Pybytes Downlink Messages
Is there a way to receive messages from pybytes? I don't see anything documented but it would be nice to enable control on the app layer.
Something like:
pybytes.receive_signal(topic, data)or even have send_signal return the last message posted to the topic when called.
Hello @Carl-Folkesson,
On the latest Pybytes firmware we have implemented the downlink feature over MQTT.
Steps:
- Once the device is activated
pybytes.set_config('pybytes_autostart', False)- in your
main.pyyou have to initializepybytes - To send a JSON string via MQTT to the device, you need to use topic
d+<device_id> - The message should start with
0x08h+ MESSAGE example: To send{"test":"value"}the hex code is:087b2274657374223a2276616c7565227d
main.pyTest Code:def callback_function(message): print(message) if (len(pybytes_config['username']) > 4 and len(pybytes_config['device_id']) >= 36 and len(pybytes_config['server']) > 4): from _pybytes import Pybytes pybytes = Pybytes(pybytes_config, user_callback=callback_function) if pybytes.connect_wifi(): # SEND PING pybytes.send_ping_message() # SEND DEVICE'S INFORMATION # The INFO message should always be sent, otherwise, Pybytes could not be aware # of some important information regarding this device, like its firmware version. pybytes.send_info_message() # ENABLE TERMINAL # This should always be enabled if you're using firmware that is compatible with the pybytes terminal. # The terminal messages will use the virtual pin (or signal) 255. pybytes.enable_terminal() else: print("Failed to connect to Pybytes! Invalid credentials or network issues?") else: print("Could not load Pybytes configuration!")NB: Kindly note that this is still experimental.
Let me know if you face any errors.
Have a nice day.
Best Regards,
Ahmad El Masri
Hi @jirkakrepl,
Any update on downlink functionality over Wi.Fi/LTE?
Hi @mcallistertad,
I agree. Currently, there's no way to do it. We will discuss today and probably implement this functionality.
On Wi-Fi/ LTE Cat m1 we could send any downlink messages over mqtt.
on LoRa/Sigfox we need to do something else - we are constraint by bandwidth and downlink connection windows
