    SI7021 I2C sensor
    lopyi2ctemperaturehumiditysi7021
    3 Posts 2 Posters 2.3k Views 2 Watching
      tobru
      I'm trying to get the SI7021 sensor working, which is connected on the I2C bus. Connectivity basically works and I can also write and read bytes. But I strugle with converting the example Arduino code to MicroPython. I've also found another example using the smbus Python library, but I also couldn't find out how to convert this.
      Here is what I've done so far:
      from machine import I2C
      ADDR = 0x40
      SI7021_MEASTEMP_NOHOLD_CMD = 0xF3
      SI7021_MEASRH_NOHOLD_CMD = 0xF5
      # configure the I2C bus
      # Humidity
      i2c.writeto(ADDR, bytes([SI7021_MEASRH_NOHOLD_CMD]))
      time.sleep(0.3)
      hum0 = i2c.readfrom(ADDR, 1)
      hum1 = i2c.readfrom(ADDR, 1)
      print(hum0)
      print(hum1)
      #humidity = ((hum0 * 256 + hum1) * 125 / 65536.0) - 6
      #print(humidity)
      # Temperature
      i2c.writeto(ADDR, bytes([SI7021_MEASTEMP_NOHOLD_CMD]))
      time.sleep(0.3)
      temp0 = i2c.readfrom(ADDR, 1)
      temp1 = i2c.readfrom(ADDR, 1)
      print(temp0)
      print(temp1)
      #cTemp = ((temp0 * 256 + temp1) * 175.72 / 65536.0) - 46.85
      #fTemp = cTemp * 1.8 + 32
      #print(cTemp)
      Output:
      b'F'
      b'F'
      b'h'
      b'h'
      Currently I don't understand how I can read and convert the data correctly. Sending the commands works and I also get some sort of data back when calling the i2c.readfrom function, but then I'm lost. F.e. I don't know how many bytes I must read and then how to convert it to an actual useable value.
      Any help is much appreciated!
      Tobias
        crankshaft
        Try This;
        from time import sleep_ms
        from machine import Pin, I2C
        # Default Address
        SI7021_I2C_DEFAULT_ADDR = 0x40
        # Commands
        CMD_MEASURE_RELATIVE_HUMIDITY_HOLD_MASTER_MODE = 0xE5
        CMD_MEASURE_RELATIVE_HUMIDITY = 0xF5
        CMD_MEASURE_TEMPERATURE_HOLD_MASTER_MODE = 0xE3
        CMD_MEASURE_TEMPERATURE = 0xF3
        CMD_READ_TEMPERATURE_VALUE_FROM_PREVIOUS_RH_MEASUREMENT = 0xE0
        CMD_RESET = 0xFE
        CMD_WRITE_RH_T_USER_REGISTER_1 = 0xE6
        CMD_READ_RH_T_USER_REGISTER_1 = 0xE7
        CMD_WRITE_HEATER_CONTROL_REGISTER = 0x51
        CMD_READ_HEATER_CONTROL_REGISTER = 0x11
        class SI7021(object):
          def __init__(self, i2c=None):
            self.i2c = i2c
            self.addr = SI7021_I2C_DEFAULT_ADDR
            self.cbuffer = bytearray(2)
            self.cbuffer[1] = 0x00
          def write_command(self, command_byte):
            self.cbuffer[0] = command_byte
            self.i2c.writeto(self.addr, self.cbuffer)
          def readTemp(self):
            self.write_command(CMD_MEASURE_TEMPERATURE)
            sleep_ms(25)
            temp = self.i2c.readfrom(self.addr,3)
            temp2 = temp[0] << 8
            temp2 = temp2 | temp[1]
            return (175.72 * temp2 / 65536) - 46.85
          def readRH(self):
            self.write_command(CMD_MEASURE_RELATIVE_HUMIDITY)
            sleep_ms(25)
            rh = self.i2c.readfrom(self.addr, 3)
            rh2 = rh[0] << 8
            rh2 = rh2 | rh[1]
            return (125 * rh2 / 65536) - 6
          tobru @crankshaft
          @crankshaft said in SI7021 I2C sensor:
          Try This;
          WOW! You're great, works like a charm... Thank you very very much!
