Cant install Pymakr in Atom
I have been running pymakr without problem before in atom. Yesterday when I connected my pycom the terminal didnt showed up as it used to. I tried to unsinstall and was then going to install the new version but it wont install.
Gets this error message:
Installing “pymakr@2.1.12” failed.Hide output…@serialport/bindings@8.0.8 install C:\Users\jocke\AppData\Local\Temp\apm-install-dir-202145-13596-wqwffe.nk5n\node_modules\pymakr\node_modules@serialport\bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildC:\Users\jocke\AppData\Local\Temp\apm-install-dir-202145-13596-wqwffe.nk5n\node_modules\pymakr\node_modules@serialport\bindings>if not defined npm_config_node_gyp (node "C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated parser-byte-length@1.0.2: renamed to @serialport/parser-byte-length
npm WARN deprecated parser-cctalk@1.0.2: reanmed to @serialport/parser-cctalk
npm WARN deprecated parser-delimiter@1.0.2: reanmed to @serialport/parser-delimiter
npm WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline
npm WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-ready
npm WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
prebuild-install WARN install No prebuilt binaries found (target=9.4.4 runtime=electron arch=x64 libc= platform=win32)
gyp ERR! find VS
gyp ERR! find VS msvs_version not set from command line or npm config
gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer
gyp ERR! find VS looking for Visual Studio 2015
gyp ERR! find VS - not found
gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
gyp ERR! find VS
gyp ERR! find VS **************************************************************
gyp ERR! find VS You need to install the latest version of Visual Studio
gyp ERR! find VS including the "Desktop development with C++" workload.
gyp ERR! find VS For more information consult the documentation at:
gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows
gyp ERR! find VS
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Visual Studio installation to use
gyp ERR! stack at VisualStudioFinder.fail (C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
gyp ERR! stack at C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
gyp ERR! stack at C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
gyp ERR! stack at C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
gyp ERR! stack at C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
gyp ERR! stack at C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
gyp ERR! stack at ChildProcess.exithandler (child_process.js:297:5)
gyp ERR! stack at ChildProcess.emit (events.js:200:13)
gyp ERR! stack at maybeClose (internal/child_process.js:1021:16)
gyp ERR! System Windows_NT 10.0.19042
gyp ERR! command "C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\bin\node.exe" "C:\Users\jocke\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\jocke\AppData\Local\Temp\apm-install-dir-202145-13596-wqwffe.nk5n\node_modules\pymakr\node_modules@serialport\bindings
gyp ERR! node -v v12.4.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN notsup Unsupported engine for pymakr@2.1.12: wanted: {"atom":">=1.41.0","node":">=6.3.0 <=7.0.0"} (current: {"node":"12.4.0","npm":"6.14.8"})
npm WARN notsup Not compatible with your version of node/npm: pymakr@2.1.12
npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\jocke\AppData\Local\Temp\apm-install-dir-202145-13596-wqwffe.nk5n\package.json'
npm WARN apm-install-dir-202145-13596-wqwffe.nk5n No description
npm WARN apm-install-dir-202145-13596-wqwffe.nk5n No repository field.
npm WARN apm-install-dir-202145-13596-wqwffe.nk5n No README data
npm WARN apm-install-dir-202145-13596-wqwffe.nk5n No license field.npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install:prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.Does anyone have a clue how to solve this?
That diagnostic seems to reference VisualStudio rather than Atom. The pymakr plugins for VS & Atom are different as far as I know, are you sure you have the right one?
As far as Atom goes you probably need to roll back. https://forum.pycom.io/topic/6970/pymakr-not-compatible-with-atom-1-56/7
