    LTE init error
    ltemicorpythonfipy
    4 Posts 2 Posters 84 Views 2 Watching
      tttadam
      Hey there,
      When I create an LTE object on my fipy i got this error.
      The only solution I found if I replace the firmware on the lte modem, which is not really an elegant solution and not feasible in a batery operated device.
      Anyone has any idea what can caused this?
      I have a feeling is related to not shuting down the lte or the wifi object is present? IDK...
      Please give me some guidance...
      lte = LTE()
      Traceback (most recent call last): File "<stdin>", line 1, in <module> OSError: Couldn't connect to Modem!
        Can you give the output of lte = LTE(debug=True) and import sqnsupgrade; sqnsupgrade.info(debug=True)?
          tttadam
          Well right now it is working fine... but here it is:
          As soon as I experience it again, I will post again.
          >>> from network import LTE
          TypeError: extra keyword arguments given
          >>> lte = LTE()
          <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
          >>> FiPy with firmware version 1.20.0.rc13
          The current delay is 1000
          Response (+++ #1): None
          Response (AT #1) b'\r\nERROR\r\n'
          Response (AT #2) b'\r\nOK\r\n'
          Response (AT+SMOD?) b'\r\n2\r\nOK\r\n'
          Converting response: 2 to int...
          Modem state: 2
          mirror? False  recover? False  resume? True  direct? True  atneg_only? False bootrom? False load_fff? False
          baudrate: 921600 target_baudrate: 921600
          SYSTEM VERSION
            FIRMWARE VERSION
              Bootloader0  : 5.1.1.0 [41065]
              Bootloader1  : 5.2.1.0 [48829]
              Bootloader2* : 5.2.1.0 [48829]
              NV Info      : 1.1,0,0
              Software     : 5.2.1.0 [48829] by robot-soft at 2020-04-15 16:55:54
              UE           : 5.2.0.3
            COMPONENTS
              ZSP0         : 0.0.0-15743
              ZSP1         : 1.0.99-15968
          IMEI: 354346097957780
            @tttadam said in LTE init error:
            Concerning this error, please update to the latest stable firmware (1.20.2.r4) as the 'debug' keyword is not supported in the version you're using.
            Let me know if it happens again, generally the issue is solved by either machine.reset() or a power cycle
