    Helium Hotspot Miner - Batch 1 Available for Pre-order. Ships June 2022
    Scheduled Pinned Locked Moved Helium Hotspot
    29 Posts 13 Posters 500 Views 14 Watching
    • H Offline
      Heraldo Salinas @Bettina
        Alexander Pilhar @Bettina
        @Bettina Congrats on this wonderful device!
        I do have a question I couldn't find an answer to, yet:
        What type of helium hotspot is this device? I guess it is a Full Hotspot, right?
        For information about hotspot types see helium dev docs.
          Martin Flauger @Bettina
          @Bettina Great to see price is dropping even for a fulf hotspot. Hopefully you have a more reliable contract manufacturer as your compettitors. Anyway, I orderd a few minutes ago :-)
          Two question: Can you confirm that there is a RP-SMA female on the body and the anntena has a RP-SMA male connector. Thx.
          The reason why ethernet is only optional is that only WIFI is situable to sync the blockchain ? => Not clear when HIP 55 will be implemented .
            Lucian Pavaloi
            I really wish the discord channel creation will happen faster. That would improve communication a lot!
              Bettina administrators @Lucian Pavaloi
              @Lucian-Pavaloi we'll go live with Discord as soon as we start shipping hotspots.
              Bettina
              Pylot at Pycom
              L 2 Replies Last reply Reply Quote 0
                Bettina administrators @Alexander Pilhar
                @Alexander-Pilhar Thanks and yes it is indeed a Full Hotspot (included in the price are the $40 registration fee and the first $10 Location assertion fee) :-)
                Bettina
                Pylot at Pycom
                  Bettina administrators @Nic Lalanne
                  @Nic-Lalanne Hi Nic, let me come back to you on that one. I need to check a few things.
                  Bettina
                  Pylot at Pycom
                  • F Offline
                    Francisco Juan de Santos Iglesias
                    Hello, I write from Spain.
                    I want to buy some hotspots but I need to know the final price in Spain. What is the "HS Code" of this product to know what fees are going to be applied to the import?
                    If my sister (who lives in London) buys them, what is the final price with taxes there?
                    Thank you very much
                      Lucian Pavaloi @Bettina
                      @Bettina I believe it's best to go live with the discord channel way before the shipping starts so people can address questions.
                      Also, can you please explain exactly how the add-on poe module is installed ? maybe a video turorial or something? I want to prepare my setups in advance and I have never used this module so I want to know if I should go with this or do my own poe injector & splitter setup.
                        Lucian Pavaloi
                        @Bettina can you please explain a bit more about the poe shield? does the device needs this in order to receive poe directly in without the need of a splitter while it still requires an injector, is that what it's for? or can this device be used with the regulat 0.5a 48v poe injectors & splitters already available on the market?
                        I cannot stress enough the need for a discord server again ....
                          @Nic-Lalanne Sorry, no we don't have that yet. We do have IP67 cases but they are not custom made for the Hotspot.
                          Bettina
                          Pylot at Pycom
                            Bettina administrators @Francisco Juan de Santos Iglesias
                            @Francisco-Juan-de-Santos-Iglesias You will most likely be asked to pay VAT when the hotspots enter Spain, coming from the UK. So you'll need to apply the VAT percentage on electronics (and observe if there are any for import duty (which would then be in addition)).
                            Bettina
                            Pylot at Pycom
                              @Lucian-Pavaloi We're looking into going live soon.
                              Bettina
                              Pylot at Pycom
                                @Lucian-Pavaloi The PoE module adds Ethernet + PoE to the Pycom Helium Hotspot. It supports both active and passive PoE. It doesn't require a splitter but it requires an injector or PoE enabled networking switch.
                                Bettina
                                Pylot at Pycom
                                M G 2 Replies Last reply Reply Quote 0
                                  Bettina administrators @Martin Flauger
                                  @Martin-Flauger The antenna has RP-SMA male connector. It is provided an RP-SMA female to UFL cable, to attach in the UFL connector in Pygate.
                                  The hotspot could connect to internet via WiFi or via the Ethernet port. Also the Ethernet port has POE capabilities, so the whole unit can be powered. This is good for when installing a hotspot in a rooftop of a building for two reasons, 1-probably in the rooftop you won't have wifi signals, specially if your appartment is not in the last floor, 2-you won;t need to carry cables with power supply and also the antenna cable to bring the signal from your antenna to your hotspot (long cables add extra losses). So, it is will always better to keep the device as close as possible to the antenna, and a POE/internet is great for it, so you will need only a single cable to power your device, and don't need to worry for cable losses, neither for connectivity in the rooftop
                                  Bettina
                                  Pylot at Pycom
                                    @Bettina Can I buy the PoE module later and install it by myself ?
                                      @Nic-Lalanne Hi Nic, No, not at the moment.
                                      Bettina
                                      Pylot at Pycom
                                        @Martin-Flauger Yes you should be able to. However, please note that at the moment, our OEM modules are reserved for Hotspots shipping and therefore, they may not be in stock.
                                        Bettina
                                        Pylot at Pycom
                                          Georgi Rusev @Bettina
                                          @Bettina Hello , it may be a silly question but how many watts must be the PoE injector 15W or I will need more ? Thank you !
                                            @Bettina can you please create the discord channel faster to improve the communication? I think many people are missing out on this simply because they don't want to wait to get answers via forum anymore. Discord is so much faster. Also, the shipping date of the 1st batch is coming close so I think people have many questions to ask and this is ideal for a discord channel.
                                            I don't understand why it's taking so long.
