the safe boot tricks to no avail.
              Any ideas how to get the LoPy to come up running the version of firmware just uploaded via make?
              • I Offline
                iannucci @iannucci
                @iannucci Just re-tried this and was able to compile, flash and boot. Initial test indicates the issue is resolved, but I will do some additional testing.
                • I Offline
                  iannucci @iannucci
                  @iannucci Sadly, the fix does not work for me. Benefit: does not seem to hang. Downside: the first seven packets get through (according to the Loriot dashboard). After that, nothing.
                    cmsedore @iannucci
                    @iannucci I just was back in the office today and ran some tests--I couldn't create a scenario where it did not work as expected (all packets went through). Do you have source you could share? Does it behave better if you reconfigure all the channels as @dchappel suggested? (the code is in the post below)
                    • I Offline
                      iannucci @cmsedore
                      @cmsedore I just ran a test with @dchappel's code -- 4000+ messages and counting, no drops. Good news!
                        @cmsedore Sorry for the delay in merging your code. I'm testing it now and everything looks solid. This will be on the next release. Thanks for your contribution!
                        • 2 / 2
