Onewire Temp Sensor Does Not Work on latest 1.20.2.r6 Firmware
Hi
I've been using the Onewire DS18X20 temp sensor driver provided by @robert-hh for a while now, always running firmware
1.20.2.rc6
, no problems at all. Just recently upgraded to1.20.2.r6
, the latest revision, and the temp sensor readings returnNone
after the first initial reading.I am running this very simple
main.py
:import time from machine import Pin from ds18x20 import DS18X20 from onewire import OneWire #DS18B20 data line connected to pin P10 ow = OneWire(Pin('P22')) temp = DS18X20(ow) roms = temp.scan() temp.convert_temp() while True: time.sleep(1) for rom in roms: print(temp.read_temp(rom), end=" ") print() temp.convert_temp()
And I am using the
onewire.py
andds18x20.py
libraries provided here: https://github.com/robert-hh/Onewire_DS18X20. These are the ones I have always used, because the Pycom-provided libraries had a bug in temperature conversion.The problem is, if I remove the
print()
statements in thewhile
loop, the conversions are executed correctly. For example, if I modify the above loop to save the conversions to a list, instead of printing them:temp.convert_temp() ans = [] while True: time.sleep(1) for rom in roms: ans.append(temp.read_temp(rom)) temp.convert_temp() #print(ans)
And I later probe the value of
ans
by stopping the loop and writingans
in the REPL, I get:>>> ans [22.5, 22.5, 22.5, 22.5, 22.5625, 22.5625, 22.5625, 22.5625]
If instead I uncomment the
print(ans)
line in the above code, I get:[22.5] [22.5, None] [22.5, None, None] [22.5, None, None, None] [22.5, None, None, None, None] [22.5, None, None, None, None, None]
So every other conversion aside from the first one is incorrect, because of an
AssertionError: CRC error
(I noticed this by raising the exception in theread_temp()
method of theds18x20
class).This does not happen on my past firmware,
1.20.2.rc6
. I am using a LoPy4.Any ideas, anyone? This seems very odd, why should the
print
statement affect the communication with the DS18X20 sensor? If it were a timing issue, I'd understand a print would affect if executed in time-critical parts, but this print is called after the temperature has already been read.There is, however, one very interesting addition: If I change the print statement to
print("foo")
, the conversion works again. It only fails when the print is related toans
(the temp conversions list).By this point, I am already very frustrated and this seems metaphysical. Someone, please tell me if I am crazy. Thanks.
@d-alvrzx I'v tested that, and it seems to work fine. Sometimes the conversion fails. But that's to be expected. The timing seems acceptable.
The print problem you talk about indicates a memory corruption somewhere else in the code. Try to switch of WiFi and Bluetooth.
P.S.: It took me a while and a handful of curses to compile the firmware. Quite a few compile errors and warnings. At least one of them shows a bug. I do not know if people at Pycom verify, that the code the publish builds at least. It seems that no.
Hey, @robert-hh, any chance you could try to reproduce this, just to see if it's just an issue on my side?
